3.4 TT detailed specifications..?
Discussion in '3rd Gen Tundras (2022+)' started by Soupbean77, Mar 5, 2023.
  1. Mar 5, 2023 at 8:38 AM
    Soupbean77
    Soupbean77 [OP] New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Curious to know more detailed specs of the 3.4 TT. It’s an all aluminum 24 valve vvt-i with dual variable valve timing..? Twin turbo, obviously assuming one for each bank of cylinders ?
    Wondering if anyone knows if turbos are making any boost right from idle ? They work in parallel creating identical boost to both banks ? Would be interested in seeing HP/TQ curve in relation to rpm, throttle opening and load. Just wondering if anyone is aware of more technical specifications…
  2. Mar 5, 2023 at 9:11 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
  3. Mar 6, 2023 at 3:07 AM
    Soupbean77
  4. Mar 6, 2023 at 4:16 AM
    Do any turbos do that? Turbos require exhaust gas in large volumes to produce boost. At idle, with no load on the engine, not enough exhaust gas is being produced, In any engine. Even if you cranked the idle up, with no load on the engine, still not enough exhaust gas. Since the Tundra uses s-medium sized turbos, they will spool up quickly and produce boost at a lower rpm than a larger turbo would, but you are probably looking at 1200-1500rpm before you start to get the boost.
  5. Mar 6, 2023 at 5:26 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
  6. Mar 6, 2023 at 11:24 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
