37s with stock gears
Discussion in 'Performance and Tuning' started by mixwells, Jun 19, 2017.
  1. Jun 19, 2017 at 9:09 PM
    mixwells
    mixwells [OP] New Member
    lets hear some honest reviews, guys running 37s with the stock gears! Can't decide on 35s or 37s:notsure:
    Rica25 likes this.
  2. Jun 20, 2017 at 4:45 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Are you lifted high enough to do either, or trying to decide?
    Rica25 and Law323 like this.
  3. Jun 20, 2017 at 6:05 AM
    mixwells
    Yup good to go, just got a BDS 7" kit in the mail! Now on to tire size?
  4. Jun 20, 2017 at 6:12 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I don't have 37's, but from what I've read on here the guys who go to 4.88's generally see less downshifting and overall better get up n go. @1UPPER, @Spvrtan and @papasmurf are a few of the guys who run 37's on this site.
    Rica25 and 15whtrd like this.
  5. Jun 20, 2017 at 6:27 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    37s with stock gears will not harm your truck. You will lose power. Up to you if you are willing to deal with the power loss.
    37s and 4.88 will bring your truck back to stock ratio. So if you like how the truck feels with 32s and 4.30 gears, then that is how 37s and 4.88s will feel
  6. Jun 20, 2017 at 6:47 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    After having 4.88s installed now with 37s I definitely notice an improvement at highway speeds. My truck gets to highway speeds faster without shifting between 5 & 6th gear as much.
    Rica25, papasmurf and Jsena like this.
  7. Jun 20, 2017 at 8:46 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    You'll want to regear for sure..
    Stock gears on 37's makes the truck feel like there's an extra 1000 lbs in the bed everywhere you go.
    Gee Dub, TRDblvd and showtime240 like this.
  8. Jun 20, 2017 at 11:05 AM
    KOZ
    KOZ New Member
    Indiana
    2008 Toyota Tundra SR5 Regular Cab
    TRD Supercharger TRD Lowering Springs TRD Front Sway Bar TRD Rear Sway Bar URD Pulley 2.345" TRD 22" Wheels SOS 2.5"/4.5" Lowering Kit StopTech Big Brakes Front & Rear JBA Headers JBA Cat Delete w/O2 Sims Dirty Deeds Budget Dump
    I'm running stock gears with 37" no issues but I also have a TRD Supercharger installed so my opinion isn't really that relevant.
  9. Jun 20, 2017 at 11:10 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    @dirtydeeds is spot on. 4.88s need to happen. He has the best price I could find and is super helpful too! I just did a blower also...everyone should have them. 37s on stock gears were ok for flat roads with no load in bed or truck with the wind pushing you.
    Pay to play. Do 37s do gears.
  10. Jun 20, 2017 at 2:52 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I'm loving my new 4.88s and LSD with the 37". I'm still taking it easy for the initial break in period but I notice it's a big difference. IMG_8242.jpg
    D4x4TRD, TundraDad73, Mattyc and 2 others like this.
  11. Jun 20, 2017 at 2:55 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    I wouldn't go over 35" tires without re-gearing.
    showtime240 and 1UPPER like this.
  12. Jun 20, 2017 at 4:08 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    I ran Toyo 37's on my last truck and had 3:42's. It ran ok too and helped cut down on tire wear r/t spinning but then again it was a modified Cummins. You can get by with 37's and a stock 5.7 with 4:30's but 4:88 would be better and if you plan on 40's later you may as well go with 5:13's. I ran 33's on my supercharged Tundra and it was perfect as long as you didn't floor it from a standstill.
    JBSTOY likes this.
  13. Jun 20, 2017 at 4:18 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Unfortunately they only make 4.88 gears for Tundra.
    GNTundra and zcarpenter92 like this.
  14. Jun 20, 2017 at 4:28 PM
    :drool:
  15. Jun 20, 2017 at 8:16 PM
    mixwells
    Thanks for input guys, how about those 35s?
  16. Jun 20, 2017 at 8:20 PM
    dirtydeeds
    Keith
    USA
    I would run 4.88 on 33's. Much less 35's or 37's.
    Rica25, 15whtrd, showtime240 and 2 others like this.
  17. Jun 21, 2017 at 9:37 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    35.4" on mine with the SC, I do notice a difference from stock. But going to 4.88 would really put me up much higher than I want to run the RPM band down the highway with 35's
    Mnorris1206 likes this.
  18. Jun 21, 2017 at 2:56 PM
    dirtydeeds
    Keith
    USA
    lower rpm causes a steeper throttle position. Steeper throttle position is sensed as more load by the ecu.
    In other words, you're better off with slightly higher rpm, that you are with slightly more throttle position.
  19. Jun 30, 2017 at 11:36 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Anyone here running 37's , is the width typically 13.5????
  20. Jun 30, 2017 at 11:38 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    12.5 on mine. wish they were wider but they rub already at a 0 offset up front.
    Jsena likes this.
  21. Jul 1, 2017 at 12:29 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    BFG has a 37x12.5 for 17" wheels. Not sure about other size wheels
    Jsena[QUOTED] likes this.
  22. Jul 1, 2017 at 12:30 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    0 offset is hard to clear
    Jsena likes this.
  23. Jul 1, 2017 at 12:51 PM
    1UPPER
    TEXAS
    Flux capacitor!
    37 typically come in 12.5" or 13.5" wide. I'm running 13.5" because my wheels are 12" wide with a -51 offset. I wanted the extra side wall protection since I'm running a 12" wide rim. What size rim are you thinking of running? What size lift are you looking at doing?
  24. Jul 1, 2017 at 1:27 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    22x10 -25
    7 inch BDS
  25. Jul 1, 2017 at 1:52 PM
    1UPPER
    TEXAS
    Flux capacitor!
    You can clear a 37". I'm running the same size lift with a bigger offset and wider rim. You may need to have your body mounts shaved and probably need to shave some of the inner fender to push the fender guards more forward. It's not a big deal but some people do not want to cut their stock body mounts. There are several companies who sell the body mount steel trim pcs. So you just need to cut the corner and weld the steel plate and then repaint it with a high gloss black. Here is a link to the plates for the body mounts.
    http://www.socalsupertrucks.com/2007-current-tundra-body-mount-plate-kit.aspx#.WVgLh7U8KEc
  26. Jul 1, 2017 at 1:54 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Thanx a lot again.. do you have rub issues ?
  27. Jul 1, 2017 at 2:02 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Before the body mount had been cut I did rub a little when I would reverse with the tires fully cranked. After having the body mounts trimmed I don't rub at all.
  28. Jul 1, 2017 at 2:09 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Sweet... thanks a lot my friend :thumbsup::cheers:
  29. Jul 1, 2017 at 6:53 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    On the highway the transmission keeps going back and forth from 6th to 5th gear. It is really annoying. That's also a lot of wear on the trans over time. With tires over 35" changing gears is a must. My truck drives so much better with the 4.88s.
    zcarpenter92 and Jsena like this.
  30. Jul 1, 2017 at 7:31 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea I'm getting it done.. 100% was just thinking about that Auburn.. do I need it ¯\_(ツ)_/¯
