35's on 3 inch boss lift
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dustydirt19, Sep 21, 2016.
  1. Sep 21, 2016 at 11:34 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Anyone running 35's on a boss 3"lift or any 3" lift? Any trimming? Also what offset are you running with your rims? Looking to be flush or a little outside bushwacker pocket fender flares. I was thinking +18. Any pics would help
  2. Sep 21, 2016 at 12:17 PM
    Rick4x421
    Rick4x421 New Member
    2012Blacktrim/pyrite
    Yes, Toytec 3" boss kit, 1" rear block, 35"x 12.5 x 20 Toyo open country, I trimmed each side of skid plate 1.5", took 20 minutes, not a big deal.
    RW
  3. Sep 21, 2016 at 12:32 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  4. Sep 21, 2016 at 12:47 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Take a look at @Sean266 build page. He has the boss kit with 35's.
    T-Rex266 likes this.
  5. Sep 21, 2016 at 1:08 PM
  6. Sep 21, 2016 at 4:30 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Boss 3.25"/1" with 34.5" with an overall offset of +18.24. Trimmed front plastic and skid plate. Did not have to do the cab mount chop.
    2cID, TheBeast and T-Rex266 like this.
  7. Sep 22, 2016 at 8:44 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Sean, your truck always does weird things to me below the waist haha
    zcarpenter92 and T-Rex266 like this.
  8. Sep 22, 2016 at 9:44 AM
  9. Sep 23, 2016 at 12:32 PM
    Dustydirt19
    Dustin
    Duluth, MN
    For the time being when i do my boss 3" lift would I be able to run 295 70 18 on my stock rims and swap the rims later? Just trying not to spend 5k at once.
  10. Sep 23, 2016 at 2:47 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That would be a little close to the UCA, I would get some wheel spacers just to offset that problem (pun intended) and sell them off later.
    I personally chose to get a smaller tire size (275/70r18) until I got wheels with a lower offset. It gets the job done but they do look a tad bit small on the 3/1.
    Hindsight is always 20/20
  11. Sep 23, 2016 at 5:46 PM
    csuviper
    Broomfield, CO
    Wheel spacers will run you about $250 for all 4. That would be cheaper than going with wheels. You could sell them after you get wheels and not loose too much on them.
    Since stock are +60mm they will be very tight to the UCA if 11.5" wide or wider
  12. Sep 24, 2016 at 3:15 AM
    Dustydirt19
    Dustin
    Duluth, MN
    What's a good brand?
  13. Sep 24, 2016 at 8:02 AM
    Icon
    TC
    SPC (decent)
    Edit: thought he meant UCA. Derp a derp
  14. Sep 24, 2016 at 8:20 AM
    csuviper
    Broomfield, CO
    I believe your asking about brand of wheel spacers. I went with spidertrax as they are on of the top brands and manufactured in Colorado. Haven't had any issues at all.
  15. Sep 24, 2016 at 9:20 AM
    Dustydirt19
    Dustin
    Duluth, MN
    1.25 spidertrax spacer would push a 295 70 18 tire out far enough then til I'd get the bling for new rims
  16. Sep 24, 2016 at 10:47 AM
    csuviper
    Broomfield, CO
  17. Sep 24, 2016 at 2:28 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Thanks. I really appreciate all your help. Honestly
  18. Sep 24, 2016 at 2:28 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Go packers
  19. Sep 24, 2016 at 4:39 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    If u don't want to go the full 1.25" with spider trax, look at Bora. They make great spacers as well in smaller thicknesses
  20. Oct 4, 2016 at 8:09 PM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    That truck sits perfect.
    T-Rex266[QUOTED] likes this.
  21. Oct 4, 2016 at 8:22 PM
    csuviper
    Broomfield, CO
    Sean's truck is pretty perfect actually
    :jellydance:
  22. Oct 6, 2016 at 11:31 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Did you have any of the driver side lean with the boss setup? Just wondering if I should get shims when I order my lift. If so how many should I get?
  23. Oct 6, 2016 at 11:43 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    The BOSS system is adjustable so no need
  24. Oct 6, 2016 at 11:49 AM
    Dustydirt19
    Dustin
    Duluth, MN
    That's what I thought but someone else said on a different forum they had to add shims and I trust the guys knowledge on this forum so I wanted to make sure
  25. Oct 6, 2016 at 11:57 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I don't see a problem with doing that but why spend the extra cash?
  26. Oct 6, 2016 at 12:12 PM
    csuviper
    Broomfield, CO
    You won't be able to feel any difference with 1/4"- 1/2" adjustment on the Coilovers. No need for an added shim.
  27. Oct 6, 2016 at 3:12 PM
    ^^^ yep
  28. Apr 3, 2017 at 11:29 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    sorry about waking an old thread, but I'm in search of a few answers. I have a 6" lift right now. With 35's and I think the wheels are +30 I'm not 100% sure. I'm thinking about getting and ome 3" lift and keeping the wheels n tires for now. Some guy at 4wp said they can't cut enough out of the cab mount to make my wheels fit, but I beg the differ.
  29. Apr 3, 2017 at 12:24 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I got 35s on 3" lift. My offset is +18 tho. I think your sit further in with +30 so I'm not sure exactly. I know that I had to cut the cab mount and remove the liner avoid all hitting. I'm sure someone will chime in. Here is mine with my set up for reference
    T-Rex266 and J4RR3N4 like this.
  30. Apr 3, 2017 at 12:28 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    That looks perfect! I'm thinking I need some wheels spacers till I get new wheels.
    TXMiamiFan[QUOTED] likes this.
