33s ?!
Discussion in 'Wheels & Tires' started by mv133, Mar 16, 2021.
  1. Mar 16, 2021 at 5:08 AM
    mv133
    mv133 [OP] New Member
    21 tundra SR5
    Brandy new
    So my truck came with 275s on it obviously. I was going to order 33s then i realized that’s damn near the same size correct ? Should i order 34s? I’m going to be running stock suspension with a 1.5 leveling kit. Thank you any response appreciated
  2. Mar 16, 2021 at 5:18 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    The stock tire of 275/65/r18 is like a 32". I went with a 275/70/r18 which put me at like 33.2". They fit well on stock suspension and wheels. If I had a leveling kit I would probably go 295/70/r18 on stock wheels which would put it at a 34". If you go aftermarket wheels then the flood gates open you will look at doing some modifications to make sure they don't rub
    Sean492 likes this.
  3. Mar 16, 2021 at 6:27 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    275/70-18 fit well on stock truck and are a bit taller than 33s. 285/70-18 can probably be squeezed in on stock truck but would probably need stock offset wheels. The 285/70s size do cost significantly more however and there are limited choices in that size. Anything larger will require 2+ inch lift in the front. 295/70-18 and 285-75-18 are very popular sizes for leveled/lifted Tundras. And of course moving to any larger than stock size mean moving from the standard load stock tires to E load.
  4. Mar 16, 2021 at 8:27 AM
    mv133
    21 tundra SR5
    Brandy new
    So 33s are smaller then my stock 275s jeeez i don’t want to go smaller .. so what’s the biggest i can fit with a leveling kit ? I’m bad at the metric tire thing ugh
  5. Mar 16, 2021 at 8:30 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  6. Mar 16, 2021 at 8:35 AM
    AZBoatHauler
    So.Arizona
  7. Mar 16, 2021 at 8:37 AM
    BIGUGLY
    Paul
    2018 Limited
    275 is the width. The second number gives you the height. The stock is 275 65 18. Going to 275 70 18 gets you a 33 inch tire, not smaller than stock.
  8. Mar 16, 2021 at 9:11 AM
    mv133
    21 tundra SR5
    Brandy new
    Ok that clears up a lot .. so I’m thinking 305/65/18 slightly bigger then 33s with +20 offset.
  9. Mar 16, 2021 at 9:24 AM
    AZBoatHauler
    So.Arizona
    Get ready to :sawzall:
  10. Mar 16, 2021 at 9:27 AM
    mv133
    21 tundra SR5
    Brandy new
    Because of tire or offset? Maybe I’ll just stick to ordering 33s lol
  11. Mar 16, 2021 at 9:28 AM
    AZBoatHauler
    So.Arizona
    Look at the link in post #5. 305s will cause you problems.
