Discussion in 'Detailing' started by War Machine, Oct 21, 2018.
  1. Oct 21, 2018 at 5:25 PM
    War Machine
    War Machine [OP] SSEM # 5 3MW
    Pudge, fundra_goes_west and 4x4_Angel like this.
  2. Oct 22, 2018 at 5:18 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The instructions say to apply to a wet surface, small area at a time, and rinse immediately with high pressure. Would this be difficult to do? It seems like doing one panel, then rinsing, then doing the adjacent panel, you will be spraying over the previous panel again. Or does it not matter since the rinse will get that panel again also?
    War Machine[OP] likes this.
  3. Oct 22, 2018 at 5:44 AM
    War Machine
    It doesn’t matter. I generally do “sections” as opposed to a panel at a time.
    My process is to wash the whole vehicle. While it’s still wet, I’ll spray this on an area.
    Spray the product on the roof, rinse.
    Spray hood, grill, both front fenders, rinse.
    Front and passenger doors (one side), rinse.
    Sides of bed, rinse.
    Repeat on opposite side, rinse.
    Tailgate, rinse.
    Obviously the descriptions apply to a truck. A car or SUV follow the same pattern. Basically top, front, sides, rear, in that order.
    While doing this, I will periodically spray water on the areas I’ve already done to avoid any parts air drying. This is mainly because I have hard water that will leave spots if it dries on its own. Then I dry the whole vehicle.
    It also is a good idea to keep spraying the adjacent panels because the product will overspray onto them.
    The most important thing is to keep this stuff from drying in the vehicle before rinsing. If it’s hot outside you’ll need to do smaller sections. It was pretty cool yesterday, so I could do bigger sections at a time. If this stuff dries on the car before rinsing, you’re gonna have a bad time.
    Overall, Wet Coat or Hydro2 are the easiest sealants to apply. McKees and Waxaddict make the same thing. I’ve tried the McKees, and it really didn’t work as well. It didn’t spread or stick nearly as well as these two. I have a bottle of the Waxaddict version, but have not used it yet. I’ll update when I do.
    I hope I was clear and answered your questions. Still a little tired, so I may not be as sharp as I normally am. I did four vehicles yesterday, so I’m pretty whooped.
    If you can afford it, go with Carpro Hydro2. It’s triple the price, but it calls for a minimum of a 1:6 dilution. I suck at math, but I think that means it’s 50% cheaper in the long run. Wet Coat is a very good value though. I put it on three trucks, and had a third of a bottle left. If you’re only doing your truck, that bottle should last you a couple of years.
    Pudge and Boerseun[QUOTED] like this.
  4. Oct 22, 2018 at 10:20 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    Excellent Thanks for the review!
  5. Jan 1, 2019 at 11:34 AM
    torontopimp
    torontopimp New Member
    2018 tundra SR5 off road
    Running boards , tonneau cover, short antenna, Solo Mach 40 side exit before rear wheel.
    I used this about a week after I got the truck and I find that the dirt and salt comes off way easier than on my other vehicle that doesn’t have the wet coat. I just go to the power wash and give it a good rinse off and the dirt just falls off.
    Right now we haven’t had much snow and it has been warm at 20-25 F compared to our usual cold winters.
    I will use this stuff year around.
  6. Jan 1, 2019 at 6:34 PM
    War Machine
    It really is good stuff. Gyeon has a good reputation, though this is the only product of theirs I’ve tried.
