3/2 lift do you guys like the look or would it be better more leveled
Discussion in 'Suspension' started by Roborbob33, Jul 25, 2022.
  1. Jul 25, 2022 at 7:21 AM
    Roborbob33
    Roborbob33 [OP] New Member
    2015 black tundra crew max 5.7 Sr5
    Katskin leather seats. And 3/2 lift with 295/60/r20 20x9 fuels
    I got a 3/2 lift with 295/60/r20 on 20x9 I love it but it’s definitely not as level as I wanted it to be. I’m not a fan of the stock rake in trucks I know it serves a purpose but I hate it. This isn’t too bad tho I think I can live with it. But I’d appreciate your guy’s opinion
  2. Jul 26, 2022 at 7:32 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I like some rake personally, as I do haul and tow at times and I do not like the look or handling when the truck squats and is nose high.
    bflooks and DIYDad like this.
  3. Jul 26, 2022 at 7:57 AM
    YouFallWeHaul
    YouFallWeHaul New Member
    2010 Marine Blue DC 4x4
    If you happen to be in an area that sees winter/snow, and want to put sand or other weight in the back for traction, this is another good reason to leave it slightly raked when unloaded. Here in the Northeast, you see a lot of trucks in winter with a bit of silly squat to them from tube sand.
  4. Jul 26, 2022 at 8:06 AM
    RobertD
    Robert
    DFW, Texas
    It really depends how you use your truck. If its never loaded and you just ha e folks in the cab, being the nose up the other inch to level it out. But as the others have stated, if you load up the truck or haul anything you will likely become nose high which normally looks worse than the 1" rake you have.
    But its your truck! Do what will make you smile everytime you see it and during each session behind the wheel :thumbsup:
    DIYDad likes this.
  5. Jul 26, 2022 at 8:15 AM
    To me it looks level in the 2nd pic.
  6. Jul 26, 2022 at 1:33 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I think it looks nice with a little rake. And that it’s black too. :thumbsup:
  7. Jul 26, 2022 at 1:35 PM
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    I agree with most here. Leveling kits make it look okay but as soon as you put anything in the bed you’re squatting.
  8. Jul 26, 2022 at 1:36 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I think it looks perfect. I have a 2 inch front 2.5 inch rear and its slightly too ass high, but i need it since i run at almost max payload alot of the time with the whole fam and gear. It might also be the diamondback that makes it look a little higher than it is.
  9. Jul 26, 2022 at 1:40 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Mine was completely and perfectly level. It looked good most of the time. Sometimes it looked level but a lot of the time it looked like the front was higher than the back depending on the slope of where it was parked. It looked like hell every time I towed a trailer, sat on a slope or had a load in the back. Just yesterday I lifted the back so that my lift is about 3 inches in both the front and the back to fix that. Now I have my stock rake back. I don't like the look as much on level ground but it is better to tow or haul loads with.
    RobertD likes this.
  10. Jul 26, 2022 at 1:46 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm with everyone else here and like it. I'm biased as I have a 2" rake after lift, but I feel a little rake makes it look more rugged and purposeful.
  11. Jul 26, 2022 at 1:55 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    The only thing wrong with the look of your truck is all the rain drops on it.
  12. Jul 26, 2022 at 2:36 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    When I had my 6112s installed my truck pretty much sat level.
    Every time I made a fast turn some nanny crap would go off.
    There is a sensor under the console that detects rake or lack thereof.
    You can put a spacer under one end of it to simulate rake, but I ended up getting Toytec shackles and putting them on the 1" setting.
    When it was level..
    It looks nose high but measured perfectly level.
    763B91DF-899D-4443-A7EC-B9CE39DA5452_zps_bea47deabf8dc5fbeea4cb3cdbc4cdc119d6b1b5.jpg
    BAAB1B4D-343A-41B7-90CF-D7BBCE1A53C3_zps_390a98c7984fc43142a5ae989679ec9c3d8014be.jpg
    With the shackles..
    942B7FE5-470C-4383-9C30-59887BC9D6D9_zps_a8747e7bccd94158852fe28b2148e53e73e14110.jpg
    The shackles on the higher setting was too high..
    A1236474-134A-4520-8381-00AB5F6E2B1C_zps_dd0805a91c7bcbed3a20f60d75f47d5614182281.jpg
    RobertD likes this.
  13. Aug 5, 2022 at 7:47 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    We have pretty much the same setup but I went with a 3/1 lift instead of the 3/2. I prefer the more leveled look. But your truck by no means looks bad whatsoever. Here is mine compared to stock.
