3 way vs single hitch?
Discussion in 'Towing & Hauling' started by Outbound, Sep 7, 2021.
  1. Sep 7, 2021 at 1:15 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Random thought/question. I remember hearing when I was younger that those hitches that have 3 different balls weren't to be trusted. A single hitch that you swap the balls out on was supposedly much better, so that's what I've always used.
    It would seem to me that the 3 way would be more handy to keep on the truck and I don't see why it wouldn't be as safe.
  2. Sep 7, 2021 at 1:18 PM
    Taco-Spike
    Two Trucks
    Interesting. I've never heard that these were bad. Not saying they might be, but I see a lot of people using them.
  3. Sep 7, 2021 at 1:20 PM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I keep one in my truck just in case and have the others available and prefer using designated ones if I can. I personally don't believe they are unsafe, the only downside is that they don't drop if you have a lower lying trailer.
  4. Sep 7, 2021 at 1:22 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Difference between the ball being welded to the shank rather than bolted to it? :notsure:
    AZBoatHauler likes this.
  5. Sep 7, 2021 at 1:26 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Because it is a fixed size do it all that probably will not have your trailer level, which will affect towing stability.
  6. Sep 7, 2021 at 1:33 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have one, they are good for higher trailers and I do use it when I need the extra height. The straight design works well for boats, and other taller trailers, like rentals. But for my utility trailer and pop up, need the drop hitch.
  7. Sep 7, 2021 at 2:18 PM
    Outbound
    Aaron
    Northern Alberta
    Cool, thanks for the thoughts guys. I can see the straight hitch being a bit problematic for lower trailers. I think I'll stick with my current hitch and swapping balls.
    GODZILLA likes this.
  8. Sep 7, 2021 at 2:28 PM
    Used many of them with no I'll effects. As you stated, the downside is there is not drop or rise adjustment.
    Outbound[QUOTED][OP] likes this.
