3/1 vs 3/2? Toytec suspension lift
Discussion in 'Suspension' started by Tundra07Limited, Dec 29, 2019.
  1. Dec 29, 2019 at 10:01 AM
    Tundra07Limited
    Tundra07Limited [OP] New Member
    2007 Double Cab Limited Timberlan Mica with ARE Overland Shell in Black
    non yet
    I just picked up a 2007 double cab limited with 100,000. I called toytec and discussed all my needs.
    They recommended I get off road as much as the next guy, but my days of driving toward obstacles were left in my 20s with my ability to function on a hangover.
    So I'm definitely going with a Eibach 3" coil over in the front with the Boss shocks in the rear. They said to go with a 1" or 2" block in the rear. They said 1" if I want level and 2" if I want a little rake. The thing I want to avoid is having a taller front end after a few years of wear and towing my camper. I usually have a few tool bags or other random items in the bed. I also plan on getting a aftermarket steel bumper. I guess what i'm saying is there's typically a small static load (100-200 lbs) in the rear.
    Anyone have experience running factory leafs with the 1" block? how is the level when carrying a light load?
    Any input would be appreciated.
    p.s. toytec said there's not ride improvement with taller shackles so I'm going with blocks.
  2. Dec 30, 2019 at 6:03 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Go with the 2” block. That will give you approximately 1” of rake empty depending on the condition of the leafs. The 1” will definitely promote a nose high stance at 3” of lift.
    Hope this helps
    Joe S
    A-A-Ron and Tundra07Limited[OP] like this.
  3. Dec 31, 2019 at 6:53 AM
    Tundra07Limited
    non yet
    Thanks @WestexSBK. That’s what I was thinking, but I wanted to here others opinion on it before I pulled the trigger
  4. Dec 31, 2019 at 7:26 AM
    WestexSBK
    No problem sir. I’ve heard the same about TT shackles but I’ve heard the Poly bushings on the coach builder shackles improve the rears dampening
  5. Dec 31, 2019 at 7:34 AM
    The TT poly bushings with the TT shackles help too. Had them on my 07. Bed bounce not near as bad. Same polys that CB uses.
  6. Jan 7, 2020 at 1:16 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I ran a 1” in block for a couple years then switched to 2” shackles I like the rake of a 3/2. And the ride going from a block to shackles was very noticeable. Pro form shakes are super beefy pair them up with poly bushings and you’re set.
    Here’s what I bought these are 1.5” but if you contact them they have 2”....you can’t beat the for $60
    https://www.ebay.com/itm/2007-2018-...ft-Shackle-Kit/193287908853?fits=Model:Tundra
    Here’s mine out of the box
    drobb and AZTundra like this.
  7. Jan 11, 2020 at 10:42 AM
    Resnikphx
    Resnikphx New Member
    I did the 3" boss with leaf expansion... 1.5" rear lift. Looks great and have about a half inch rake.
    drobb likes this.
  8. Jan 11, 2020 at 11:09 AM
  9. Jan 11, 2020 at 11:26 AM
    Resnikphx
    I did, Icon UCAs... Ride is great.
