2WD Tundras - 3rd Gen
Discussion in '3rd Gen Tundras (2022+)' started by Big Baker, Sep 2, 2022.
  1. Sep 2, 2022 at 6:05 PM
    Big Baker
    Big Baker [OP] New Member
    2022 Tundra Limited 2WD in Blueprint
    I just ordered my 2WD CrewMax Limited from the dealer. I'll post pictures as soon as I can.
    Looking through these forums, I see lots of great pictures of trucks with Level Kits, Lift Kits , wheels and tires.
    Now, I'm curious to see if anyone made their 2wd look like a 4wd?
    Share some pictures and specs please.
    **Edit** - I want to know what size tire I can add to a 2WD truck before needing a Level or Lift.
  2. Sep 2, 2022 at 6:23 PM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    How do you tell the difference between a 2nd and a 4wd by looking at the exteriors?
  3. Sep 3, 2022 at 12:58 AM
    xc_tc
    xc_tc New Member
    2WD ride height is lower
  4. Sep 3, 2022 at 3:04 AM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    You can add the same leveling spacer to it.. turn it into a Pre-runner Tundra!
  5. Sep 3, 2022 at 4:16 AM
    porterbc
    porterbc New Member
    Brandon
    Mall crawler !
    22PlatWCP likes this.
  6. Sep 3, 2022 at 6:43 AM
    Big Baker
  7. Sep 3, 2022 at 6:47 AM
    porterbc
    porterbc New Member
    Brandon
    That would be based off the lowest part of the vehicle off the ground. Which generally is the front lower A-arms or rear diff. And nothing will change that height except for tire size..
  8. Sep 3, 2022 at 6:50 AM
    xc_tc
    xc_tc New Member
    Yeah because the lowest point on the truck is the differential and that’s what Edmunds is listing. Toyota lists a “running ground clearance” and the 4x4 is 0.7” higher than the 4x2. Approach and departure angles should be different for 4x4 too.
    porterbc likes this.
