2WD 5.7 CrewCab... What U-Joint part numbers?
Discussion in '2nd Gen Tundras (2007-2013)' started by TexasGuyTX, Apr 28, 2024.
  1. Apr 28, 2024 at 2:59 PM
    TexasGuyTX
    TexasGuyTX [OP] New Member
    Ryan
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    Found the # in the 00-06 thread for the 1st gen's.. but have some conflicting numbers for the 07+ up 5.7 2wd's. I would just ignore it my trucks lurch seems to be getting worse want to get these all replaced since I can't grease them
    EDIT: Truck is a double cab
  2. Apr 28, 2024 at 4:22 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    According to ToyoDIY.com:
    04371-0C080
    That number has been superseded to:
    04371-0C084
    Double check your VIN into ToyoDIY and confirm. You can use them to cross reference at Dana/Spicer.
    It looks like:
    Greaseable - Dana/Spicer 5-178X
    Non-greaseable - Dana/Spicer 5-1350X
    Rockauto has them for a decent price. At least when I have ordered Dana/Spicer u-joints from Rockauto, they are typically drop shipped from the factory.
    TunaDr likes this.
  3. Apr 28, 2024 at 4:25 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Is there really a difference between 2wd and 4wd driveshaft u-joints? Obviously I don't know but I doubt there is.
  4. Apr 28, 2024 at 5:37 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    If your truck is the white one from pics in a previous thread, that truck is a Double Cab
  5. Apr 28, 2024 at 6:39 PM
    TexasGuyTX
    Ryan
    RGR that thank you
    ah yes i mispoke thank you ill edit it
