35 Skinnies, Do they exist?
Discussion in 'Wheels & Tires' started by scooterprint, Jul 4, 2022.
  1. Jul 4, 2022 at 9:38 PM
    scooterprint
    scooterprint [OP] Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Hello,
    I'm looking at moving up to 35s in the not-so-distant future. I'd like to maintain my 17x7.5" factory wheels, so I guess I'm in the market for something skinnier than 12.50 wide tires. It looks like the only options are Super Swampers or T/A KO2s. I feel like I have to be missing a few other options here...
    Thanks
    Jeremy
    Edit: I'm specifically looking for M/Ts.
    [​IMG] [​IMG][​IMG]
  2. Jul 4, 2022 at 9:42 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    35X10.50 is a size. Not sure how hard to find.
  3. Jul 4, 2022 at 9:44 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    DJenerated and scooterprint[OP] like this.
  4. Jul 4, 2022 at 10:02 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    35x10.5r17
    35x11.5r18
    The 255/85-17 is a 34 x 10
    scooterprint[OP] likes this.
  5. Jul 4, 2022 at 10:10 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
  6. Jul 4, 2022 at 10:24 PM
    BuzzardsGottaEat
    '16 Tundra DCLB
    Round Tires
    I believe the Toyo Open Country AT III comes in a 35x11.5r20 ha. Random size and an AT, but…. also available, if I remember correctly.
  7. Jul 4, 2022 at 10:29 PM
    alb1k
    Left Coast
    It's good
  8. Jul 4, 2022 at 10:41 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    285/75R18 is exactly that: a slightly taller—34.8 vs 34.5 (the true diameter of a 35), a skinnier 35 that requires no cab mount chop or cutting up fenders to fit with a 2” lift.
    Edited to add: lots of options in this size, too, from Goodyear, Toyo, Falken, Yokohama, Nitto, and Cooper. But if you’re staying on 17s, there will probably be a lot fewer options.
    Here’s an older pic of mine:
    equin, Blue Thunder and Saltyhero13 like this.
  9. Jul 4, 2022 at 10:46 PM
    alb1k
    Left Coast
    It's good
    Probably won't fit a 2004 the same way. I run 285/75/17 on my 05 DC and that is the max without way more work than I did.
  10. Jul 4, 2022 at 10:51 PM
    Terndrerrr
    Music City
    6UR-FE
    Ahh. Yep. Didn’t see the 1st gen in the OP’s pic. Plenty o’ options for skinny 35s on an 18” rim, but if he wants to stay on 17s, probably far more limited.
    alb1k[QUOTED] likes this.
  11. Jul 4, 2022 at 11:03 PM
    alb1k
    Left Coast
    It's good
    My experience with the same truck in 2WD (in my case) is that a 275/70/17 fits all day long at least leveled up front. That's about a 32.2-4" at 10.4. A 33X10.50 should fit easy leveled as well. A 285/75/17 (33.7X11.2) takes some work, but is a great size. I run 3/4" spacers for frame rub, adjusted my bump stops, trimmed liners, hammered pinch welds, and stuff them without loosening my fenders...barely. A super skinny 35 is out there I believe that will work for 1st gen, but the up-travel is still a concern on turns for the fenders, unless we have a rad lift. So rad, 35" isn't a fit concern at all.
  12. Jul 4, 2022 at 11:09 PM
    alb1k
    Left Coast
    It's good
    Close to full stuff on spaced bump stops and sub 34" tires. Not much room left on mine.
  13. Jul 4, 2022 at 11:16 PM
    alb1k
    Left Coast
    It's good
    Well, he did help me with most things, so...
  14. Jul 4, 2022 at 11:20 PM
    alb1k
    Left Coast
    It's good
    That's OK, I can never remember what state you guys are in. Unless it's CA. I just assume everyone else is in TX, AZ, TN or somewhere with snow.
  15. Jul 5, 2022 at 12:39 AM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    I'm on 285/70r17s right now. The actual size is 32.9x11.70. Rocking the 17x7.5 +18 split-spoke wheels with 1.5" spacers, which is effectively 3.46 backspacing. I believe if I move to 1.25 spacers, it should actually increase my tire clearance, though I know when I go to 35s, I will have to tub my cab corners.
  16. Jul 5, 2022 at 12:07 PM
    alb1k
    Left Coast
    It's good
    I think you got this if the tires are found, I'll try a search.
  17. Nov 2, 2022 at 1:42 PM
    zoomspeed05
    zoomspeed05 New Member
    marc
    2006 tundra double cab sr5 4WD
    35x10.50r17 Kenda Klever RT
    AKA skinny 35s
  18. Nov 2, 2022 at 2:09 PM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Those kendas look good. I always like the pie cutter look and performance
    zoomspeed05 likes this.
  19. Nov 7, 2022 at 5:43 AM
    zoomspeed05
    marc
    oh yea
  20. Jun 21, 2023 at 11:21 PM
    Dvolcan
    Dvolcan New Member
    Mickey thompsons 255/85/17, they call them 35/10/17.
    Fricken love them compared to my cooper stt pro’s
    equin, roughfisher and PermaFrostTRD like this.
  21. Jun 22, 2023 at 12:29 PM
    COTundra23
    COTundra23 New Member
  22. Dec 6, 2023 at 7:04 PM
    6T8Tundra
    6T8Tundra New Member
    Kevin
    06 Tundra 4x4 AC
    Minor cutting if any? Just the look I’m trying to pull off on my AC. Stock bumper
    1stgentundradriver likes this.
  23. Dec 24, 2023 at 6:21 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Kinda reviving a dead thread here, but I've nearly worn out my Maxxis Razr ATs at 21,000 miles. I believe I have an alignment issue causing premature wear, but we'll ignore that for now.
    It looks like kenda has come out with their new KR629 MT2s which you can get in a 35x10.50r17 size. Really has me thinking about getting a set.
    WFD473 likes this.
