3/4 Ton Truck
Discussion in 'Towing & Hauling' started by A-A-Ron, Jun 15, 2020.
Best New 3/4 Ton Diesel Option
  1. Ram
    26.3%
  2. GMC
    40.5%
  3. Ford
    33.1%
  1. Jun 15, 2020 at 10:15 PM
    A-A-Ron
    A-A-Ron [OP] Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    Like many of you on the forum I over analyze everything truck related. Earlier this year I purchased a travel trailer that maxes out my Tundra, I think 2021 will be the year of the 3/4 ton diesel upgrade. Would like some feedback from the unbiased Tundra community on which domestic I should consider. Going diesel for the ease on hills, the gas HDs aren’t much of a power upgrade. Leaning towards the Ram, I heard the German transmission is excellent and the rear coil springs ride well for an HD. New Chevy HDs are extremely ugly and excluded, GMC will fill in. Would be new or a year old, plan to daily drive it then make it a second vehicle at 100k miles.
  2. Jun 15, 2020 at 10:43 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Hi a Ram 3500 has an Aisin trans in it now which is way better than the 68RFE trans theirs Rumors of a ZF 8-9 speed trans in the near future but just rumors they are having good success with the Aisin Japanese trans in the HD Dodge.
    The Gm HD has a 10 speed Allison which is a very good trans the duramax is the quieter of all the Diesel engines but Cummins is a beast I’m not a fan of the Ford sorry
    My choice would be the Ram even tho I’m a GM guy I feel like the Ram for towing is the best in this situation just my .02
    HappyTraveller, Jake91 and Black Wolf like this.
  3. Jun 16, 2020 at 12:41 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
  4. Jun 16, 2020 at 1:59 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Tow companies are moving to Rams because the Fords have turned into garbage. Do with that information what you will.
    jordoncloutier likes this.
  5. Jun 16, 2020 at 3:00 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I would rather have my balls hammered flat than buy an FCA product.
  6. Jun 16, 2020 at 3:19 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I don’t care who you are, but that shits funny! Good luck.
  7. Jun 16, 2020 at 5:34 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    They all have their issues - Ram's can't keep front ends in them, so companies that do off-highway business stay clear; Ford's have electrical issues that may or may not pop up; and GMC's (and Chevy somehow) get uglier the more I see them on the road, the side profile is just wrong, and if the reliability of the half tons creeps into the HD trucks then look out. And all of them have emission issues as the big downfall. Right now if I had to I'd likely pick a Ford, but I'd make sure I have a reliable second vehicle for when it's likely to be in the shop.
    Jack Burton and Sundown5oh like this.
  8. Jun 16, 2020 at 6:23 AM
    A-A-Ron
    Aaron
    Seattle
    There is one limiting factor for me. It will be on my workplace’s vehicle allowance program that doesn’t allow 1 tons, will need to be 3/4 ton.
  9. Jun 16, 2020 at 6:26 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    They all have their own issues like with everything. I will never own a Ram as I think their quality is still shit. GM would be my second choice. I have owned multiple Duramax trucks and multiple Powerstrokes. Both have been good, but I prefer my Ford.
  10. Jun 16, 2020 at 6:27 AM
    This is personally what I did:
    Researched the following- cost of ownership, ease of maintenance, tire size and cost since they don’t last for nothing. I just rolled 50,000 miles yesterday and I’m into my third set of tires. Two sets of Michelin AT2 and now the Cooper XLT. The Coopers are going fast though. I'm thinking 30-40K miles out of them....maybe.
    Reliability. Check with several local diesel repair facilities. Ask what trucks they seen problems with and repair cost. For instance, I would not buy a "baby" Duramax 2.8L. To change out the timing belt, you have to drop the transmission, since the belt is in the rear of the motor. I just shake my head at that.
    Look at injector cost, filters, transmission replacement, periodicity of maintenance items.
    One of my bosses just switched over from being all GM to Ram. He purchased 2019 Ram 2500 and 2020 Ram 1500. His diesel GM was a 2002 with 170k miles. Kinda hard to compare 17 year old trucks in performance and features. He went Ram due to cost. He was able to pick up a new 3/4 ton truck for 51K. GM wasn't even budging at over 60K. I feel into that as well with my two Dodges. Then again, I also paid for it in repair bills as well.
    So I’m just gonna day it, I’m not a Dodge fan. In particular not a Cummins fan in a light duty truck application. If you do go Dodge, I would select the 3500/1 ton to eliminate the coil rear suspension. This is an image of the rear suspension. Let’s talk about this for a minute.
    I’m sure you all have heard about death wobble. This is caused by track bar bushing wear. Dodge, Ford, and Jeeps are known for it since they run solid front axles and a 5 link suspension system. Dodge still has a 5 link front suspension...and now a 5 link rear, with a anti-wrap link to boot (see center of axle). Two weekends ago I was following a Ram 3/4 ton that probably had some miles on it. He was empty except bed mounted boxes. That truck was all over the place. I actually almost called Colorado Highway Patrol until I seen what was going on. Every time he hit a bump, the ass end of the truck would shake and send the truck into a shift and what almost seemed like death wobble. Yeah...no thanks.
    The 3500 has a radius arm front suspension with coil springs which is a lot stronger than links. Another bonus is you can get the HO output cummins with the Aisan transmission. However, since I just seen you post the truck has to be a 3/4 ton....easy decision for me then. GMC.
  11. Jun 16, 2020 at 6:29 AM
    Since you won't be upgrading until next year, I wouldn't put the new Tundra out of the race. Heard some pretty amazing numbers coming from all of the "rumors" in the past 6 months.
    Black Wolf and Malinois38 like this.
  12. Jun 16, 2020 at 6:31 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  13. Jun 16, 2020 at 6:36 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    ColoradoTJ, been meaning to ask you what is the difference between the GM twins as far as 3/4 tons go? Is there anything or is it just brand difference and looks?
  14. Jun 16, 2020 at 6:38 AM
    For some reason I thought Ford was out for you @A-A-Ron. If a 3/4 ton truck is the max you can go, I wouldn't put a 6.7L powerstroke out of the running either. Damn nice trucks and pull hard. 90% of my friends have them with minimal issues. Only one of my buddies has a F350 that causes him headaches all the time. I do believe it's self induced headaches though.
    LS Powah, Black Wolf and Stroke250 like this.
  15. Jun 16, 2020 at 6:38 AM
    Redcon41318
    Redcon41318 New Member
    For new diesels, I dislike emission regulations. I would honestly get a gas ford 6.2 F250. But i love my families 2006 6.6 duramax!
    i love my tundra but i wouldNt pull more than it could handle.
    JustJake likes this.
  16. Jun 16, 2020 at 6:40 AM
    Option/appearance packages. We used to always joke around and say "GMC are chevy's with the bolts torqued"....
  17. Jun 16, 2020 at 6:41 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  18. Jun 16, 2020 at 7:01 AM
    Redcon41318
    I feel 3/4-1 ton trucks have their duty, but got dam tundras are built better and feel more solid, power train wise compared to American brand trucks.
  19. Jun 16, 2020 at 7:01 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Before 2020, I would have said GM was the most reliable with Ford a close second. Have to see if the T1 HD GMs have as many problems as the 1500s. Already have some reports of leaking sliding rear windows but that's easily resolved by getting a truck with a fixed rear window.
  20. Jun 16, 2020 at 7:07 AM
    Well I'll be damned, they front ends did go with the radius arm suspension.
    I still wouldn't go with a 3/4 ton ram, but that's just my preference. Your GF says she likes it a lot and very comfy. Decent fuel economy as well. I don't get that kind of fuel economy though. Yesterday I was at 11.5 mph at best, but towing 11K in town.
  21. Jun 16, 2020 at 7:10 AM
    2017 and 2019 GM's have had their issues for sure. I wouldn't own those years either. 2017 had emissions issues and the 2019 has brake issues. No thanks.
  22. Jun 16, 2020 at 7:31 AM
    I’m also not brand loyal either.
    My wife had to threaten divorce so I wouldn’t bring home another Dodge. Lol
    I’m not gonna lie, I looked at a 3500 in secret.
  23. Jun 16, 2020 at 7:31 AM
    A-A-Ron
    Aaron
    Seattle
    Ha ha! Maybe one of the hydrogen/electrics some day, at least one that wasn’t designed by a 5 year old. Their cars look amazing but their truck still feels like a joke.
    el_conquistador and Black Wolf like this.
  24. Jun 16, 2020 at 7:32 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    As far as I understand, it's legal to delete the emissions equipment here. That's probably the first thing I'd do if I bought a diesel.
  25. Jun 16, 2020 at 7:38 AM
    A-A-Ron
    Aaron
    Seattle
    I’m still holding out some hope for a new Tundra. Would need to be a big step up in the payload/towing and the power. Looking forward to some facts to take over the years of rumors.
  26. Jun 16, 2020 at 7:54 AM
    belanger9
    Edmonton, AB
    A bunch
    Next February at the earliest is when we'll get numbers, but I'm thinking more like a year. So that's 2 summers of sketchy towing if you decide to even pull with the Tundra. May as well just buy a diesel now so you can get those 2 summers of camping and memories.
    If you're still within the limits but want more confidence you could look at improved bump stops (Sumo Springs or Timbrens) or go for air bags to help. I feel like the Tundra could be rated at 2500 lb payload and 15k lb towing if only it had stiffer leaf springs - not going with 3" leafs is killing the ratings with how weak they are.
  27. Jun 16, 2020 at 8:58 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Well.... Had diesels before the Tundra. Where I work, we have around 15 Ford and GMC 3/4 ton and 1-tons. All diesels. All are between years 2014 to 2019. All get crews put in them daily and driven to job sites. Some with 300k on them.
    The Duramax/Allison combo is for sure the most reliable and the better platform. I base this off of the expense tracking and the Ford's have cost us much more to operate. They will nickel and dime you and we have had some larger repairs that we plain have not had with the GMC's. My diesels were between 2004 to 2016. All my buddies always had Ford's and issues were a plenty. I can honestly say I never had and issues what so ever with my Duramaxes.
    Now to be fair to Ford, we also have 9 F450 to F750's. Admittedly, they have been pretty good and been good to us.
    Our mechanics will put the Ford's in the lift and go through the wiring and other things on the bottom. Some not in looks, etc.... They can see why they have el tribal problems.
    We also have 2 older Dodge's 1-ton flatbeds that seldom get used. Nothing catastrophic but something little always to deal with.
    I would go GM with the Duramax/Allison. They ride better than the others also.
  28. Jun 16, 2020 at 9:12 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I would go with what @1UPPER has. That truck is a beaut!
    1UPPER and Cfincke like this.
  29. Jun 16, 2020 at 9:12 AM
    A-A-Ron
    Aaron
    Seattle
    I’ve done two trips so far, had several more canceled reservations. I’m still within the rated capabilities but I have to stay dry, pack somewhat light and mostly in the trailer. I was very impressed on how it handled going over the windy Tacoma Narrows bridge. I thought about air bags but the WDH really seems to balance it out well. The biggest weakness I have felt so far is the power going up hills. The lift and the 295/70-18’s aren’t doing me any favors either. Put it in S mode and watch the trans temp on my Scan Gauge as I slowly creep up the hills. My truck is paid off, won’t be in a position to take on another truck payment until next year.
    ColoradoTJ likes this.
  30. Jun 16, 2020 at 9:12 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Forgot to share my uncle's experience with diesel one tons on his farm and ranch.
    Caveat: he only buys used, typically from auction, tries to buy cheap, works his stuff hard and treats it poorly.
    He had a 1993 Dodge Cummins that he ran for about 15 years. I didn't hear about too many issues with it, though it had some odd design quirks that made it tough to live with.
    Replaced that with two Ford Powerstrokes. Both were garbage and he got rid of them quickly.
    Since then, he's gone back to Dodge. He's had two in the last 12 years or so. The turbo went out in his current truck a while back and he's still waiting on parts but, as far as I know, that was the first major issue he had with it. Not sure how the interior and features have fared over time, though.
    At one point he had to repair his Land Rover and get it running so he could use it to haul oats while his Cummins was out of commission. :facepalm:
    Black Wolf likes this.
