3.5 lift
Discussion in 'Suspension' started by Chingo31, Oct 13, 2021.
  1. Oct 13, 2021 at 7:06 AM
    Chingo31
    Chingo31 [OP] New Member
    2019 Toyota Tundra 1794 4X4
    Lift Kit
    Just installed RC 3.5 lift. Aligned but it’s still pigeon toed. Was told to get adjustable control arm. Not sure why it can’t be aligned properly with control arm provided. Should I buy the adjustable control arm?813FCA25-FEBE-4DAE-84D7-C02876F2226B.jpg
  2. Oct 13, 2021 at 7:12 AM
    2mchfun
    What UCA did you use? Did you tighten LCA with truck in the air or on the ground?
  3. Oct 13, 2021 at 7:23 AM
    Chingo31
    Lift Kit
    I used the UCA provided with the kit. I took it to Les Swab for alignment. Leveled on the floor.
  4. Oct 13, 2021 at 7:28 AM
    2mchfun
    So again, did you tighten the LCA bolt with the truck elevated?
  5. Oct 13, 2021 at 7:30 AM
    Chingo31
    Lift Kit
  6. Oct 13, 2021 at 7:32 AM
    2mchfun
    Well, that is part of your problem. Now loosen them and roll the truck a bit then torque them with the truck on the ground. You have the bushings in a bind right now.
  7. Oct 13, 2021 at 8:22 AM
    My suggestion is yes. With after market UCA’s you can achieve better alignment results
  8. Oct 13, 2021 at 9:48 AM
    Chingo31
    Lift Kit
    Just checked the camber is completely maxed out. Manufacture says it should work.
  9. Oct 13, 2021 at 9:55 AM
    2mchfun
    You will risk ruining your LCA bushings if left uncorrected. Do your truck right and correct your mistake, then do alignment.
  10. Oct 13, 2021 at 10:02 AM
    Chingo31
    Lift Kit
    So loosen the LCA roll it back and tighten?
  11. Oct 13, 2021 at 1:29 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    I don’t know what pigeon toed means but you definitely don’t have enough caster and need upper control arms. While the LCA bolts do need to be torqued with the truck on the ground that should have been dealt with when it was aligned.
  12. Oct 13, 2021 at 1:38 PM
    Chingo31
    Lift Kit
    Now that I’m looking the tire size recommended is 295/60r20. Would this help out?
  13. Oct 13, 2021 at 1:43 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Nope. Tire size has nothing to do with alignment.
  14. Oct 13, 2021 at 1:46 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    No - caster is what keeps the truck driving straight and returns the wheel to center. You’re measurements are 1.4/1.9 and you generally want 3-4 degrees if not more. Lifting reduces the amount of caster available on the stock components and the way get more caster is replacing the upper control arms.
  15. Oct 13, 2021 at 4:22 PM
    Chingo31
    Lift Kit
    What adjustable upper control arm do you recommend?
