32 gal tank listen instead of previous years' 38 gal
Discussion in '3rd Gen Tundras (2022+)' started by TTund16, Dec 13, 2021.
  1. Dec 13, 2021 at 11:48 AM
    TTund16
    TTund16 [OP] New Member
    Did Toyota finally list the correct gas tank size for 22's? or the lawyers got involved?
    I see them listing 32 gal instead of previous years "38 gal" minus the infamous 6 or 7 pump cooler(?) unusable gallons ...
    Or are they using smaller gas tank now? Kind of doubt that.
  2. Dec 13, 2021 at 11:53 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Not sure of the physical differences in tank design, but Yota lists 2 available tanks based on options: 22.5 gallon (standard on SR & SR5) or 32.2 gallon (available option on SR5, standard on Limited, Platinum, 1794, TRD Pro)
    This dude had got a video filling up his 22.5 gallon from "empty" and only gets 18-ish gallons in it, as I recall.
    TTund16[OP] likes this.
  3. Dec 13, 2021 at 11:55 AM
    Kentuckytundra
    Kentuckytundra I love spam calls, we talk for hours
    They are smaller
  4. Dec 13, 2021 at 12:01 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  5. Dec 13, 2021 at 12:03 PM
    TTund16
    lol has this been discussed before?
    I saw '22 stickers and it says 32 gal.
    My '16 says 38.
    I'm bad in math but figured 38 minus unusable 6 = 32
  6. Dec 13, 2021 at 12:06 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It's not unusable.
  7. Dec 13, 2021 at 2:00 PM
    TTund16
    Yes, in one bank if I had $1700, I could only withdrawal max of $200 without a big penalty (e.g. risk burning the fuel pump) They had a $1500 min required balance for checking and $300 min balance for savings.
    I called the bank and they said the $300 (savings) or $1500 (checking) min reserved and unusable money was for cooling-off the bank interior (air conditioning? I assume) kind of like Tundra fuel pump needs 6 gal for cooling purposes ...
  8. Dec 13, 2021 at 2:29 PM
    Blueknights75
    Ron
    Clayton, NC
  9. Dec 13, 2021 at 2:37 PM
    AJGallo41
    AJGallo41 New Member
    Aj
    MN
    2016 Tundra Crewmax 5.7
    Level Kit 275/70r18 BFG KO2's
    They reduced the tank size because the truck is overall a bit more fuel efficient. The range of the new 22 is about the same as years prior if not slightly better.
  10. Dec 13, 2021 at 2:43 PM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    So now the F150 is the class leader in terms of range with the 36 gallon fuel tank.
    I don't think the Tundra is that much more fuel efficient over the F150 to make up for the 4 gallons difference.
  11. Dec 13, 2021 at 2:46 PM
    Breathing Borla
    Northern Illinois
    I dont think you can get the 36 gallon tank on the powerboost, but Im not 100% on that
  12. Dec 13, 2021 at 3:20 PM
    Polo08816
    2014 BMW 335i
    You are correct, you cannot.
    I wouldn't buy a hybrid vehicle. For the non hybrid options, the F150 still has the largest gas tank and that's an important factor when towing longer distances.
  13. Dec 13, 2021 at 3:26 PM
    Breathing Borla
    Northern Illinois
    Ok I’m no ford expert nor do I want to be
    I was thinking total range and that model gets the best mpg , but I see what your saying
  14. Dec 13, 2021 at 3:31 PM
    Polo08816
    2014 BMW 335i
    I was really hoping Toyota would have kept a ~ 38 gallon fuel tank and been a class leader in the range department.
    Totherion and Mattedfred like this.
  15. Dec 13, 2021 at 3:33 PM
    Breathing Borla
    Northern Illinois
    I get it but the range wasn’t reduced in most instances since the efficiency is better but 32 is fine with me if and that’s a big if I decide to get one
    Cpl_Punishment likes this.
  16. Dec 13, 2021 at 3:43 PM
    UATundra
    UATundra New Member
    The biggest instance I can think of is the most important to me, that's while towing.
    Gas burners are going to average somewhere around 8-10 MPG while towing a 18-25 ft travel trailer, doesn't matter if it's a TT V6, a NA 7.3L or anything in between.
  17. Dec 13, 2021 at 3:44 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Sr-sr5 22 gallon tank with option of 32.2 TOTAL gallons with package.
    limited and up 32.2 gallon
  18. Dec 14, 2021 at 5:27 AM
    nuclear
    nuclear New Member
    I don't think the average person cares about that and then it hurts them in other ways, I understand why they dropped it.
  19. Dec 14, 2021 at 12:23 PM
    Smokingloon
    Smokingloon New Member
    Anyone know about the sr5 with the long bed? I couldn't find an add on package that mentions the bigger gas tank like the short bed does in the sr5 trim.
  20. Dec 14, 2021 at 12:26 PM
    Kentuckytundra
    My 3/4 ton came with a 26 gallon tank... got rid of it almost immediately for a titan 50 gallon tank. What was ford thinking for a diesel meant to pull?!
  21. Dec 14, 2021 at 12:37 PM
    AJGallo41
    Aj
    MN
    There's diminishing returns, 38 gallon tank weighs about 250lbs, 50 gallon tank would be even more. The larger tank size you add the less fuel economy you'll get.
    NueveTundra likes this.
  22. Dec 14, 2021 at 12:42 PM
    Kentuckytundra
    I think it had more to do with payload personally. In the competition between manufacturers to get the slight edge over one another for class leader.
  23. Dec 14, 2021 at 12:47 PM
    AJGallo41
    Aj
    MN
    Yep, that's a good point too. Toyota payload is already bad as it is, imagine if they could make a 50 gal work.
  24. Dec 14, 2021 at 12:58 PM
    Kentuckytundra
    All I can say is eww. Lol a big boned family of 4 would exceed the payload :D
  25. Dec 14, 2021 at 1:02 PM
    TTund16
    "big boned" or bigfoot? :muscleflexing:
    Family of one Bigfoot would do the same!
  26. Dec 14, 2021 at 5:11 PM
    BlueMeany
    BlueMeany New Member
    Finger Lakes NY
    2018 Tacoma SR5
    So . . . . Hypothetically . . . . .
    if it was winter and the fuel pump was plenty cool enough on its own, you could run waaaay past empty. Like possibly 100+ miles after empty. If there’s about 6 gallon of fuel in there that “doesn’t count”.
    Who wants to pull a Kramer and try it?
    biebs96, TTund16[OP] and MTRock like this.
  27. Dec 16, 2021 at 8:53 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    I’ve gone 50-60 miles several times after the light comes on with my 2013’s 26.4 gallon tank…and never filled more than 25 gallons. But I only avg 14mpg at best.
    I’d go 90-100 miles after the low fuel light came on with confidence if I was averaging 18-19mpg.
  28. Dec 18, 2021 at 11:05 AM
    Totherion
    Totherion New Member
    Every new vehicle I buy I get the tank down until the warning light comes on. I then go fill up. From that I know my true range. In my Silverado's case I have 3.5 gallons remaining.
    I'll do the same on the Tundra. To what I have read so far it seems I'll have a lot more in reserve when the light comes on.
  29. May 9, 2022 at 7:03 PM
    Tundra1Los
    Tundra1Los New Member
    Carl
    2022 Tundra Sr5
    TRD Off road Package
    I recently bought a 2022 Tundra sr5. I allowed it to get to the 10min es remaining warning light before I filled up with gas. From empty my tank is only taking 18 gallons before it starts to overfill. Should I be concerned? I thought the fuel tank size was 22.5 gallons.
  30. May 9, 2022 at 7:57 PM
    Breathing Borla
    Northern Illinois
    no, it’s called a reserve and it’s supposed to be there.
    my .02, just fill it when it gets to a 1/4 tank.
