30K mile maintenance
Discussion in 'General Tundra Discussion' started by tacouser, Feb 12, 2018.
  1. Feb 12, 2018 at 11:52 AM
    tacouser
    tacouser [OP] New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    I have a 2015 dbl cab 5.7 4x4 with almost 30k miles. Does any one have a idea of what Toyota charges for the 30K mile maintenance?
    Or can this work be done at a independent shop?
  2. Feb 12, 2018 at 1:08 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I’m in the same boat. I have an oil change due at 30k and I’m lazy so I’ll just take it to the dealership and let them tell me what it needs. I’ll let you know if you don’t have an answer by then.
  3. Feb 12, 2018 at 1:48 PM
    tacouser
    Chicago
    I know what is involved in the 30k maintenance what I am interested in is what people paid for it.
  4. Feb 12, 2018 at 2:50 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Dealer's are going to be different. My local Toyota dealer changed both my differentials for $90 at 30k, engine oil cost $60 I believe. Only reason I take my truck to the dealer is the cost of service is about what I can get fluids for, plus rotating tires.
    14burrito likes this.
  5. Feb 12, 2018 at 3:11 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Make sure they use the CORRECT t-case oil. If they charge you $100 for a 4x4 service, they arent using the correct fluid.
  6. Feb 12, 2018 at 3:28 PM
    wh4x4
    wh4x4 New Member
    I take mine in April for 30k (really 36 month service as I log below avg miles/yr). I'll post up what they charge me when I take it in.
    I always take a look at Toyota maintenance guide before going, dealerships always try to up-sell.
    https://www.toyota.com/owners/resources/owners-manuals/tundra/2015
    pg 41
    Unless you fall into the special driving conditions, looks like same service as 10k and 20k, with couple minor extras -- retorque propeller shaft (?$) & cabin air filter (25$)
    So I am guessing $200 -- but knowing around my area here, probably $275, just because they can
  7. Feb 12, 2018 at 3:44 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    My dealer says $100 for the 30k service last time I checked
  8. Feb 12, 2018 at 3:52 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I got a flier in the mail the other day to extend my free oil changes that came with the truck from 25k to 45k for $329, that's every 5k miles. It says the average 30k mile service is $141. Just had my 15k done, it would've been $94.
  9. Feb 12, 2018 at 4:03 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    What t-case fluid was it quoted for?
    I'm going with 75w90 and not the 75w spec the Borg Worner case now calls for. :stirthepot:
  10. Feb 12, 2018 at 4:16 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    They don’t change t case or diff fluid at 30k normally.
    Medic343 likes this.
  11. Feb 12, 2018 at 4:28 PM
    Don’t forget to have the 30k transmission check. All they do it cycle the solenoids, ensure proper level, and operational checks. My dealer didn’t even charge me for it. I don’t care if they did it or not, but it was documented it was in the event your transmission dumps right before warranty is up.
    If you don’t get the 30/60/90k mile checks, you may be paying for a transmission out of your pocket. This happened to a couple guys on a different forum.
    Sas and BTBAKER like this.
  12. Feb 12, 2018 at 4:38 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  13. Feb 12, 2018 at 4:41 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Right. You have to specify that you want that service performed based on your use.
    The standard 30k service it won’t be performed.
  14. Feb 12, 2018 at 4:43 PM
    I'm at 50k I need to schedule an appointment
  15. Feb 12, 2018 at 4:45 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Its tied into a 4x4 service. Dealership will probably try to sell you on it as part of the 30k.
  16. Feb 12, 2018 at 4:47 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Mine didn’t last summer on my Tacoma.
  17. Feb 12, 2018 at 4:51 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Well then the Service Writer and Service Department missed out on some $ and hopefully no issues down the road occur that will cause them or Toyota to lose $ for not keeping up on services...
  18. Feb 12, 2018 at 4:54 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I did it myself. I only had the normal services done at the dealer since it was free. Besides, that truck is someone’s else’s now.
    I’m just pointing out that the $100 30k service quotes are the bare minimum and don’t include the 4x4 service. And most dealers you will have to specify that you want it done.
    Rocko9999 likes this.
  19. Apr 6, 2018 at 7:28 AM
    wh4x4
    wh4x4 New Member
    Just had my service 30k completed. Just did what was in the book for Toyota, declined diff fluid changes, etc.
    269.11-40 coupon = 229.11 + random regulatory charges of 32.82 and tax 10.44 = 272.37
    I got a free hand wash out of it though, in my area, a wash sets you back $30 (I still feel dirty though spending 272 on an oil change, tire rotation, and cabin air filter)
  20. Apr 6, 2018 at 7:36 AM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    How much is a cabin air filter??
  21. Apr 6, 2018 at 7:42 AM
    15whtrd
    15whtrd Mr. Blonde
    Unless I can stand there and watch them change my oil, I will do everything in my power to avoid anyone doing it for me. Let alone pay them LOL. Cabin air filter is really easy to change.
    BTBAKER and nk1794 like this.
  22. Apr 6, 2018 at 7:45 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    At my local toyota dealership my last basic oil change and tire rotate was $110 nothing else. I'm do for my 30k oil change and contemplating just buying the jack and stands and doing it my self if I'm paying that much.
  23. Apr 6, 2018 at 7:46 AM
    wh4x4
    wh4x4 New Member
    they charged me 28.99. You can get OEM on Amazon for 20.29 (Toyota 87139-07020 Cabin Air Filter).
  24. Apr 6, 2018 at 7:50 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Agreed. I’ll do everything myself. I have zero faith in dealerships. Most of them are totally full of shit. For instance, I know for fact they DO NOT retorque and grease the prop shaft.
    But, I do! My work is 100 times more thorough than theirs. I document everything.
  25. Apr 6, 2018 at 7:52 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    It doesn’t t say anything about that other than check for signs of leaks so they would have a pretty hard time denying a claim IMO.
    nk1794 and 15whtrd like this.
  26. Apr 6, 2018 at 7:57 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Total rip off and you will do a better job. It’s easy and once you get the right tools it’s cheap. Plus while you are under there you will probably inspect and be more apt to retorque prop nuts and grease.
  27. Apr 6, 2018 at 8:06 AM
    17inferno
    17inferno New Member
    I have a pretty good dealership and went in for 15k service and the extra step is alignment check. I sat down and literally 18 minutes later all service was done, tires supposedly rotated, oil changed, alignment check, plus inspection. Seemed sketchy. That actually bummed me out a bit when I was rechecking everything in the parking lot before I left...no care into it.
  28. Apr 6, 2018 at 8:20 AM
    Grizzly660
    North Dakota
    Ya that's what I'm thinking. For that price i can get another jack and stands. I like things done right and that's not always the case at dealerships. Oh and I forgot to mention it took them 1 hr 45 min to complete basic oil change and tire rotate. :mad: they claimed it was bc the skid plate has to be removed (not too difficult)
    BTBAKER[QUOTED] and nk1794 like this.
  29. Apr 6, 2018 at 8:30 AM
    15whtrd
    15whtrd Mr. Blonde
    @BTBAKER I like your style.
    BTBAKER and seniramsu like this.
  30. Apr 6, 2018 at 8:45 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    This X1000. Just do your own work - then you know it is done right, you can take pride in it, and save some coin to boot.
    BTBAKER[QUOTED] and 15whtrd like this.
