35s and no cutting?
Discussion in 'Wheels & Tires' started by TundraBot, Feb 14, 2021.
  1. Feb 14, 2021 at 5:09 AM
    TundraBot
    TundraBot [OP] New Member
    2020 Black Tundra TRD OffRoad CrewMax
    Toyota tonneau cover (regrettably) N-Fab Podium steps Icon 2.5 IR front coilovers Icon 2.5 piggyback rear struts 1” blocks in rear with front diff drop 18x8.5 +30 offset American Racing rims 35x11.5 Falken Wildpeaks
    Hey everyone, I’ve read through a lot of different discussions on this forum and the one thing that confuses me is whether I’ll need to make body mount cuts for 35s with a 3.5” lift. I’ve see some folks say no cuts other than some front mud flap trimming/removal and others say cutting and welding will be needed.
    My plan is to run a Rough Country 3.5” lift https://www.roughcountry.com/toyota...=2020-toyota-tundra-4wd-740669&sid=NsIfx6xPzP
    Add 35x12.5R18, likely Falken Wildpeak and run them on 18x8.5 rims with a +30mm offset. Can I do this without cutting and welding the body mounts? Oh yeah, I have 2020 TRD Off-Road /SR5 CM.
    Thanks
  2. Feb 14, 2021 at 5:44 AM
    Elduder
    Elduder New Member
    Despite what people say over and over, 3" lifts don't make a difference. The wheel and tire still make the same travel upward. If you plan to take it off road it would rub with a lift still.
    The way to prevent it is tire choice, offset, and potentially caster.
    A 285/75r18 will be a 35 less likely to rub than a 35x12.5
    +30 is a good offset, the most popular for reducing rub seems to be +25 on a 8.5" wide wheel.
    Caster can help with the cab rub, but there will almost certainly be rub on the front fender plastic. Adding caster will make it worse. Good thing with the fender plastic on the front bumper is you can just remove it. If youre concerned with removing it youll have to trim it or push it forward. Another option is bumper spacers.
    Saltyhero13, Sunnier, joonbug and 4 others like this.
  3. Feb 14, 2021 at 6:16 AM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I just got 285/75/18..I haven’t installed em yet. I have 3”. with +30 (5.75+ backspacing?) and depending on your UCA’s, you SHOULD be fine. If you rub when you wheel it’ll be the liner or skid plate, both can be modified.l easily. If you need a CMC it’s only $50 for SDHQ plates and a shop won’t cost but maybe 150-200. 285/75 will be 35” and an inch narrower. Amazon has em for $258 each no shipping. My local discount tire price matched, It’s a hell of a deal..
    Falken Wildpeak A/T3W all_ Terrain Radial Tire-LT285/75R18 129R https://www.amazon.com/dp/B07JM9TYNW/ref=cm_sw_r_cp_api_glt_fabc_QDWMRB7K63744T0TARW5
  4. Feb 14, 2021 at 6:38 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Every truck is different, if you aren't totally prepared to do the body mount chop then drop down to 33's. If you go in to it saying, I'm gonna try to avoid BMC, but if I have to do it then so be it, go for 35's
  5. Feb 14, 2021 at 6:44 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    This!
    You'll never know until you get it on.
    Play it safe and don't try and put the biggest tire possible in there.
    joseph_womack and TundraBot[OP] like this.
  6. Feb 14, 2021 at 6:45 AM
    Elduder
    Elduder New Member
    FWIW I ran 315/70r17 Mickey T ATZP3s on a stock 19 Pro. Icon Rebounds. Paid for a BMC and turned out to not even need it. Even in reverse I had about a .5-.75" clearance back there.
    I did remove the front fender liner on the bumper.
    BMC rub is something you can wait to see if you need to address. It typically only shows up while reversing, unless you go with a very aggressive stance or something larger than a 35. When it does rub its not something that will immediately cause any damage either.
  7. Feb 14, 2021 at 6:46 AM
    Elduder
    Elduder New Member
  8. Feb 14, 2021 at 6:55 AM
    HighonFirewood
    2019 Tundra
    For reference...here are 33’s on a 3” lift. It’s a funny game to make the space work. But if 35’s concern you find a comfortable 34”. Otherwise I think my truck currently looks silly with 33’s
  9. Feb 15, 2021 at 7:18 AM
    TundraBot
    Thanks everyone for the replies. I think I’m going to avoid the 35s and see what I can do with 33s or 34s even. I definitely want to avoid a BMC. I’ll probably dial down the lift as well from 3.5 to maybe just 2” or so. Thanks again.
    Loose, BravoDeltaRomeo and Elduder like this.
  10. Feb 15, 2021 at 7:37 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    that was my first thought. My Duratracs are 35.1” tall, and I only removed the little mud guards at the front of the wheel well. I’m on stock wheels (and stock UCAs) with no spacers, but I’ve seen guys make these work with different offsets.
    I haven’t taken them on any technical trails yet though. Waiting for warmer weather as we usually camp when we go off roading. If they rub off-road, I will do some cutting.
  11. Feb 15, 2021 at 7:46 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    I have true 35's (Toyo R/Ts) and have NO rubbing at all.
    The secret sauce is listed in my signature. I did push in my inner fender plastic wall a inch on the frontside of the fender. Removed the front backside mud flap.
    And still have the little front aero mud flap on, cause I like it on there.
    That's it.
    O.S.T.
    ShinyConcretE and TundraBot[OP] like this.
  12. Feb 16, 2021 at 8:15 AM
    TundraBot
  13. Feb 16, 2021 at 8:48 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Also look at the manufacturer's specs, most "35" inch tires don't actually measure at "35" Keep it around 34 and you should be fine.
    TundraBot[QUOTED][OP] likes this.
  14. Feb 16, 2021 at 8:51 AM
    TundraBot
    yeah, 285/75 gets pretty close to 35 (34.8ish). I was thinking of going 35x11.5 instead of 35x12.5, but it seems the tire options are more limited at 11.5.
  15. Feb 23, 2021 at 4:37 PM
    HighonFirewood
    2019 Tundra
    I went with 285/75 and it’s 35” OD. And am not even close to needing to cut..helps to have the bumper, but this is on a 3/1 lift. pizza cutters!
  16. Feb 23, 2021 at 5:58 PM
    TundraBot
    Nice bumper, who makes that? Pizza cutters?
  17. Feb 23, 2021 at 6:06 PM
    Loose
    Loose New Member
    2020 Platnium
    These are 295/60 (34 x11.5) on +20 offset. They rub the cab mount but I am gonna try and max my caster before I have to CMC
    joseph_womack and HighonFirewood like this.
  18. Feb 23, 2021 at 6:12 PM
    HighonFirewood
    2019 Tundra
    Tall and skinny pizza cutters style. It’s a thing on here..bumper is Extreme Terrain Barricade HD2. It’s cheap but not cheap. Love it..only $800 shipped and super clean. Really well made and it’s my favorite bumper I’ve seen
  19. Feb 23, 2021 at 6:17 PM
    DWombatz
    DWombatz New Member
    2021 Tundra SR5 Cement 4x4
    4/2 lift, Flowmaster super 10 outlaw exhaust, TRD pro grille, NITTO ridge grappler 295/65/18R and more to come
    I put the exact same lift on my 21 and I'm running 295/70 Nitto ridge grappler v2 on the factory 18's no rub at all and I easily could have went a little bigger I just wasn't interested in getting different wheels yet.
    HighonFirewood likes this.
  20. Feb 23, 2021 at 6:18 PM
    biebs96
    PA
    285/75 will work in your application.
  21. Feb 26, 2021 at 3:28 AM
    Whitewhale
    Whitewhale New Member
    Kyle
    The Berkshires
    16' white limited
    I’m lifted minimal as all hell (front 2.5 if that and rear 1.5 and I’m running true 35s with +25 offset wheels.
    other then a front wheel well liner trim
    And mudflat removal I don’t rub at all.
    go 35s
  22. Feb 26, 2021 at 4:06 AM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    +25 offset and skinnier tires will max your chances. Everyone has slightly different results. My 285 75 17 (34 x 11.2) clear but barely after plastic manipulation. No metal affected. 6112 @1.9 +shim (2.4” lift).
    TundraBot[OP] likes this.
  23. Feb 26, 2021 at 6:55 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    What tire size do you run?
  24. Feb 26, 2021 at 10:25 AM
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    that’s a 35x12.5r 18 on there in the photo on Scs ray10 18x9.5
  25. Feb 26, 2021 at 10:41 AM
    TundraBot
    That’s a nice setup and the exact kind of look I want. I was talking to my mechanic, who’ll be doing the work, and he said he’ll make 35s fit but warned me that a 12.5” wide tire means components will wear out faster due to the larger contact patch of the tire. He said a 285/75R18 still gets you a capable tire, but you won’t be replacing/repairing components (brakes, bearings, etc.) as often. I’ll post a pic once I get everything installed.
    DeesCrewMax and BravoDeltaRomeo like this.
  26. Mar 11, 2021 at 11:18 AM
    TundraBot
    Hey everyone, thanks for the advice. I can’t bring myself to making body/cab mount chops so I’m going with Falken Wildpeak 285/75R18s and I just received my Icon 2.5IR coilovers and 2.5 piggyback rear struts. Tires don’t come in until the end of the month and also waiting on the diff drop kit. Once everything is installed, I’ll post a few pics.
    Thanks again :thumbsup:
    BravoDeltaRomeo likes this.
  27. Mar 11, 2021 at 11:25 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Congrats on the purchase, I've got the stock TRD PRO suspension and am running Falken 285/75/18. No rubbing except when I am on an incline and full turn to the left. I think it is rubbing on the sway bar but haven't confirmed since it is so minimal. About to throw a bumper on her so we'll see if this fixes any issues or makes anything worst.
  28. Mar 11, 2021 at 11:56 AM
    TundraBot
    Nice truck. I was so close to getting that cement colour, but the dealership said I can get black right away or wait 3-4 months for cement or quicksand. I didn’t want to wait.
    YotaBro[QUOTED] likes this.
  29. Mar 11, 2021 at 11:59 AM
    YotaBro
    Calvin
    FL
    Haha, thanks! You can always wrap your truck to that color if you decide so in the future!
  30. Mar 11, 2021 at 12:03 PM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    For the most part, I hate the color blue...but your truck looks incredible. :headbang:
