3.0 coilover with tie rod contact
Discussion in 'Suspension' started by 14burrito, Jul 31, 2018.
  1. Jul 31, 2018 at 6:31 AM
    14burrito
    14burrito [OP] IG @14burrito
    2014 SR5 CM 4x4 5.7
    There were a few members I remember reading about contact issues when running 3.0 coilover.
    Those with 3.0s, regardless of contact issues, can you post up which coilovers and which control arms your running along with alignment specs. Please mention whether or not you have contact with the tie rods and when that contact occurs (static wheels straight forward, full lock, or otherwise?)
    If you had contact and fixed it, what did you do to remedy the issue?
    Please lets not turn this thread into a UCA battle of well theirs has so much x built into it vs this one and blah blah. Thanks
    blue16, TheBeast and GodlessPro like this.
  2. Jul 31, 2018 at 7:40 AM
    15whtrd
    15whtrd Mr. Blonde
    I thought I read about the tie rods need the threads trimmed?
  3. Jul 31, 2018 at 7:42 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    That's a seperate issue with toe rod adjustment for those not getting proper toe/camber numbers.
    TheBeast and 15whtrd[QUOTED] like this.
  4. Jul 31, 2018 at 7:54 AM
    15whtrd
    15whtrd Mr. Blonde
    I thought that was for both clearance and to get the numbers right. Doesn’t dirty deeds or coachbuilder make something for that?
    831Tun likes this.
  5. Jul 31, 2018 at 7:58 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I heard swapping outer may help, dont recall 100. You may be right....my simple mind can't see how shortening the inner would clearance the contact issue.
    CB tie rod ends I believe are much larger, not sure how that would help either. But if someone posted examples, again - my simple mind.
    15whtrd[QUOTED] likes this.
  6. Jul 31, 2018 at 8:17 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    ADS 3.0 coilover
    Camburg 1.5"
    Alignment = caster 7%, camber -.1*
    Does not contact at any point during travel, at full lock, the tie rod boot barely touches the outside of the spring. There are no signs of rubbing or wear. I did not swap/turn around tie rod ends.
    The clearance is pretty tight however. I can take pics if needed.
    14burrito[OP] likes this.
  7. Jul 31, 2018 at 8:20 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Perfect, great info - thank you!
    Hate to bother with pics, but if you wouldn't mind when you have a few minutes :)
  8. Jul 31, 2018 at 8:38 AM
    d0zer
    2017 MGM Platinum
    No worries, the reason I got these coilovers was this site! Why spend $300 on 5100s when I can spend 5k on ADS!
    Passenger side pics straight ahead.
    Clearance is probably a 1/2" maybe a little more.
  9. Jul 31, 2018 at 8:41 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    ADS 3.0 coilovers
    MCM UCAs
    Caster 3.3° left, 3.6° right
    I contact a full lock. I'm going to take my truck back and have them increase the caster another .5° to see if that clears it up. Too much caster is a bad thing from what I have heard, 7° sounds extreme.
    @joonbug @TRD15559 also have 3.0's
  10. Jul 31, 2018 at 8:45 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I believe the trimming of the inner tie rod threads is the solution for the bad alignment #s. Specifically, it's an attempt to correct the improper geometry of Icon tubular UCAs. This didn't make sense to me so I replaced the defective arms with MCM and couldn't be happier. I stacked the Icons on top of the MCM before install and the problem is clearly visible. Icon arms are wrong...... IMO
    ARES, TexasTundra27, TheBeast and 3 others like this.
  11. Jul 31, 2018 at 8:47 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think I caused steering rack issues with too much caster but haven't fixed it yet. BTW you need some dirt on that suspension,,,,,, way too clean unless you're headed to the mall.:boink:
  12. Jul 31, 2018 at 8:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I had to slide the boot up some. And sacrificed caster because I have the garbage ass Icon tubular UCAs. They need to either correct it or just stop selling them.
  13. Jul 31, 2018 at 8:51 AM
    d0zer
    2017 MGM Platinum
    I spoke with camburg, they said they see 6-7.5 caster with their arms. I think next alignment (when i get new tires) I'll probably try camber at -.25 to get caster in the low 6's, if possible.
    GodlessPro[QUOTED] likes this.
  14. Jul 31, 2018 at 8:52 AM
    d0zer
    2017 MGM Platinum
    What rack issues you have? I have about 10k miles with the specs I'm on.
    831Tun[QUOTED] and GodlessPro like this.
  15. Jul 31, 2018 at 8:58 AM
    GodlessPro
    Matthew
    NorCal
    What size tires are you running? That much caster would push you back pretty far to the body mount wouldn't it? I might have my directions mixed up.
    831Tun likes this.
  16. Jul 31, 2018 at 9:00 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Not with Camburg arms. They have the opposite problem of the Icon arms. Needs too much caster.
  17. Jul 31, 2018 at 9:00 AM
    d0zer
    2017 MGM Platinum
    I'm pretty sure high positive caster pushes the wheel towards the front of the vehicle. Like a chopper motorcycle. I have a bunch of room between the body mount and could easily roll 35s. Right now i'm on 295/70r18s on +25 offset wheels (SCS).
    joonbug and GodlessPro[QUOTED] like this.
  18. Jul 31, 2018 at 9:05 AM
    GodlessPro
    Matthew
    NorCal
    You are right, I had it reversed in my head.
    dcsleeper408 likes this.
  19. Jul 31, 2018 at 9:07 AM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I have ADS 3.0 with MCM UCA...no issues. Here are my numbers:
  20. Jul 31, 2018 at 9:10 AM
    GodlessPro
    Matthew
    NorCal
    Can you take a pictures of the driver side at full lock? I might have to adjust more than I was expecting.
  21. Jul 31, 2018 at 9:11 AM
    d0zer
    2017 MGM Platinum
    @14burrito , make sure you have this spacer facing forward.
  22. Jul 31, 2018 at 9:17 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @14burrito , which 3.0's and UCA's do you have?
    dcsleeper408 and GodlessPro like this.
  23. Jul 31, 2018 at 9:31 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Currently have ADS 2.5" but thinking of making the jump.
    For all the caster discussion, didn't want yo really go there but...
    Caster gets tricky depending on control arms. With Camburg, as they have a lot of caster built in....less positive caster will actually move the wheel BACK into the body mount. Lets say on a OEM arm, the positive caster will move the wheel forward.
    831Tun, joonbug, dcsleeper408 and 2 others like this.
  24. Jul 31, 2018 at 9:43 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When talking about 3.0's, you have to discuss caster and the arms. The UCA's are everything. There is so little room between the tie rods and the axles that you have to get the shocks right in between by adjusting caster. If you have Icon Tubulars like me, your caster will be too low. Camburgs, caster will be too high. MCM and Total Chaos seem to have it right in the middle. As soon as I can confirm my Resi hose can clear MCM arms, I think I'm going to make the switch. It's really a shame because I really wanted to keep the Delta Joints on my Icon arms.
  25. Jul 31, 2018 at 9:45 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Camburg Billets with Icon 3.0's on my truck. I have zero contact at 6.8 degrees of caster on the left and 7.8 degrees on the right. Drives like a dream.
  26. Jul 31, 2018 at 9:45 AM
    GodlessPro
    Matthew
    NorCal
    Go Total Chaos with the Delta Joints. That is what I wanted to to.
  27. Jul 31, 2018 at 9:49 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Total Chaos won't clear the resi hose on the Icons. I'd have to remove the shocks and swap the left and right to clear and the hose which will then be too short and rub the springs. If I'm going to do this, I'm going to do it correct this time.
  28. Jul 31, 2018 at 9:50 AM
    TheBeast The Beach
    I see you grinded the front sway bar ears like me. i run KING 2.5 and the square ears were touching the base of the coilovers
    831Tun likes this.
  29. Jul 31, 2018 at 9:51 AM
    sdhq_offroad
    GILBERT, AZ
    The manifold at the top of the shock where the reservoir fitting goes in rotates. So you can rotate it left and right.
  30. Jul 31, 2018 at 9:53 AM
    TheBeast The Beach
    :spending::spending:
