37" tires = RE-GEAR
Discussion in 'Wheels & Tires' started by JTP, Jun 2, 2017.
  1. Jun 2, 2017 at 8:06 AM
    JTP
    JTP [OP] The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Did a little road trip hauling research pulling a pretty light weight boat last few days.
    Boat and gear was around 1500#s and we had the bed loaded down with another 500#s or so of gear.
    I am defiantly going to have to do the re-gear for towing anything heavier running these 37's.
    Gas mileage suffered more than I would like and top end pull was just not there like it should be.
    Was not horribly bad but pulling anything heavier is going to be tough going without the gear change.
    Running around town or down the highway is fine with out them but if your going to work / pull with it then the gears are a must.
    There was a lot of discussion of having to re-gear on the big tires, its all true. :thumbsup:
    Just my 2 cents.
    equin, Jsena, dcsleeper408 and 2 others like this.
  2. Jun 2, 2017 at 9:15 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I saw a definite power loss going to 35s. MPG is whatever.
    37s with 4.88s will get you slightly better than 4.30 and 32" tires. I will definitely regear when I do 37s. It will be nice to get back to stock range
  3. Jun 2, 2017 at 9:25 AM
    TheBeast The Beach
    re-gear necessary when switching to 35" or 315/70 ? thinking of upgrading my 33"
    Jsena likes this.
  4. Jun 2, 2017 at 9:27 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I'm getting my 4.88s and limited slip done in two weeks. I'll let you know how it pulls after with my 37"s.
    Jsena and JTP[OP] like this.
  5. Jun 2, 2017 at 9:28 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Its not a necessity. Just depends on if you are willing to deal with the small loss or not
  6. Jun 2, 2017 at 9:40 AM
    JTP
    The Big Black Moose
    Yea I am now wondering if this might help running 35's too.
    My truck came with 35's but I never pulled anything with it but I could tell at highway speed not pulling anything the difference between the 35's and 37's.
    As mentioned you can run without the 4:88's but its going to be WAY BETTER with them.
    Jsena likes this.
  7. Jun 2, 2017 at 10:35 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I'm not towing but carrying a load intermittently and have recently noticed what feels like gears sticking with 35s, only 10,000 miles, and an empty bed.
    would you be able to notice gears sticking or slipping with 35's?
    I don't really care about a little power loss, nor MPGs. I just don't want to do damage when i'm loaded down, nor when i'm not
    Lordaca, Jsena and dcsleeper408 like this.
  8. Jun 2, 2017 at 10:42 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm not sure what you mean by sticking or slipping. Mine shifts normally, it just felt like I lost a little power when I switched to 35s
    Jsena, JTP[OP] and dcsleeper408 like this.
  9. Jun 2, 2017 at 10:44 AM
    JTP
    The Big Black Moose
    Your in a completely bad situation if you are getting "sticking or slipping gears". I don't think that the "gears" that we are talking about changing that are taking power from the drive shafts and sending it out sideways through the axels to the wheels through the differentials are what your having an issue with.
    There is no way that they could 'slip' or 'stick' unless the gears are somehow damaged.
    Your transmission might be down shifting more often at higher speeds when climbing a hill running bigger tires but I doubt seriously that you have a gear issue.
  10. Jun 2, 2017 at 10:47 AM
    JTP
    The Big Black Moose
    Its is sounding to me that even 35" tires could use 4:88 gears. I learned that the newer Tundra's come with 4:30's probably to take bigger tires and turn better at highway speeds with a load.
    My truck came with 4:30's as apart of the tow package.
    No tow package comes with 4:10 gears.
    Jsena likes this.
  11. Jun 2, 2017 at 10:48 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    What do you mean by sticking or slipping?
    JTP[OP] likes this.
  12. Jun 2, 2017 at 10:53 AM
    JTP
    The Big Black Moose
    Slipping or sticking GEARS comes with loud bangs, grinding noises, truck feeling like its getting kicked in the balls and jumping and ALL KINDS of other weird "oh shit" somethings really fucked up and its going to be expensive feelings AND the truck probably won't roll forward or backward for long.
    Jsena likes this.
  13. Jun 2, 2017 at 11:19 AM
    Eclipsed & Floating
    Voluptuous Whitey
    It's not that
    It's like they are holding longer when not in tow/haul mode than expected, but normally when going uphill. I live in the high rockies so no avoiding hills here. It could be an anomaly and i only noticed it yesterday. I'll keep an eye out. Probably just my brain playing tricks
  14. Jun 2, 2017 at 11:21 AM
    JTP
    The Big Black Moose
    If you went up to 35's the transmission is waiting "holding" longer to shift.
    Jsena likes this.
  15. Jun 2, 2017 at 11:22 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I've been on 35s for 4 months though...never noticed it before yesterday
    Jsena and JTP[QUOTED][OP] like this.
  16. Jun 2, 2017 at 11:24 AM
    JTP
    The Big Black Moose
    Check transmission fluid level (and for leaks)
  17. Jun 2, 2017 at 9:51 PM
    zackbremer
    zackbremer New Member
    Da Z
    https://www.tundras.com/threads/4-30-gears-front-and-rear.10468/
    i dont think toyota changed their drivetrain for the newer gens? do you have a link to this info, just trying to confirm. 2017 should sstill be 4.10(non tow package) 4.30s for tow package..this is for the 5.7v8 not sure about the 4.7L
    Jsena and osidepunker like this.
  18. Jun 2, 2017 at 9:58 PM
    JTP
    The Big Black Moose
    2017 5.7 comes with 4:30 gears
    Jsena likes this.
  19. Jun 2, 2017 at 10:12 PM
    zackbremer
    Da Z
    ^^correct, in the post i quoted you typed "4.20" gears i now assume this was a typo
    JTP[OP] likes this.
  20. Jun 2, 2017 at 10:24 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    You'll have to take it to the dealership to get the trans fluid. Our trucks don't have a dipstick.
    JTP[QUOTED][OP] likes this.
  21. Jun 2, 2017 at 10:26 PM
    JTP
    The Big Black Moose
    Didn't know that. Will have to take a look at the book to see how it can be checked.
  22. Jun 12, 2017 at 3:48 PM
    payyourtoll
    payyourtoll New Member
    Tampa, FL
    what brand 4.88s? And which master install kit did you choose?
    Jsena likes this.
  23. Jun 12, 2017 at 4:25 PM
    1UPPER
    TEXAS
    Flux capacitor!
  24. Jun 12, 2017 at 4:57 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Pretty much every Tundra 2010+ (with the 5.7") is all standard with the tow package. 35's do rob a little bit of the low end torque, but unless you are hauling and pulling heavy loads it won't affect performance. In my case, it helped me not spin the tires off the line as bad. :burnrubber:
    We use the Nitro gears here and typically either do the Auburn Limited Slip or an ARB air locker.
    Jsena likes this.
  25. Jun 12, 2017 at 5:03 PM
    sdhq_offroad
    GILBERT, AZ
    I don't mean to jack the thread, but it is somewhat gear related. We built this Single cab with a custom 5.5" bed. Supercharger with AEM water methanol injected.
    Performance
    Drivetrain
    • Level Ten Valvebody
    • Level Ten Torque Converter
    • 4.88 Gears Front And Rear
    • Auburn Limited Slip Rear Differential
    Wheels & Tires
    2014-tundra-single-cab-short-bed-frame-chop-icon-vehicle-dynamics-method-wheels-toyo-mt.jpg
    equin, Geo4x4, Mountun Goat and 5 others like this.
  26. Jun 12, 2017 at 5:07 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Which shocks and suspension did you guys go with?
  27. Jun 12, 2017 at 5:10 PM
    sdhq_offroad
    GILBERT, AZ
    Just Icon Coilovers/Upper arm. 2.5" rear piggybacks. No add-a-pack.
  28. Jun 12, 2017 at 5:14 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Did you install the Icon bump stops?
  29. Jun 12, 2017 at 5:22 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    What does an lsd do and why would I want one after regearing?
  30. Jun 12, 2017 at 5:32 PM
    TheBeast The Beach
    that looks like a very capable off road platform
