35s —> 37s HELP
Discussion in 'Wheels & Tires' started by McTrilliams, Nov 22, 2019.
  1. Nov 22, 2019 at 6:51 PM
    McTrilliams
    McTrilliams [OP] New Member
    David
    Lilburn, GA
    2016 Grey Tundra TRDpro
    37s and 4” lift
    I have a ‘16 TRDPro with 3” lift, Bilstein suspension and am running 35 / 12.5 BFG KO3s.
    I like the look of 37s and THINK I can squeeze them in with my current set up. However, if I need a bigger lift I’ll probably go larger than 37s. Anyone have advice? Read a couple of threads and just can’t seem to find an answer to the 3” lift and 37s.
    FYI: wheels are factory TRDs 18s w/ 60mm offset.
    Rica25 likes this.
  2. Nov 22, 2019 at 8:08 PM
    TheBeast The Beach
    fenders work is usually involved with 37's
    Rica25 likes this.
  3. Nov 22, 2019 at 8:20 PM
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
  4. Nov 22, 2019 at 9:06 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    first of all, whats your review of the km3's? look into the dirty seven thread, lots of info there, oh and it will be expensive
    Rica25 and McTrilliams[OP] like this.
  5. Nov 22, 2019 at 9:47 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    A trd pro with a 3 inch lift? What combo are you running?
    Rica25 likes this.
  6. Nov 22, 2019 at 11:39 PM
    McTrilliams
    David
    Lilburn, GA
    37s and 4” lift
    Love my KM3s. Had ProComp MT2s and Nitto Trail Grapplers and these are by far my favorite.
    I’m not stressed about “major” work. I’m happy to go higher but like the lower lift/ larger tire stance.
    Samoan Thor likes this.
  7. Nov 23, 2019 at 4:50 AM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I’m running 37s on 3” lift. I have stock fenders with bushwackers bolt on flares. Just need to remove front sway bar and body mount chop as well as pinch weld mod. Basically cut and flatten the pinch weld. If you have the stock front mud flaps they need to go as well. The dirty seven thread though can answer most other questions. But that’s what I did to make my 37 km3s fit. Now with the stock offset I’m not sure if the sway bar has to go. I’m on +25 offset method grid 18x9 wheels and it was rubbing almost at full lock on the sway bar. Also with the stock offset you may not need to cut the body mount as much as most people do as most of us run +25 or 0 offset wheels. Maybe someone with stock offset wheels can verify that part. But honestly not that much work to get them to fit. Last but not least caster on your alignment is what got me the extra clearance. My caster is in the 4s range. Passenger is at 4 exactly and the driver is like 4.3 or close to it. Hope that helps.
    McTrilliams[OP] likes this.
  8. Nov 23, 2019 at 4:52 AM
    Jimes
    Jimes New Member
    Oh ya, welcome to the forum and say good bye to your money. We are a good influence on how to spend your cash.
    TheBeast, Quebec, Rica25 and 2 others like this.
