+35 offset Wheels with 295/70/18 Ridge Grappler
Discussion in 'Wheels & Tires' started by Willskaf, Feb 7, 2020.
  1. Feb 7, 2020 at 9:51 PM
    Willskaf
    Willskaf [OP] New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Hey Fellas,
    So I have a 2019 TRD Offroad. As you know, the 295/70/18 fits on the TRD pro because it's 2" higher in the front than mine .so I just ordered and will be installing the Bilstein 6112 on the front with a 1.9 inch lift which will level the truck and will have the same height as the pro. So I'm assuming that I will be able to fit the 295/70/18 with the OEM wheels? BTW, I'm also going to install the bumper shims.
    So here is my question. Anyone here has the Bilstein 6112 setup at 1.9 leveled the front with the 295/70/18 on a +35 offset wheels? Basically, I'm trying to see if I can fit the 295/70/18 on a +35 offset wheels with the same height setup instead of keeping my OEM wheels .
  2. Feb 7, 2020 at 9:52 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Pictures will help please if any
  3. Feb 9, 2020 at 12:49 PM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
    You should be fine. I ran a 35x12.50 on a 18x8.5 +35 wheel on the TRD pro suspension with 1 CB shim with minimal rubbing in reverse (removed mud flaps).
  4. Feb 9, 2020 at 4:56 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    That's good to know. Would you still happen to have a picture please?
    How did it look? Do you think it will look better with more lift or just with that? If you have any pictures I would really appreciate it. I just want to see what it would look like. I'm receiving the bilstein's 6112 this week and if I needed more Lift, I can get it done before I install it
  5. Feb 9, 2020 at 5:24 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Who makes +35 18s?
    PermaFrostTRD likes this.
  6. Feb 9, 2020 at 6:15 PM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
  7. Feb 9, 2020 at 6:17 PM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
    I’ve got a bunch if there’s any specific angles you want to see. Handful on my Instagram page @Nvlendy.
    Mine were ATX ravines.
  8. Feb 9, 2020 at 6:33 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Method does
  9. Feb 9, 2020 at 6:34 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thank you for the pic bud. Yes please . Do you have a picture from a side angle showing how much the tires stick out b Young the fenders? My understanding is that with plus 35 offset, they should be flush with the fenders or maybe just a slightly further
  10. Feb 9, 2020 at 6:35 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    @Flyinryank. Sorry bud. Methods makes the +35 in 17s not 18s
    Flyinryank likes this.
  11. Feb 9, 2020 at 6:39 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I saw there wheels today on a Tacoma. I swear they look kind of similar to the TRD wheels if I'm not mistaken. I like them but as you see, no brand is listed on them . I thought they migh look good on a Tundra .
  12. Feb 9, 2020 at 6:42 PM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
    Yeah the +35’s had them just slightly outside the fender wells
    drobb and jordan0317 like this.
  13. Feb 9, 2020 at 7:53 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thanks buddy
  14. Feb 7, 2022 at 12:35 PM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    you said rubbing AFTER pulling the front mud flaps?
    so rubbing on cab mount/frame? Did you chop it? (Bmc)
    gonna be pairing 17x8.5s +35. With 35x12.50s and really dont wanna do a bmc.
  15. Feb 7, 2022 at 1:10 PM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
    The BMC fixes the rubbing on the back side(cab side). The only place it rubbed on was on the lower plastic area behind the fog lights. After I switched to an aftermarket front bumper there was zero rubbing. I’m sure I could’ve solved it with a heat gun and some massaging though. Since then I’ve switched to 37’s and had to do the bmc, pwm, and aftermarket upper control arms set to 4 degrees caster. No rubbing with those now either lol.
  16. Feb 7, 2022 at 5:42 PM
    Tundra18overland
    Jesse
    GA
    Sweet. Still running the +35 wheels with 37s? SPC UCA?
  17. Feb 8, 2022 at 5:25 AM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
    No I’m on +18 method grids now, LSK uniball uppers
  18. Feb 8, 2022 at 8:50 AM
    Tundra18overland
    Jesse
    GA
    Beautiful truck. Do you think the +35s would have worked for the 37s? Or did you need the +18s. Are you regeared?
  19. Feb 8, 2022 at 9:41 AM
    thedonn
    thedonn New Member
    295 70 18 Falken AT3 with Method +25. i have the 6112 set at +1.9. i did bumper shims and removed mudflaps - no BMC. From everything i have read If you have stock wheels they are more like +65 and you will need a 1.5 spacer to get to the sweetspot (+18 to +26 offset) to clear UCA and not rub
    Tundra18overland likes this.
  20. Feb 8, 2022 at 9:47 AM
    thedonn
    thedonn New Member
    also over 1 inch of UCA clearance....my truck does not have a front skid plate so i cant speak to that.
  21. Feb 8, 2022 at 9:55 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Anyone actually know if these tacoma 17s would fit? Always liked these rims.
  22. Feb 8, 2022 at 3:41 PM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
    Thank you! And yes I think the +35’s would’ve worked for sure. Probably would’ve saved me some extra cutting I would imagine. I only switched to the methods because I found a smoking good deal on 5 of them locally. Not regeared and no plans to. I have a company vehicle so I only drive my truck on the weekends. Driving around town there is no difference between the 35’s I had on previously. At interstate speeds on some hills there’s definitely some extra gear hunting though.
  23. Feb 8, 2022 at 4:39 PM
    Tundra18overland
    Jesse
    GA
    Our trucks are 5 lug, so no. Maybe a 1st gen tundra.
  24. Feb 8, 2022 at 4:52 PM
    PermaFrostTRD
    Northern NY
    I still wanna see these +35 18” wheels!
    for the OP the stock/ OEM TRD off road ( and TRD Pro) wheels are +60mm offset not 65.
    295 is a nominal width. You’re gonna get tires from different manufacturers that range from 11.5” to 12” widths designated as a “295”. Also, tire widths will be slightly “pinched” on the OEM 8” wide wheels. After market 8.5 or 9” wheel widths will fatten them out some. Most manufacturers will give the recommended wheel widths plus the width of the wheel that the tire was “measured” on. ymmv
