36mm 12 point nut on axle?
Discussion in 'Wheels & Tires' started by FREEK, Mar 18, 2025.
  1. Mar 18, 2025 at 9:09 AM
    FREEK
    FREEK [OP] New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    2019 Limited Crewmax 4x4
    Pulling the D/F axle to replace inner CV joint boot. Pulled the bearing dust cap to find a 12 Point 36mm(?) spindle nut, I was expecting a 6 point.
    All the 36mm sockets I find locally are typical hi-torque 6 point sockets. HF has a 36mm box wrench, dunno if a wrench will slip on the nut with the dust seal lip in the way?
    Suggesions???
    THANK GAWD FOR YOU GUYS WHOM HAVE GONE THERE BEFORE ME!!!!
  2. Mar 18, 2025 at 9:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Amazon next day delivery?
  3. Mar 18, 2025 at 9:15 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I rented one from parts store. Try autozone, orielly, etc
    1lowlife likes this.
  4. Mar 18, 2025 at 9:17 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Is that 36mm 12 point nut normal for these trucks (or is it an aftermarket addition)? Asking so I can be prepared for any future front end work that may require CV removal
  5. Mar 18, 2025 at 9:20 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I pulled mine to do the ECGS bushing and since I was anticipating only doing it once I went with a cheap Amazon set with multiple sockets for the same price I could buy a single for locally.
    https://www.amazon.com/EMENTOL-Spin...2314420&sprefix=12+point+,aps,155&sr=8-8&th=1
    I don't remember the exact size I used but it was in this set, and I have also ended up using one of the smaller ones on my SPC upper control arm nut so I think it worked out fine for me.
  6. Mar 18, 2025 at 9:21 AM
    APalmTree
    Brandon
    SW Washington
    Yes the 12 point is the correct stock part
    FREEK[OP] and Red&03Taco[QUOTED] like this.
  7. Mar 18, 2025 at 9:24 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Think this is it.
  8. Mar 18, 2025 at 9:29 AM
    FREEK
    Darren
    Olathe, KS
    O’Reilly’s had. 12pt 36mm for sale at $23.00.
    Their rental was a 6pt.
  9. Mar 18, 2025 at 9:33 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Been a few years and my memory ain’t so good anymore but I’m almost definitely it’s a 39mm. Unless yours is aftermarket.
  10. Mar 18, 2025 at 9:40 AM
    APalmTree
    Brandon
    SW Washington
    Also can't remember but I will check my sockets later today and I will be able to tell which one I used :rofl:
    In the meantime 39mm seems to be correct
    https://www.tundras.com/threads/need-help-axle-nut-size.17197/
    joonbug[QUOTED] likes this.
  11. Mar 18, 2025 at 10:09 AM
    FREEK
    Darren
    Olathe, KS
    Ignore the videos.
    Well, IT AIN’T NO 36mm 12pt.!!!!
    It’s larger. I am guessing a 38mm 12pt.
    I am headed to NAPA for the CV clamp tool, hopefully they’ll have one. If not, back to O’Reilly’s!
    A “simple” 3.5” Level Kit has become one issue after another… ARgHhhh.
    NOTE TO SELF:
    Pay the measly $800 next time for the shop installation!!!
  12. Mar 18, 2025 at 10:20 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    39mm is correct.
