3/1 Pro comp lift and level. 295/70/18
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dgjman, Feb 21, 2020.
  1. Feb 21, 2020 at 6:06 PM
    Dgjman
    Dgjman [OP] New Member
    Gilbert Arizona
    2015 limited crewmax
    3/1 Pro Comp lift and level. 295/70/18 tires Black Rhino Arsenal wheels
    Well I finally pulled the trigger and got it done. I stalked this forum for months now gleaning all the information I could about lifts and tires and wheels. I finally did it, thanks guys!
  2. Feb 21, 2020 at 6:08 PM
    Dgjman
    Gilbert Arizona
    Nfab nerf bars coming next week
  3. Feb 21, 2020 at 6:15 PM
    Julssellers
    Julssellers New Member
    Julian
    2018 White Toyota Tundra SR5
    Stock for now
    Looks great
    Dgjman[OP] likes this.
  4. Feb 21, 2020 at 6:18 PM
    Dgjman
    Gilbert Arizona
    Thanks Jussellers!
  5. Feb 21, 2020 at 6:23 PM
    somadbamos
    somadbamos Dude, you're being totally undude.
    Jake
    Idiot Out Wandering Around
    '14 Crewmax w/ Attitude
    Nice! What offset are your rims? Any rubbing?
  6. Feb 21, 2020 at 6:25 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    'bout time you signed up on here! Looks good!
  7. Feb 21, 2020 at 6:26 PM
    Dgjman
    Gilbert Arizona
    Somadbamos the offset is +12
    No rubbing
    Took off flaps
    somadbamos likes this.
  8. Feb 21, 2020 at 6:59 PM
    somadbamos
    Jake
    Awesome, thanks for the info.
    Dgjman[QUOTED][OP] likes this.
  9. Feb 21, 2020 at 7:03 PM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome and nice truck!
  10. Feb 22, 2020 at 6:42 AM
    2chains
    2chains New Member
    Southern Ablerta
    Looks great! Could you post the fender measurements at each wheel?
  11. Feb 22, 2020 at 9:22 AM
    Dgjman
    Gilbert Arizona
    I will as soon as I can
  12. Feb 22, 2020 at 12:45 PM
    Dgjman
    Gilbert Arizona
    I love the way it looks!
  13. Feb 22, 2020 at 12:48 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Which Nfabs are you looking at? I just put some on mine a couple weeks ago, you should check them out.
  14. Feb 22, 2020 at 1:10 PM
    Dgjman
    Gilbert Arizona
    Those are pretty sharp! I am going with the tubular ones
  15. Feb 22, 2020 at 6:55 PM
    tdiantonio
    tdiantonio New Member
    Lift and rims look great!!
  16. Feb 23, 2020 at 10:16 AM
    xX1794TRDXx
    xX1794TRDXx New Member
    2016 White 1794 Edition
    TRD Exhaust, Grille Guard w/ 2 KC Lights, Running Boards, TRD Intake, Etc
    Do you know what tire size I can run for KO2s if I keep my stock 20inch 1794 rims? Thanks.
  17. Feb 23, 2020 at 10:18 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Second Gen (2007-2013) and Third Gen (2014+) Tundra
    No Lift Kit
    Max tire sizes are:
    • 18″ rims: 285/65 R18 – 5/10ths taller and 4/10ths wider than factory. Trimming may be necessary.
    • 20″ rims: 275/60 R20 – one inch taller but same width as factory
    https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
  18. Feb 23, 2020 at 11:19 AM
    Dgjman
    Gilbert Arizona
    Front- bottom of fender to top of tire is 8"
    Side fender to tire is 3"
    Rear- bottom of fender to top of tire 8.75"
    Side fender to tire is 3.75"
