38 gallon fuel tank swap
Discussion in '2.5 Gen Builds (2014-2021)' started by Goneforgood, May 10, 2019.
  1. May 10, 2019 at 5:12 PM
    Goneforgood
    Goneforgood [OP] New Member
    Mark
    2017 tundra
    Saw a post from papa smurf a while back about swapping out a 26 gallon tank for a 38 gallon in 2nd gen.
    Just wondering if anyone has done this in a 3rd gen. Looks totally doable, but looked under my 2017 with 26 gallon and wondered how you deal with the rigid fuel lines that are run further back on the frame for the shorter tank. Anyone?
    Y0TA PR0 likes this.
  2. May 11, 2019 at 3:09 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    OR18TRD likes this.
  3. May 11, 2019 at 3:18 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    I just got a 38gallon tank but waiting on my front crossmember to arrive so I can install!
    Didn’t all 2016+ 5.7L come with a 38gallon tank?
    TXRailRoadBandit73 likes this.
  4. May 11, 2019 at 4:42 PM
    Sunnier
    Sunny
    San Diego, CA
    Nope. It was one of the packages.
    Y0TA PR0[QUOTED] likes this.
  5. May 11, 2019 at 4:53 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Ah ok! I didn’t know that.
  6. May 11, 2019 at 6:43 PM
    Man you lucky!!! I'm looking for one too
  7. May 11, 2019 at 6:51 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    OR18TRD[QUOTED] likes this.
  8. May 11, 2019 at 6:53 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Keep looking bud you’ll find one! I’ve been wanting one since 2016!
  9. May 12, 2019 at 4:14 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I'm thinking you may have fewer headaches by simply replacing the existing lines with those for 38 gallon tank. In fact, it looks to me like the only difference is some short lines right at the tank. Check with @Roman about Items 20 and 21 in this diagram: https://parts.toyotaofcoolsprings.c...7l-v8-gas/fuel-system--fuel-system-components
  10. May 13, 2019 at 8:04 PM
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    The problem with changing the lines on the tank (20 and 21) is they won't meet up with the lines on the frame. I thought the lines were needed and I then looked into changing the 2nd set of lines that run from tank forward along the frame, but can't find them on any diagram, and don't know if they go all the way up to the engine bay or not, as they are covered by a heat protective wrap.
    I also can't find the parking brake diagram either. As I assume it's different because on a 2nd gen (what I have) it is in the way of the crossmember, but a 3rd gen is more of a bolt on swap.
    I have all the parts waiting to go in, but I am torn on if I want to part ways with it all and go the TF route. I am trying to figure out a way to get it high enough via hoist or stands, plus finding time!
  11. May 13, 2019 at 10:39 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    You use the short lines from the 26 gal tank and the parking brake is slightly different on the third gen worst case is you bend up the bracket a bit...
    Also why make a new thread I’ve covered pretty much everything... and you could just PM me or tag me in the thread I made about this... seems silly to put useful info not in a thread that is easily searchable That is also a well known thread...
  12. May 18, 2019 at 8:46 AM
    Goneforgood
    Mark
    2017 tundra
    Hey Bruce,
    I found your fuel tank post very helpfull, it’s what actually made me decide to go ahead and do the swap. If I am understanding correctly, you would just fabricate new brackets to push the fuel lines and parking brake cable up high enough to clear the tank and reconnect.
    Still waiting for the front cross member, thinking that might be the hardest part
    of the swap.
  13. May 18, 2019 at 9:20 AM
    gjcarving
    gjcarving New Member
    Huh. I don't know if my mechanic/friend switched out for the shorter lines of the 26 gallon tank or not. Would there be an issue? I may have to seriously pm you when my new cross member arrives
