35x12.5/18 before getting lift?
Discussion in 'Wheels & Tires' started by 462Loadtoad, Feb 8, 2017.
  1. Feb 8, 2017 at 1:15 PM
    462Loadtoad
    462Loadtoad [OP] New Member
    Surprise, AZ
    2012 Rock Warrior CrewMax 4x4 5.7
    Upgrade plans are: Zone 5" Suspension Lift Method Double Standard Rims 18x9 Goodyear Duratrac 35x12.5/18's N-Fab W2W Nerf Bars Smittybilt M1 Front Bumper Smittybilt M1Rear Bumper
    I'm needing some insight/guidance. I have a '12 RW that I'm putting wheels/tires on and eventually a 6"lift. I want to go with 35x12.5/18 tires with 18x9 or 10" rims. My question is, will this work on my truck before I get the lift. If so, what is the backspacing/offset I'll need to do it. Unfortunately I can't get everything at one time and I'm gonna need tires soon.
    Thx
  2. Feb 8, 2017 at 1:50 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    im doubting this but ill wait for an expert...
  3. Feb 8, 2017 at 2:15 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Seems to me that's a pretty wide set up, might have issues with hitting the UCA. Trimming will have to happen at the least.
  4. Feb 8, 2017 at 2:18 PM
    Ardnut
    Ardnut New Member
    TX
    http://www.tundratalk.net/forums/will-fit/460114-not-leveled-35s.html
  5. Feb 8, 2017 at 2:31 PM
    462Loadtoad
    Surprise, AZ
    Thx for the reply. Those are the tires I plan on getting. Good to know they will fit just fine!
  6. Feb 8, 2017 at 3:32 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    In theory, yes you can put them on but you wont get a quarter turn out of em. You're gonna hit fenders, bumper, skid plate, etc
  7. Feb 8, 2017 at 3:33 PM
    joem1cha3l
    Albany, NY
    Umm....
  8. Feb 8, 2017 at 3:46 PM
    Carlos@Camburg
    Carlos@Camburg Carlos @ Camburg Vendor
    Carlos
    Huntington Beach
    2015 Tundra DC
    Camburg UCA Bilstein 6112 KMC Wheels General Tires Rigid Lights
    You cannot run a 35" tire with your stock truck.
  9. Feb 8, 2017 at 4:21 PM
    462Loadtoad
    Surprise, AZ
    If this won't work then how did the guy in the thread that Ardnut pasted in his response get it to work??? Am I missing something there?
  10. Feb 8, 2017 at 4:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Looks like that guy did it on RW wheels which I believe are +50 offset. That would help a little on rubbing but still can't imagine it would fit. And he's probably rubbing on his UCAs and doesn't even know it.
  11. Feb 8, 2017 at 4:45 PM
    462Loadtoad
    Surprise, AZ
    I'd like to run the 17" RW wheels I have but every 6" lift I read about says basically an 18" is the min diameter. That's what got me going down this road.
  12. Feb 8, 2017 at 4:56 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    basically most 6in kits have knuckles that alter wheel fitment(backspace and offset) the material is thicker for rigidity and won't allow a 17 inch wheel to mount on it. That's why you are seeing it call for 18+ sizes with at minimum 5in backspace which is generally a 0 offset give or take a few millimeters. There's a reason why that post is probably showing the wheels straight ahead:rolleyes:
    462Loadtoad[OP] likes this.
  13. Feb 8, 2017 at 5:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So I just read that entire thread and that guy did get them in there. But it wasn't a true 35. With it being 34.5" and an AT tire with the +50 offset, I still have some doubt, but I can see it being possible.
  14. Feb 8, 2017 at 5:18 PM
    462Loadtoad
    Surprise, AZ
    Yeah, after reading everyone's responses I'm gonna have to change my game plan...
  15. Feb 8, 2017 at 5:19 PM
    462Loadtoad
    Surprise, AZ
    Thanks for everyone's guidance/insight!!!!
  16. Feb 8, 2017 at 5:20 PM
    Carlos@Camburg
    Carlos
    Huntington Beach
    2015 Tundra DC
    The offset of that wheel had everything to do with it. Most lifts have ucas that require certain offsets on wheels. If you plan on running the rock warrior wheel then you might be ok with certain brand tires. Good luck!
    joem1cha3l likes this.
  17. Feb 8, 2017 at 5:21 PM
    Carlos@Camburg
    Carlos
    Huntington Beach
    2015 Tundra DC
    That was a lot of "certain"
  18. Feb 8, 2017 at 5:28 PM
    462Loadtoad
    Surprise, AZ
    As of right now I'm going with the 35x12.5/18 BFG KO2's. And for wheels it's a toss up between the black Method double standard and the Fuel Hostage III in a gun metal grey with black outer ring.
  19. Feb 8, 2017 at 7:22 PM
    Ardnut
    Ardnut New Member
    TX
    Zero offset?
    As stated, those bfg's measure out to 34.5", that coupled with offset will be the biggest factor as others have said. If you look at the pictures he has clearance from the body mount, UCa, and even mudflaps. and said he rubs at full lock "a little". Depending on tire and wheel offset, it's obviously possible as you saw in that thread with his picture at full lock. If you take your measurements and know the tire wheel combo you can see for yourself.
    With that said, this is coming from the guy running 35x12.50r17 nitto MT's, rock warrior wheels, 1.25" wheel spacers, and a 3/1 kit and will soon be running 37's with a BMC. So I am all for the stuffed look. Either way, take your measurements and you'll figure it out.
  20. Feb 8, 2017 at 7:52 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    OP, the Method will come in a 18x9 +18 offset (depending if you can get those as they have released a new fitment) which at that point if you run a 35x12.50x18 KO2 on that with 3in lift whether its a 3/1 or coilovers or 6in; expect to remove the mud flap on the back side of the front fender well, remove the bottom flap on the front bumper, trim/push back the front lower liner, and shave/remove the skid plate if you have one on there. You will need a body chop which is minimal and doesn't affect the structure of the frame. Im running the Method Roost on my truck with a 305/70/18 (35in tire) on Coilovers and did this mod(s) to clear at every angle and any amount of flex. You won't need spacers as the wheels you are referencing have either a 5.75 BS (Method) or the Hostage which is about 5BS depending if you get the dual drilled pattern as sometimes they share a Dodge Ram 1500 bolt patten, 5x5.5 which if that's the case your offset is going to be either -6, 0, +1, or +20. Keep in mind if you choose the Hostage with the lower offset measurements, know that you may have more to trim with the 35 on there. I'd encourage you to consider a UCA to help dial in the alignment so you won't prematurely wear out the tires. You're gonna need that to get some play in the caster adjusting.
    You will benefit with the Hostages on the truck if you do the 6in lift because if you want the wheels to peek out a bit from the body line; the wheel should offer different offsets to achieve the look. However depending on which kit you choose, going with Methods will be too close for comfort due to the knuckles.
    Look at the current offerings for our bolt pattern from Method: 18x9 +25 (6inBS)
    http://www.methodracewheels.com/collections/all/products/double-standard-black
    I hope this helps you out
