37x13.5 on 18x9.... thoughts?
Discussion in 'Wheels & Tires' started by AnonVet, Mar 7, 2018.
  1. Mar 7, 2018 at 9:51 PM
    AnonVet
    AnonVet [OP] That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    What's up yall, I'm looking into getting some 37s and keeping my current rims. The 20s or 22s with a nice offset and deep dishes look nice, I can't keep myself out of the mud and whatever else I can get into. I'm wanting more tire and don't want to upgrade rims because they won't stay looking pretty. I've been looking around and can't seem to find tundras with lots of sidewall. Anyone herr running nice size tired with some 18s or 17s? If so... post some pics
    831Tun likes this.
  2. Mar 7, 2018 at 10:05 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    @zackbremer is running 37"
    GodlessPro and Sunnier like this.
  3. Mar 7, 2018 at 10:07 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    @SoCalDave is too I think. Check the speed glampers (SGU). Several of those guys are running the RW 17" wheels with at least 35s.
  4. Mar 7, 2018 at 10:33 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Ya I seen a ton of this dudes videos on YouTube. Literally looking everywhere lol
    GNTundra likes this.
  5. Mar 7, 2018 at 10:35 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Nothing about my rig says "what's dirt" lol. And the stuff I get into, I'll need the sidewall
  6. Mar 8, 2018 at 3:34 AM
    zackbremer
    zackbremer New Member
    Da Z
    13.5 youre going to run into a lot of rubbing issues unless youre on a bracket lift...try to stick with a 37x12.5..i have pics in my build and i run the toyo RT(one of the bigger 37s) with 2in of lift and no rubbing unless im flexing with the wheel turned
    AnonVet[OP] likes this.
  7. Mar 8, 2018 at 8:26 AM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    I'm running 37x12.5r17 and rub a little bit in reverse at full lock. You might rub a little more with 13.5s.
    AnonVet[OP] and dcsleeper408 like this.
  8. Mar 8, 2018 at 8:56 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    If I remember correctly, @KevinK was running 37x13.5's at one point.
    AnonVet[OP] and KevinK like this.
  9. Mar 8, 2018 at 9:11 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    We ran 37x13.5 on a 18x9 +18 offset rim.
    2” lift
    No rub. Just have to trim some shit outa the way. I wrote it up in our build thread. The pic in my sig will take you there or search ‘komodo’ on this site. Offset is the key factor in larger tires
    Now we run 37x12.5 on 17x8.5 0 offset beadlocked Methods.
    2” lift
    No rub. Had to get a tad more aggressive on the body mount chop and we use heimed uppers to make alignment adjustments. That lets us push the lower control arm as far forward as possible to clear the body mount better.
    Skew12, RangerBP, Samoan Thor and 4 others like this.
  10. Mar 8, 2018 at 1:58 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Thanks for all the input fellas. I'm getting a stage2 lift and cranking my 5100's to 2.5 and throwing deavers in the rear and want to keep my 18's. @KevinK thanks for the pics and description bud. Ton of help. Nice to see y'all are into more then just crawling through malls and using this bad boy for what's worth.
    KevinK likes this.
  11. Mar 8, 2018 at 2:18 PM
    15whtrd
    15whtrd Mr. Blonde
    I love your truck so much. It’s one of my favorites here. Actually your wife’s truck if I remember correctly.
    KevinK[QUOTED] likes this.
  12. Mar 8, 2018 at 2:54 PM
    KevinK
    Tundras to Sedona
    We do some mall crawling too. :rofl:
    Thanks man! Yeah, it’s her daily driver. I just get to consult on the upgrades and drive it sometimes. :cool:
  13. Mar 24, 2018 at 8:51 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I'll be honest, I like 20's on the tundra as it is more proportionately sized and with 35's it looks like it has alot of rubber but then the price for tires is steep. Before you hate on me, I know, Im getting 17" wheels with 35's. The only benefit of my OEM 20's right now is the MPG's with stock tires.
