30K Service
Discussion in '2nd Gen Tundras (2007-2013)' started by Nflguy, Sep 27, 2024.
  1. Sep 27, 2024 at 9:27 AM
    Nflguy
    Nflguy [OP] New Member
    I have a 2021 TRD Pro WITH 30,000 miles. I have yet to tow anything (if that matters)
    It was due for an oil change so I brought it to dealer for oil change and 30k miles service.
    They told me the battery failed load test. I have not had any issues but don't want to take the risk so approved battery replacement (true start battery for $198)
    They recommended power steering fliud replacement and brake fluid replacement but didnt say why. Just seemed to be a standard upsell attempt (maybe I'm wrong?)
    I feel like I might be getting scammed on the battery but I'm crazy busy at work and don't have time for dealing with getting stuck somewhere cuz my battery is dead.
  2. Sep 27, 2024 at 9:30 AM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Sounds like your truck has no issues. If it’s not broke, don’t fix it. Save your money.
  3. Sep 27, 2024 at 1:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Battery is a ripoff. Go to costco for better and cheaper battery with great warranty. Power steering and brake fluid you can turkey baster the reservoir out and refill with new every 10k miles and your good.
    Hbjeff and SoCal_Erik like this.
  4. Sep 27, 2024 at 4:13 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I would not get the Toyota battery but a aftermarket battery that is an upgrade. The power steering fluid you can do yourself easily there are some YouTube videos. The brake fluid is a good idea to replace since brake fluid is hygroscopic which means it will attract water and reduce its effectiveness. I like to fully change out brake fluid every 2-4 years and bleed the brakes if you have never done this have it done by a mechanic
    MadMaxCanon likes this.
