35x12.50R18 offroad
Discussion in 'Wheels & Tires' started by jordanpop1, Aug 7, 2018.
  1. Aug 7, 2018 at 11:45 AM
    jordanpop1
    jordanpop1 [OP] New Member
    hey folks, bout to order my 2019 TRD Pro and have a tire question.
    I’m ordering Fuel Vector 18x9 with a +20mm offset and 35x12.50 Nitto ridge grapplers.
    I understand that with trimming plastic and mud flap removal this will work just fine.
    My question is for offroad. Anyone running this setup on stock pro suspension? How’s it do Offroad?
    Edit: I also may be using the icon Rebounds with 25mm offset and 17” instead of 18”.
  2. Aug 7, 2018 at 11:58 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I don’t have that setup myself, but @TRON ran that size on PRO shocks for awhile. @boardude ran 295/70’s on the same setup, not too far off from a true 35.
    TRON and boardude like this.
  3. Aug 7, 2018 at 12:10 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You may need a little more offset with the 35s otherwise you'll probably be trimming quite a bit. I ran +12 offset wheels with my 295s and still had to trim.
    May want to look into the coach builder shims to help too
  4. Aug 7, 2018 at 12:23 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Might want to measure the brakes if your'e thinking of dropping to 17". 18" is tight enough on mine that I wouldn't be able to run 17".
  5. Aug 7, 2018 at 12:45 PM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    do you have an aftermarket brake setup? My understanding 17's will fit over stock brakes
  6. Aug 7, 2018 at 12:55 PM
    jordanpop1
    Maybe a 315/70r18 or 17 would be a safer bet. I want to beef it up as much as possible, but it’s going to get some serious use offroad
  7. Aug 7, 2018 at 12:56 PM
    jordanpop1
    17 wheel will work
  8. Aug 7, 2018 at 1:06 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I'm running a spare set of 295-70-18 on my truck w/ Method Roost 18x9 +18 ( version 1 ) and wheeled it this past weekend with @Erichudgins with NO issue and I'm 2wd. I just have a CMC on the front on Fox C/O's, etc.
    Erichudgins and TheBeast like this.
  9. Aug 7, 2018 at 1:14 PM
    TheBeast The Beach
    831Tun, dcsleeper408 and joonbug like this.
  10. Aug 7, 2018 at 1:16 PM
    TheBeast The Beach
    295/70 or 305/70 is a good compromise as you can fit a full size spare underneath the bed and you do need a full size spare if doing serious off roading. The 35" will sit in your bed and eat half the space.
    831Tun, jordanpop1[OP] and joonbug like this.
  11. Aug 7, 2018 at 1:18 PM
    jordanpop1
  12. Aug 7, 2018 at 1:25 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    295-70-18 W/ a spacer.... or else its gonna be around 275mm max, no spacer, SKINNY
    831Tun likes this.
  13. Aug 7, 2018 at 1:33 PM
    jordanpop1
    I saw the coach builder. Looks like good stuff. I’m trying really hard to keep everything stock but bumpers, tires, wheels.
  14. Aug 7, 2018 at 1:47 PM
    jordanpop1
    Really what I am after here is who is riding stock TRD pro suspension, 35/12.50r18 on a wheel offset between 20-30. After you have removed the mud flaps and trimmed what plastic necessary are you still rubbing at full bump/full lock?
    Ginsterkev and TRD_Snow like this.
  15. Aug 7, 2018 at 1:53 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    A true 35 will more than likely rub at full lock on the skid plate and the cab mount with those wheels. I'd be in for someone to post up TRUE 35, no cut, trim or removal of the skid plate with pics to prove it.
    TheBeast likes this.
  16. Aug 7, 2018 at 1:57 PM
    jordanpop1
    Right, I’d imagine it would be a total no go at full bump then too. That’s the hairy part. When you are completely compressed and have to turn the wheel.
    So 295/70R18 sounds like a good bet, yeah? With a 20mm offset
  17. Aug 7, 2018 at 2:09 PM
    Sas
    OKC, OK
    No, I have the TSS package though. I don't know if that upgraded brakes or not.
  18. Aug 7, 2018 at 2:09 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Yes sir! Going straight line heck you can throw a 37 on there and say "yay look at me no rubbin!" then when everyone leaves the parking lot, start the turning dance! LOL! You'll be close to you UCA, maybe too close for your personal comfort but yes its been done before on certain tires, less sidewall decor the better.
    Look at this scenario on mine, 37x12.50x17 in the front and worn down 35's in the rear.
  19. Aug 7, 2018 at 11:54 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    How much lift did you put on your truck and how much trimming?
  20. Aug 8, 2018 at 12:43 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    I run LT285/70R-18 Nitto Exo Grapplers on OE wheels with no problems. You could probably get a LT285/75R-18 to fit on stock wheels.
    TheBeast and zcarpenter92 like this.
  21. Aug 8, 2018 at 6:47 AM
    Rica25
    Ricardo
    Tulare
    I have 2.7 inch lift on front and 1 inch on rear running 295 70 18 nitto ridge grapplers with 12+ offset I had to do the BMC and also trimming but the truck looks good now
    TheBeast, zcarpenter92 and Silv333 like this.
  22. Aug 8, 2018 at 6:53 AM
    JRPro
    JRPro Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    Running 325/65r18 +12 offset with the coachbuilder kit. Still have to do the BMC, and had to massage the front bumper liner even after the spacer kit. Took it out, flexed it pretty good, had to go back and work the bumper liner over again. Anything is possible with the right tools!
    TundraTRD08, Big J, G10dra and 2 others like this.
  23. Aug 8, 2018 at 8:00 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    that's ultimately my concern with 35's. Full compression and turning. I think i'm going to make the same move as you and go with 295/70's
  24. Aug 8, 2018 at 10:41 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I like that front brush guard where did you get that.
  25. Aug 8, 2018 at 10:56 AM
    JRPro
    Rich
    Austin, TX
    Thanks. It’s the Aries Advantedge. Took the plate off the front and had it sprayed with bedliner.
  26. Aug 8, 2018 at 12:43 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    305/70r17. (34x12?) Stock pro suspension. RW wheels 17x8 +50 offset. Just removed the front flaps. Not sure If I even needed to.
    35's will fit easy.
    equin, Rica25 and TheBeast like this.
  27. Jan 8, 2019 at 10:23 AM
    TRD_Snow
    TRD_Snow New Member
    Odi
    16 pro
    I’m running that exact setup you looking for
    Pro suspension, 35/12.5r18 +25. No issues.
    Maybe because of after market bumper. But as far as fit? It fits.
  28. Jan 10, 2019 at 7:59 AM
    DiegoC
    DiegoC New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    What did you use? im using a heat gun and an angle grinder. but my tires are still ripping that front bumper liner to shreds. its all tore up but im on 35s so ill probably have to do a bmc huh?
  29. Jan 10, 2019 at 7:47 PM
    jordanpop1
    I don’t see how 35s without a BMC is even feasible. I’m on 295/70r18 with +20 offset with a 3/2 and I’m close close. I need to do it actually. Took it off roading last week and I definitely hit it a couple times. On road is fine with the right alignment
    Rica25 likes this.
  30. Jan 11, 2019 at 5:15 AM
    DiegoC
    Diego
    I’m on a +25 offset. I cut some of the plastic molded a tiny bit with an angle grinder. I can do one full rotation both ways without rub. It looks like I’ll have to do a little chop. I
    Don’t have time until next week. So I guess I gotta live with the rub for a few days. Lol
    Rica25 likes this.
