33/12.5R18 with my Readylift leveling kit?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraDale17, May 8, 2018.
  1. May 8, 2018 at 4:10 PM
    TundraDale17
    TundraDale17 [OP] New Member
    Ryan
    2017 Black Tundra SR5 TRD
    2" readylift leveling Kit
    I put a 2" leveling Kit on my 2017 Tubdra, I want to put bigger tire on it now. Could i run a 33 12.50r18 with my readylift leveling kit?
    T-Rex266 and jewsNbrews like this.
  2. May 8, 2018 at 4:25 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  3. May 8, 2018 at 5:20 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    What wheels you have Ryan, factory or aftermarket. If aftermarket what's the offset. :cool:
  4. May 8, 2018 at 6:18 PM
    Welcome from Ohio!
  5. May 8, 2018 at 7:16 PM
  6. May 8, 2018 at 7:19 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Sure, you can put 33s on there. Will it rub? Depends on your wheel offset. Stock are around 32"
  7. May 8, 2018 at 7:55 PM
    TundraDale17
    Ryan
    They are factory
    831Tun and jewsNbrews like this.
  8. May 8, 2018 at 8:20 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    12.5 wide might rub the OEM UCA. I'm not sure though.
  9. May 8, 2018 at 10:27 PM
    Welcome from Texas, let's see your ride
  10. May 9, 2018 at 2:16 AM
    rons23
    Ron
    Kill Devil Hills
    That 12.50 will reach out and rub that UCA. You gotta either go with spacers or a correct offset aftermarket wheel. May I suggest Ryan , go and measure the space between the inside of your front tire and UCA. This will give you an idea of what your working with. Myself I had just under an 1" clearance and went with 1 1/4" Spider Trak spacers. This is a temporary fix till I go aftermarket. There are a few factors when going up in tire size, tire size, offset, lift. As Walla Walla Wa mentioned, check out
    Wheels & Tires
    thread. This will have a ton of info on all kinds of set- ups , tire sizes, offsets, and pics. :thumbsup:
    T-Rex266 likes this.
  11. May 9, 2018 at 1:53 PM
    TundraDale17
    Ryan
    Thank you from Missouri!
  12. May 9, 2018 at 1:56 PM
    TundraDale17
    Ryan
    Thanks for all the helpful info Ron. I will check it out.
  13. May 9, 2018 at 2:00 PM
    rons23
    Ron
    Kill Devil Hills
    Anytime Ryan. Hope you get what your shooting for. :thumbsup:
