35's.. And the Speedo is Close Generous GPS? Luck? or did the dealer adjust?
Discussion in 'Wheels & Tires' started by niscur38, Feb 21, 2019.
  1. Feb 21, 2019 at 4:57 AM
    niscur38
    niscur38 [OP] New Member
    So after all the calculators and comparison going from the 275/55/20 BS Alenzas (31.89") to 35x11.5/20 Nitto TG G2's (34.53") I was expecting the speedo to be off about 8%. Finally got around to using an ipotato app to check speed via GPS this am on the drop off to school.
    It seemed that the GPS and the Speedo were in agreement the whole way. Only got up to 60 in the short drive but it appeared to be about dead nuts where I would have expected the GPS to show a faster speed vs the speedo starting at about 40-45mph.
    Can the dealer adjust tire size etc via tech stream? I had them do the mounting/balance/alignment after the lift. So, did I get lucky, should I not trust the app, or wait until I take it to work and start hitting 70-80?
  2. Feb 21, 2019 at 5:36 AM
    I ran 275/70/18's and mine was off. I just recently went to the 285/70 and it is dead on with the GPS and I did not make any adjustments with the hyper tech calibrator. It really varies from tire to tire.
  3. Feb 21, 2019 at 5:41 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Your circumference math is correct at an approx. 8% difference. I would have expected a difference to show up on the speedo.
    But the answer to your query is "yes" the dealer can adjust the internal MPH calculation parameters for the new conditions.
  4. Feb 21, 2019 at 7:39 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Only with an inline hypertech. Cost $200 so I doubt it if he didn’t pay for it. You cannot program through the obd port. Or at least that’s what I was told. Hypertech needs to stay behind dash.
  5. Feb 21, 2019 at 8:14 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Your math is correct. It should be off. I used to have a damn picture of my corrected speedometer with my bullydog so people could see the difference. I can't find it and now my stupid hdmi cable is broken.
    The bullydog won't correct. I have the hypertech for that. The bullydog just gets its speed input prior to the unit.
    Don't know anything about that Techstream software stuff.
  6. Feb 21, 2019 at 8:22 PM
    neirbot
    neirbot New Member
    I'm only off by 1-2% with my 34's. I thought it would be more. Not enough to worry about.
  7. Feb 25, 2019 at 4:01 AM
    niscur38
    Just updating this...speedo was off by about 2mph all the way to work this am. Everything from about 60 and up was off by about 2mph.
    Set the CC at 78 and the GPS was showing 80.
  8. Feb 25, 2019 at 5:43 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    I went from 275/55/20 to 295/55/20 and I expected the same thing... the speedometer to be off by a certain percentage. However, when drove with my garmin GPS, I verified that the speedometer was actually dead-on accurate with the new tire size. so that means that the speedometer was showing the incorrect speed with the original tire size.
  9. Feb 28, 2019 at 10:35 AM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    Do you have any pictures of your truck with the 35x11.50r20s? The price difference between the 11.50 and 12.50 is a few hundred bucks and now I’m considering those.
  10. Feb 28, 2019 at 1:30 PM
    niscur38
    Its up there in the wheels and tire thread that pinned at the top.
  11. Feb 28, 2019 at 1:38 PM
    SoCalTundy
    Would appreciate the link. Don’t know what thread you’re referring to.
  12. Feb 28, 2019 at 2:30 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    On my 2019, I went from 275/65R18 to 295/70R18 and the speedo vs my iphone GPS has me within 2mph at 75. I expected it to be a lot worse.
  13. Mar 1, 2019 at 3:26 AM
    niscur38
