3" Lift TSS sensor not working properly
Discussion in 'General Tundra Discussion' started by FlipMonkey21, Sep 22, 2019.
  1. Sep 22, 2019 at 8:42 PM
    FlipMonkey21
    FlipMonkey21 [OP] New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    So after getting the truck lifted I notice that the TSS sensor does not response or work properly. Is that normal and is there a fix for it? Thank you.
  2. Sep 22, 2019 at 11:01 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Your dealer will need to re program the TSS system on your truck. Mine did the same thing.
  3. Sep 26, 2019 at 10:21 AM
    FlipMonkey21
    Mark
    SoCal Glendale
    do they charge you for the reprogramming?
  4. Sep 26, 2019 at 10:40 AM
    FlipMonkey21
    Mark
    SoCal Glendale
    Cool I will check my local toyota dealer then. Thank you.
    OR18TRD[QUOTED] likes this.
  5. Sep 26, 2019 at 10:25 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    Depending on which 2019 Tundra you have, it may or may not have the recall / software update for it. You can see details here: https://www.tundras.com/threads/two-new-recalls-koa-and-kob-pcs.43075/
    Some of the 2019s already have this completed before sale.
    Lifting the truck has been known to cause issues with the radar sensor getting off alignment. Some people have issues after lifting, some do not. At first, Toyota would not perform the recall work if you lifted your truck (or even put on bigger tires in some cases) but now they do, they just make you sign a waiver releasing liability. From what I understand, lifting the vehicle isn't as much of a problem as changing the angle of the vehicle (i.e. - raising the front and rear different amounts or 'leveling' it).
    Start with checking if you have an open recall for it (you can just call your dealer, give the VIN and ask if there are any open recalls to be done) and go from there.
    OR18TRD likes this.
  6. Sep 26, 2019 at 11:34 PM
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    I have a 3/1 level from readylift on 35’s, no issues with sensor. It’s hit or miss.
  7. Sep 27, 2019 at 2:45 AM
    RLHULK
    Rich
    2022 Silverado LT.
    It was included in the labor charge.
