30K Mile Service
Discussion in '3rd Gen Tundras (2022+)' started by SirSwish32, Dec 11, 2023.
  1. Dec 11, 2023 at 7:29 AM
    SirSwish32
    SirSwish32 [OP] New Member
    Nick
    North Carolina
    2022 Tundra SR5 XP 4X4
    1.75" Rough Country Level
    Good morning good people. I am about to hit the 30K mark. I now what Toyota says I need to do at 30K, but from you knowledgeable people, what SHOULD I get done besides oil change and tire rotation? Thank you!
  2. Dec 11, 2023 at 8:34 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Definitely check the installation of the driver's floor mat! This cracks me up every time I see it. LOL
  3. Dec 11, 2023 at 8:45 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    Yeah I remember the debacle that started it. Still funny to me every time I've had any of our Toyotas in the dealer for service.
    ryanwgregg[QUOTED] likes this.
  4. Dec 11, 2023 at 1:41 PM
    demfer
    demfer New Member
    You should drain/fill new tranny fluid at 30k then after every other oil change. It’s fairly easy to do yourself, I wouldn’t pay to have it done at the dealer.
  5. Dec 11, 2023 at 1:50 PM
    demfer
    demfer New Member
    the drain and fill only replaces a limited % of fluid, most is in the system and torque converter. One can just drain, measure and refill without dealing with the overflow procedure and getting things up to temp. I’m coming off a 3ed Gen taco and had no issues over 134k miles when I sold it to a family member.
    I’m only at 22k on my rig but will attempt at 30ish.
  6. Dec 12, 2023 at 11:28 AM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    @ryanwgregg can you elaborate on what GTS/GTS+ is when doing any ATF change? Is that something we can do ourselves?
  7. Dec 12, 2023 at 11:51 AM
    OLV1071571
    Well that stinks. One of the reason I got the Tundra over others was so I could do my own trans filter change and refills etc. Never thought I would have to do a trans reset. Thanks for sharing though.
  8. Dec 12, 2023 at 12:02 PM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Do the front/rear diff and transfer case leave the trans alone for now
  9. Dec 12, 2023 at 1:08 PM
    OLV1071571
    Has anyone documented this trans procedure that you know of? Would be great to have someone that has higher mileage document the work.
  10. Dec 12, 2023 at 1:11 PM
    JayDee
    JayDee New Member
    Be sure to re-fill the blinker fluid!
    SirSwish32[OP] likes this.
  11. Dec 12, 2023 at 2:48 PM
    demfer
    demfer New Member
    I don’t follow. Hope more info will come out about it soon.
