33x12.5R18 on TRD Rims question
Discussion in 'Wheels & Tires' started by Ted4311, Jul 31, 2017.
  1. Jul 31, 2017 at 7:52 AM
    Ted4311
    Ted4311 [OP] Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    I have read so much... sick of reading...
    I want 33x12.5 on my TRD rims... Will it work and will I have to do the cmc
  2. Jul 31, 2017 at 8:06 AM
    PermaFrostTRD
    Northern NY
    What tire brand and model?
    Most (if not all) 12.5" width tires are recommended to be mounted on a minimum 8.5" rim. Our TRD's are 8". If you do a lot of wheelin' & crawlin' airing down those tires could cause you to lose the bead.
    I'm looking at 305/65r18 which are 12" wide (also recommended 8.5" rim) and 33.6" diameter.
    I currently run 275/70r18 bfg KO2's. 33.2" diameter and 10.8" wide. Zero rubbing, zero fender liner heating, pushing, melting, or cutting. Stock TRD off-road suspension.
    Most of the guys who really know what they're talking about said due to the backspace/ offset of the trd wheel, increasing width of tire would produce an issue with the UCA and therefore require spacers. I can nearly fit my hand in between there now. Adding .6" (half of the 1.2" difference in the 275 to 305 jump) I don't think will rub or contact the UCA. But I've only measured with the wheels straight on and not turned. I don't know enough about suspension components to understand if turning the wheel affects that space/geometry at all.
    Adding spacers pushes everything out which is where you run into the fender liner, mud flaps, skid plate, and body mount rubbing issues when the wheels are turned.
    I can math really well, but again, I'm deferring to the expertise of the guys who really know their stuff on here. And I've only got 15k miles on the 275/70's. Not looking to replace tires yet.
  3. Jul 31, 2017 at 8:14 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Nitto mud grappler 33x12.5r18
  4. Jul 31, 2017 at 8:37 AM
    PermaFrostTRD
    Northern NY
    32.95"x12.6" measured on a 10" wheel, I'd imagine yours would be a little taller and narrower due to your wheel squeeze.
  5. Jul 31, 2017 at 9:34 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    So trim plastic but should be OK with cab mount
  6. Jul 31, 2017 at 9:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Is there a reason you want to go so wide? I think you might hit your UCA's with stock wheels.
    The Juice likes this.
  7. Jul 31, 2017 at 9:50 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    No reason haha. being difficult i guess
    joonbug[QUOTED] likes this.
  8. Jul 31, 2017 at 9:54 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    So.... New rims (moto metal -24 offset) with the 33x12.5... Will I be required to do the cmc? Trying to get my ducks in a row before I pull the trigger and buy this stuff.
  9. Jul 31, 2017 at 10:07 AM
    PermaFrostTRD
    Northern NY
    From everything I've read, yes.
    Better start saving $$ for some bodywork / painting too. Your doors will become very intimate with every rock on the road with that width of tire and offset.
    BakNBlk2014 likes this.
  10. Jul 31, 2017 at 10:12 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    ok when you put it that way Eff that... so a 305/70 R18 mud tire on stock rims. PLASTIC trimming only no cmc? If you guys haven't noticed I am against the CMC...
  11. Jul 31, 2017 at 10:22 AM
    PermaFrostTRD
    Northern NY
    305/70 is almost 2" taller diameter than the 33" tires you were looking at (34.81"). You'd likely need some lift. And still probably require a CMC.
  12. Jul 31, 2017 at 10:52 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    SMH..... What mud tires do people run on these TRD Rims
  13. Jul 31, 2017 at 10:52 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    this is like pulling teeth:annoyed:
  14. Jul 31, 2017 at 10:56 AM
    PermaFrostTRD
    Northern NY
    I think the majority here are running some variation of: aftermarket 18x9" +30 all the way to -12 offset. (Majority in that range) with 295/70r18. 3" front lift, 1" rear lift. (+30 to +18 offset seems to be the sweet spot). Varying degrees of liner modding and CMC's.
    That's my forte.
    Backslider, The Juice and joonbug like this.
  15. Jul 31, 2017 at 11:08 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    285/65R18 Should fit minimal trimming? I really do not want to do the CMC
  16. Jul 31, 2017 at 12:23 PM
    PermaFrostTRD
    Northern NY
    Yes.
    Can verify personally that 275/70r18 will fit w/o trimming.
  17. Jul 31, 2017 at 1:13 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    285/65r18 will fit fine
    zcarpenter92 and Ted4311[OP] like this.
  18. Jul 31, 2017 at 1:32 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Sold I'm going 285/65R18 mud slingers
  19. Aug 1, 2017 at 12:13 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    I really am shocked that no one stuffs 33x12.5 on a 3 inch lift.... I am tempted because I have found a good deal on 33x12.5 but lack information (the shocking part because of this site)
  20. Aug 2, 2017 at 1:04 PM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    I think you should, as I've been curious myself.
    kyle
  21. Aug 2, 2017 at 2:01 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    I'm about to go 6 inch lift with 35's and say eff this question.
  22. Aug 2, 2017 at 2:02 PM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    Hahahah. Always an option
    kyle
  23. Aug 2, 2017 at 3:47 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    I mean...you can stuff 35" General Grabbers on TRD wheels on stock height with minimal hackery. No CMC needed.
  24. Aug 2, 2017 at 4:01 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    How? Everyone here has said no go on 33x12.5 but you said stuff 35's?.... Haha could save me 4k if we hash this out
  25. Aug 2, 2017 at 4:02 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Caused a bicker match with the wife about the lift Rims and tires. Either piss her off and do it or make her happy and just get new rubbers
  26. Aug 2, 2017 at 4:22 PM
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    Piss her off and do it!!! You only live once and she'll forget about it in a few months......besides....they always find something to be pissed about anyways dude:burnrubber:........... 285/65R18 on 18x9 wheels with 5" back space and 0 offset only requires a mud flap sacrifice...... My next tire will be a 305/65R18 because wider looks better and I will be getting new wheels with a +12 offset for the wider tires..... 2.5 inch lift front
  27. Aug 2, 2017 at 5:42 PM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Yes 33x12.5 & 35x12.5 will fit on the TRD wheels, i have done both. the 33s were on at stock PRO height. and I went to 35s after I installed my coachbuilder goodies. I already had an aftermarket front bumper so no trimming for me. and I have not had to chop the cab mount.
    New vs old and clearance(I have a 1/4 spacer on the front hubs)
    Newm likes this.
  28. Aug 2, 2017 at 5:45 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    and I put the 33x12.5 on my coworkers tundra, stock height not leveling kit and they did fit no issues, didnt even rub the skid plate.
  29. Aug 2, 2017 at 5:54 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    No one puts 33x12.5's on with a 3" lift because the tires look unproportional. Too wide and too short, the latter being the main thing IMO. Besides that, if you go to a 3/1 lift why only get a 33? A lot of guys on this site have 295/70's or 35x12.5's on that lift, or even 305/70's in some cases.
    And just curious, why are you against the CMC? Just buy the plates from Relentless and find yourself a shop that'll do it for ya, easy as pie.
    trdlife likes this.
  30. Aug 2, 2017 at 5:58 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    This is all true and I agree, 33s aren't much taller than factory and look 'little' even at stock height of a pro. Thats why i finally went with 35s.
    zcarpenter92[QUOTED] likes this.
