3/1 ready lift with bilsteins 5100 on lower notch
Discussion in 'New Member Introductions' started by Tepa1978, Nov 5, 2023.
  1. Nov 5, 2023 at 7:53 AM
    Tepa1978
    Tepa1978 [OP] New Member
    Nabor
    2017 tundra sr5 trd off road pack
    3/1 ready lift with bilsteins 5100 lower notch
    New to the forum just got this 17 tundra and add the 3/1 ready lift along with bilsteins 5100 on lower notch and uper control arms does anyone did this before cause my end up with about 1 rake to the front rides great just curios if anyone did this before
  2. Nov 5, 2023 at 9:06 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Respectfully, why did you chose this setup vs using the 5100’s to lift?
  3. Nov 5, 2023 at 9:12 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There is no way that rides well
    Sierradevil and 1lowlife like this.
  4. Nov 5, 2023 at 9:14 AM
    Jorgy1
    Jorgy1 New Member
    Shaun
    Lethbridge AB
    2019 MGM Tundra CrewMax 4x4
    5100s on the bottom setting will provide 3/4 to 1" of lift if I'm not mistaken. Combined with the 3/1 Readylift will give 4". I guess it should work if you can get alignment dialed in.
    windblown101 likes this.
  5. Nov 5, 2023 at 9:17 AM
    Jorgy1
    Jorgy1 New Member
    Shaun
    Lethbridge AB
    Oh, and welcome to the forum OP!
  6. Nov 5, 2023 at 9:19 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I thought the lowest notch was factory height…but if I am incorrect that’s a valid point.
  7. Nov 5, 2023 at 10:42 AM
    Tepa1978
    Nabor
    Exactly right I get about 3/4 " high over stock 3/1 this way
  8. Nov 5, 2023 at 10:45 AM
    Tepa1978
    Nabor
    And Hbjeff it does ride awesome this way you put less stress on the bilsteins on my opinion I had them before with the top notch and it was by far worst
  9. Nov 5, 2023 at 12:20 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The problem is that you’re gonna hit a big enough bump to compress shock too far, unless you’ve extended your bumpstop by almost 2 inches. In which case youre gonna be hitting them more often
    Sierradevil likes this.
  10. Nov 5, 2023 at 1:42 PM
    Tepa1978
    Nabor
    Yep got that also sumospring front and rear bump stops
  11. Nov 5, 2023 at 1:44 PM
    Tepa1978
    Nabor
    Awesome bump stops on my opinion can recommend enough
  12. Nov 5, 2023 at 1:58 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  13. Nov 5, 2023 at 2:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    you still need to find out height of sumos under full compression vs stock. It is possible they are too short still
  14. Nov 5, 2023 at 3:54 PM
    biebs96
    PA
    It looks like there is too much going on. Two different types of lifts installed together.
    If you are set on using the ready lift 3/1, remove the 5100s and put in an upgraded version of stock length shocks.
    Personally I would remove the ready lift and put the 5100s at the top ring, or middle with a couch builder shim or two on each side.
    This will give you the desired lift and not run the risk of jamming the shock mount into the shock itself.
    Unfortunately it looks like you might be a pivotal buy once, cry once point in your build. But hey, that means things can only get better… (cough, cough… wheels and bigger tires)
  15. Nov 5, 2023 at 8:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
  16. Nov 6, 2023 at 1:35 PM
    Welcome from NY.
  17. Nov 22, 2023 at 1:45 PM
    Tepa1978
    Nabor
    Thanks Jim le 1301
  18. Nov 22, 2023 at 1:47 PM
    Tepa1978
    Nabor
    New wheels and tires 295/65r20 nitto ridge grappler on 20x9 gear off road wheels +18
    windblown101, Jorgy1 and biebs96 like this.
  19. Nov 25, 2023 at 11:13 PM
    MoistPigeonNips
    MoistPigeonNips Birds Aren’t Real
    2002 V8 SR5 4x2 AC
  20. Dec 3, 2023 at 11:54 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  21. Dec 4, 2023 at 5:01 AM
    Tepa1978
    Nabor
    Thanks RitcheyRch
