3”/1.5” to level ?
Discussion in 'Suspension' started by Cpa757va, Mar 1, 2020.
  1. Mar 1, 2020 at 6:58 AM
    Cpa757va
    Cpa757va [OP] New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    I need some opinions. Goal is to level and even slight rake would be fine. Already ordered 285/70/18 RG with SCS ray 10s +25 mm offset.
    option 1: Bilsteins 6112 set at 2.5” with CB shim each side for 3” front with 1.5” shackle in rear.
    option 2: Bilsteins set at 2.5” and shackle at 1” in rear.
    Option 3. Bilsteins set at 1.9” with two driver side shims and one passenger side shim and shackle in rear (1” or 1.5”??)
    I have 5100s in rear already and I already have Icon delta joint UCAs being installed as well.
    thanks for any input, experience.
  2. Mar 1, 2020 at 3:19 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Click on my build thread Supe's MGM Sport Build for all your answers.
  3. Mar 1, 2020 at 3:21 PM
    timsp8
    NY
    I have the 6112s at 1.9” and CB +2 shackles and I have a slight rake. If you want yours level then 6112s at the top setting with CB +2 should do it.
  4. Mar 1, 2020 at 3:28 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    3/1.5 will look the best in my opinion. When these trucks don’t have rake in the rear over a certain amount the front end always look higher to me. I’m at 3/2 but I have a canopy and put a tent on so I’m sure it settles to 1.5 I think it looks perfect. I had 3/1 for a while before and like I said always look nose high....I did 2.5” nothing in the rear at first then did 2.5/1 which looked great then upgraded to my fox 2.5 coilovers. Keep some rake. Make sure to do a cb drop to anything over 1” and diff drop in the front anything over 2.5.
    Rengawt, Stroke250 and Cpa757va[OP] like this.
  5. Mar 1, 2020 at 4:52 PM
    Cpa757va
    Chad
    Hampton roads VA
  6. Mar 1, 2020 at 6:18 PM
    r1-superstar
    DB
    UTAH
    The 6112s are set at the top setting and I have one shim on the passenger's side and two on the driver's side; 3" of total lift.
    Cpa757va[QUOTED][OP] likes this.
