38 gal tank ( do you drive past 'empty' )
Discussion in 'General Tundra Discussion' started by Mostel, Feb 14, 2020.
  1. Feb 14, 2020 at 9:16 AM
    Mostel
    Mostel [OP] New Member
    2020 tundra plat
    Hi guys,
    New member here, thanks for providing this great resource! I am on the verge of getting a 2020 Plat Tundra. I searched extensively for real answers on this question. Hope you can help me out. So the 38 gal tank reads empty after only 28-30 gallons have been used. I'm told this is because 8-10 gallons reserve is needed to keep fuel pump primed. Here is my question. Is it safe to drive say, HALF WAY into the reserve, on a regular basis. Not draining the tank but driving 5 gallons into the reserve? Does anyone do this regularly? I need as much range as possible, but do not want to damage the fuel pump. Thanks very much!
  2. Feb 14, 2020 at 9:37 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    You will not have any issues. It is the fuel going thru the pump that keeps it cool, not being submerged under the "reserve" fuel.
    Since my '06 DC I have over 600k miles in 3 tundras, I run to below zero miles and beyond every tank and no issues
    Mostel[OP] likes this.
  3. Feb 15, 2020 at 9:56 AM
    Mostel
    2020 tundra plat
    Thanks for reply. Is the 06 engine (5.7) different than the next gen? I'd really appreciate if some other 38 gal owners would chime in! Thanks very much
  4. Feb 15, 2020 at 10:00 AM
    NWPirate
    Zach
    WA
    The 5.7 was new in 07, no problems running past 0 miles left.
    Mostel[QUOTED][OP] likes this.
  5. Feb 15, 2020 at 10:02 AM
    Mostel
    2020 tundra plat
    Thank you very much. Funny when you search this subject, it's hard to find a clear answer. Even the service guys at my dealer had no clue. A buddy owns a '17 and never drives into reserve - he is afraid to mess up the pump. So there's a bunch of funny info out there on this. Thanks again.
    NWPirate likes this.
  6. Feb 15, 2020 at 10:57 AM
    NWPirate
    Zach
    WA
    Yeah, reminds me of the saying opinions are like assholes, everyone's got one. :D
    I generally fill up between 1/4 & E and put around 31 gallons in.
    Enjoy the truck!
  7. Feb 15, 2020 at 11:06 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I generally fill at or around 1/4 tank. If I needed extended range, I'd get a transfer tank. Most of the time gassing up is a matter of convenience, not really fuel remaining. Guess it's the benefits of a large tank. I also refuel exclusively at Costco for points.
    Example. Family wants to drive from home to San Diego. We CAN range out that far, but why not get Costco fuel in Bakersfield and not sweat gas for awhile. Generally you'll want to get out and stretch after 6-8 hours of driving anyway.
    Just my. 02
    Mostel[OP] and Cpl_Punishment like this.
  8. Feb 16, 2020 at 9:13 AM
    Mostel
    2020 tundra plat
    I appreciate everyone's reply. But I'm surprised 10-15 owners didn't chime in. This should be a no brainer question, but it continues to be one where there is no definitive answer. Weird!!
  9. Feb 16, 2020 at 11:11 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    This has been discussed in dozens of threads, that is probably why few people have responded.
    I have run mine to "0" a couple of times and each time I had about 9 gallons left. Some have run completely to the point they put 38 gallons in at fill-up. Best thing to do is keep track of your mpg (don't trust the dashboard call out, it is an estimate) and get a handle on the actual quantity in your tank over time.
  10. Feb 16, 2020 at 11:37 AM
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    My guess is that Toyota's read zero with 8 to 10 gallons left to keep the fuel pump submerged. I know the 2015 with 24 gallon tank I had read zero with 4 gallons left. I always heard that the fuel keeps the pump cool. Toyota is big on reliability. So I think they make zero the point where the pump begins to hit air. That way they never get hot and die prematurely. That's my guess.
    Tierhog and Mostel[OP] like this.
  11. Feb 16, 2020 at 12:57 PM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    even when I’ve fueled at a point I’ve felt I’ve pushed it far enough I’ve RARELY seen 33 gals on a fill. Usually when I fill I’m putting in 30-31, and this is regular for 4 years of ownership now
  12. Feb 16, 2020 at 2:39 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Cost too much to fill up when it's on empty. I fill up at half a tank or just below half.
  13. Feb 16, 2020 at 2:46 PM
    Mostel
    2020 tundra plat
    Thanks guys. If you look at thread, one person says the fuel pump is primed by gas going THROUGH it. Another says, when it reads empty is when it begins to "hit air", suggesting that if you drive further, the pump gets more exposed to risk. Yes there are tons of threads on this but no agreed upon conclusion. This 38 gal tank is a major buying point, but seems like almost no one drives 35-36 gals. In any other vehicle, the gauge would tell you your remaining miles. It's not a deal breaker but why is there no definitive answer in writing from Toyota? Or is there?
  14. Feb 16, 2020 at 3:03 PM
    Pinski
    Pinski New Member
    Mark
    Western New York
    2018 SR5 TRD Crew
    Volant (Corsa) cat back,tint
    I always wait till well after the light comes on until I fill up. That’s the benefit of having Such a big tank, you don’t have to fill up as much...I usually put 32-34 gallons in minimum when I fill up.
  15. Feb 16, 2020 at 3:08 PM
    If you're going to push the range then make sure you park it level. The 38 gallon tank is very long, so with low fuel you could park on an angle and run the remaining fuel away from the pump. There was a member on here who did it in a steep driveway.
  16. Feb 16, 2020 at 3:19 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2^^, same here
    easleycrawler[QUOTED] likes this.
  17. Feb 16, 2020 at 9:08 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    Same for me, I don’t even think about getting gas until the light comes on. Drive to work and maybe stop somewhere on my way home. Even at that point I’ve never put in more than 33 gallons.
  18. Feb 16, 2020 at 9:55 PM
    Blue Thunder
    Washington
    I ran mine to almost "zero miles remaining" and pumped in 34.5 gallons. There are a lot of different results here on the forum, so I recommend doing your own testing and see how your truck performs.
    GODZILLA likes this.
  19. Feb 17, 2020 at 3:14 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I think Toyota must just normally give you a pretty good reserve. It is human nature to push any opportunity or advantage to the limit. My 06 is sitting at 1/8 or less and will take around 16-18 gallons and I think it's a 26 gallon tank. I had the light come on once and I've never as much as 20 gallons on it.
    My advice is keep a 7 gallon Jerry can in your truck and fill it up at 1/4 tank. That way you are covered if there's an emergency. Your pump is happy, you are happy, your dependents are happy, the guy on the side of the road that thought "empty" was something to be pushed is happy. Happy happy happy happy.
    Blue Thunder likes this.
  20. Feb 17, 2020 at 3:46 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    How much you spend on gas is dependent on how much you drive not when you fill up. I have driven mine past zero several times. I would not listen to the internet hype about keeping the pump cool. Stopping to get gas takes time and my time is worth something.
    Ronin73 likes this.
  21. Oct 12, 2021 at 3:46 PM
    exSCSemployee
    exSCSemployee New Member
    2020 Tundra
    I guess like some of y’all, I just had the experience of running until it read 2 miles to empty. Upon seeing this I am looking for some sort of idiot light that tells me I am low on fuel, nothing. I was fortunate enough to just arriving into town and was able to make it with 1 mile showing til empty. After I unclenched my butt from the seat I got out and fueled up only taking 31 gallons. I have often wondered about this when I fill up it only shows a range of 500 miles.
  22. Oct 12, 2021 at 4:51 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I generally fill up before the low fuel light comes on because I want to have that reserve just in case I need to drive somewhere and can't get fuel right away. I don't have a 24 hour gas station right around the corner.
    There is a lot of tolerance in the manufacture and installation of the sending unit in the tank which sends the signal to the fuel gauge. You can not rely on your Tundra having the same number of gallons in reserve as another Tundra. They will vary quite a lot.
    There have been discussions on this forum about whether or not the fuel pump will overheat if you run the tank down too low and the consensus seems to be that fuel flowing through the pump cools it, not the reserve reservoir. I suppose that if you ran the tank dry there may be some premature wear on the pump, but that is only a guess.
  23. Oct 12, 2021 at 5:04 PM
    CoachRob
    CoachRob New Member
    Platinum 4x4
    I have a ‘20 platinum also. I drive pass reserve (I go 20-60 miles pass 0/refuel mileage on dash). No problems in 2 years
    glowblue likes this.
  24. Oct 12, 2021 at 5:08 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ( do you drive past 'empty' ) = NO
  25. Oct 12, 2021 at 7:57 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
  26. Oct 12, 2021 at 11:30 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    57AA0889-05B4-4253-8082-0568935D959A.jpg This is one issue that torques my sac. It’s the same sender unit for the bigger gas tanks so it reads empty when you’re not even close. My gas light comes on with just over 12 gallons left. I go off of the odometer more than the gas gauge.
    Tundratoofun likes this.
  27. Oct 13, 2021 at 3:18 AM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    I would pay more attention to a low "Window Piss" light if we had one. Hate running out of that shit in the winter time! Low full light also goes off when you go downhill..fyi...sorry for shitty input!
    WVI and Tundratoofun like this.
  28. Oct 13, 2021 at 4:48 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    I've been following Internet forums since shortly after they came into existence, and I can tell you that "agreed upon conclusions" are virtually non-existent. ;) You just need to take the info you have and roll with it.
    Getting a definitive answer from Toyota corporate won't happen. If you get an answer at all it'll be a form letter recommending you not let it get too low, and it's doubtful they'll say what, exactly, too low is.
    I've heard the "gasoline cools the fuel pump" theory for years. I had a friend who would browbeat me mercilessly for letting my Dodge get below 1/4 tank. Sure enough I had to replace a fuel pump, and he was on that like white on rice. I pointed out that it had 170,000 miles on the clock -- and it was a Dodge :) Didn't matter. If I hadn't repeatedly let it get below 1/4 tank the fuel pump wouldn't have gone out. It's like he'd been predicting I'd burn up a fuel pump for decades, and I finally proved him right. LOL
  29. Oct 13, 2021 at 5:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    i fill up @ 1/4.
    when I had the Harrop installed...the installer said..."keep it fueled"
    meaning keep at least 1/4 tank in it.
  30. Oct 13, 2021 at 6:06 AM
    2mchfun
    Life experience tends to lead me to the gas station at a third full. After you find yourself in bad spot enough times it changes your perspective. Nowadays everyone has a phone, but back when I did most of my driving they didn't exist. Still though you should keep some gas in it, accidents and such still happen folks. You can get detoured at the craziest of times, been there done that! Just having a bottle to whiz in can also help a bunch when you find yourself up on tall bridge for two hours because someone wasn't paying attention.
    nobodyintexas likes this.
