3/1.75 Tire fit
Discussion in 'Wheels & Tires' started by UTAHRTK, Apr 11, 2018.
  1. Apr 11, 2018 at 5:41 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have done quite a bit of research on here as well as reached out to experts regarding biggest tire I can fit with 3/1.75 suspension lift. I have a 17 TRD CM with 20x9 with offset of 40. I do not want to do CMC at this time and would love to fit 295/60/20s. Optimally an aggressive A/T -Looking at Ridge grapplers and STT, Toyo A/TAnyone with a similar set up? Input greatly appreciated.
  2. Apr 11, 2018 at 9:55 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    What level kit are you going with ?
  3. Apr 11, 2018 at 11:04 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    you can clear that size safely. Im running 295/70R18 with the same lift and clear it without doing the CMC. I know some people that clear it with a 35x12.5 also but stick with the 295 if you want to be safe.
  4. Apr 11, 2018 at 11:06 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have 18 mm offset wheels with 295/70/18. Assuming that you have 9 inch wide wheels, my tires are larger and also significantly closer to the body mount than your proposed set-up. I have no rubbing on the body mount.
  5. Apr 11, 2018 at 11:23 AM
    UTAHRTK
    SOCAL
    Thanks. Badass rigs! Going with 6112/5150; TC UCA; CB Shackles and stuff. Thanks for the info- feel'n good about pushing forward.
  6. Apr 11, 2018 at 11:23 AM
    UTAHRTK
    SOCAL
    *5160
  7. Apr 11, 2018 at 11:28 AM
    UTAHRTK
    SOCAL
    IMG_2728.jpg she's got a way to go but damn if the $$$ doesn't add up. Stock but added the grill and a few accessories. once lift & tires done I will be getting Demello sliders and swapping headlights to 18 LED...IMG_2728.jpg
