35s on a 1st gen
Discussion in 'General Tundra Discussion' started by Rudolph_05tundra, Mar 23, 2020.
  1. Mar 23, 2020 at 4:05 PM
    Rudolph_05tundra
    Rudolph_05tundra [OP] New Member
    Seth
    Kentucky
    2005 Toyota Tundra DC SR5
    Alright everybody, so I have been thinking about some future plans for my build, and need some help keeping these realistic and in perspective. Keep in mind that I don't mind cutting or buying some high quality wheel spacers for clearance.
    1. If I had (roughly) 4.25" of lift up front and 2.5-3" in back, would I will be able to fit 315/75/16 tires?
    2. With a tire size like that, I would plan on regearing and add a rear locker (I'm only a 2wd) what would be the best gear ratio for this application? Any suggestions in this area are much appreciated!
  2. Mar 23, 2020 at 5:20 PM
    Sunnier
    Sunny
    San Diego, CA
    I don’t think so. Unless you want to really transform the truck, or maybe do a spacer lift, but if you plan to wheel it, I wouldn’t
    I have long travel in front, so my true 33’s clear without a chop, but I rely on an ace alignment tech to push my caster all the way forward. I have Bora spacers to make the clearance in the back work, but am gonna have to add bedsides because moving the wheels out to clear made the tires stuff in the stock bedsides. Anyway, short answer: go ahead(!) :p because I’m excited to see you do it, but no, it’s not something many have done.
    I skipped answering you on hearing because that’s well covered; a search for rehearing for 35’s will produce a lot of info. I’d suggest you not pre-but gears though, until you verify you can fit 35’s comfortably. Do you have a buddy with 35’s on a 6-lug wheel that will let you borrow to test fit, so you don’t lay out cash ‘til you work out the details?
  3. Mar 23, 2020 at 5:38 PM
    Rudolph_05tundra
    Seth
    Kentucky
    Thanks! I just did 2.5" and surprisingly fit 33s with no trimming at all. But now that's done and been on for a couple weeks, I would like to go bigger. Im sure I could find someone close with a 35 I could test fit. I need to find some UCAs before I lift it again, so I will have to save for a while.
    Sunnier[QUOTED] likes this.
  4. May 31, 2020 at 10:12 PM
    02_actundra
    02_actundra New Member
    Level 35s
    Level and 35s
  5. Jun 1, 2020 at 3:31 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    You need to go with 6 inch “race car dynamics” lift for that side tire with no rub. I had 3 inch sway a way coilovers and the tires rub on the frame. I have 315/75/16 hankook tires with no rub .i really like the RCD lift kit. Comes with all parts . Check it out. I got the kit without the Bilstein coilovers. I bought the icon coilovers that were made for this kit instead.
  6. Jun 1, 2020 at 6:17 AM
    02_actundra
    Level 35s
    I had to trim a little bit and now I don’t rub
  7. Jun 1, 2020 at 6:22 AM
    Rudolph_05tundra
    Seth
    Kentucky
    Looks good! What all did you trim and are you running any kind of wheel spacers to avoid frame rub?
  8. Jun 1, 2020 at 4:25 PM
    02_actundra
    Level 35s
    2000TundraTRDPRO likes this.
  9. May 10, 2021 at 7:27 AM
    2000TundraTRDPRO
    2000TundraTRDPRO New Member
    Desi
    Honolulu, Hawaii
    2000 tundra limited 4x4 4.7 V8
    So far 3” leveling kit 265/70/17 Firestone Destination MT2 Tailgate reverse camera 7” double din deck 2020 wood grain steering wheel Full sound system 2020 TUNDRA OEM Alarm FOR NOW
    Bro can you post a pic of the area you cut on the lower bumper and lower plastic? I’m cutting mines tomorrow because the 285/70R17 I just put on with 17x9.5 is rubbing... I even went back to a 265/70R17 and because of the 17x9 it still rubs ands it’s not even full lock... Looks to me like 1.5 - 2 inches should do it... Just the lower bumper and plastic guard under it..
  10. Jun 13, 2023 at 2:51 PM
    WaTrout88
    WaTrout88 Toyota Family
    Ben
    Spokane, WA
    1978 FJ40, 2002 Tundra TRD, 2018 Tundra
    2002 Toyota Tundra - Billy's 5100 2nd Notch, 285/75/16 OEM Wheels + 1.5" Spacers, Archive Garage HD Leaf Springs, AG Bump Stops, Freedom Offroad UCAs, ARB Coil Springs 2887
    Man I definitely want to do this to my 02 tundra twinzy. Looks great!
  11. Nov 19, 2023 at 1:46 PM
    tatum3574
    tatum3574 New Member
    2002 Toyota Tundra
    I have a 02 Tundra 2WD and want to put a reat locker too. has anyone successfully done it yet? Also i Want to run 35’s, is it possible just with a leveling kit? i dont want to lift the truck up much
  12. Nov 19, 2023 at 1:47 PM
    tatum3574
    2002 Toyota Tundra
    What Leveling kit did you use?
