2WD 2016 Crew Max 6 inch lift Advice.
Discussion in 'Suspension' started by TUNDRAZX1400, Jul 23, 2017.
  1. Jul 23, 2017 at 7:47 AM
    TUNDRAZX1400
    TUNDRAZX1400 [OP] New Member
    2013 Gun Metal Gray Texas Edition Tundra
    Toneau BakFlip 7' Bed Cover Yakima Bike Rack
    Hello,
    Would the 4WD 6inch Rough Country kit work with 2wd Crew Max. l've called rough country and the Customer service rep said it would. Just not all of the parts from the 4WD kit would be used. Can anyone else validate this?
  2. Aug 3, 2017 at 3:22 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Yes, the only thing you would not use is the differential drop. Hope this helped. Post pic if you get it installed
    040Tundra likes this.
  3. Aug 3, 2017 at 3:36 PM
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    I have a 2WD 2016 and there are only two that fits on my truck if you go 6" kit. Procomp and Fabtech. I called Rough Country and they only have leveling kit available. They said maybe in 3-6months they have a kit for the 2WD 6". Anyway, I took the Procomp coz its a good brand. Its a little bit pricy, but when its all done, i was stoked. check this out https://www.4wheelparts.com/Suspens...anufacturer_PQ=Pro+Comp+Suspension#ReadReview
  4. Aug 3, 2017 at 4:02 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'd get a BDS.
    Buy once cry once.
  5. Aug 3, 2017 at 4:19 PM
    Stay away from s spacer lift IMO rough ride
    Law323 likes this.
  6. Aug 8, 2017 at 8:35 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    If you are 2wd, why not get a spindle lift and add some bilsteins or coilovers for a 6" lift?
    strosek7 likes this.
  7. Aug 8, 2017 at 8:57 AM
    strosek7
    strosek7 New Member
    2016 Black Tundra SR5 DC
    Excatly my thought, best suspension upgrade and best price for 2wd
  8. Aug 8, 2017 at 10:36 AM
    rons23
    Ron
    Kill Devil Hills
    I agree with both of you and was told that's the best option for 2wd, but.......... You can't install spindles unless you have aftermarket wheels. Won't work with OEM. I have been known to be wrong from time to time, but I'm willing to roll the dice :cool:
  9. Aug 8, 2017 at 10:55 AM
    strosek7
    strosek7 New Member
    Depends on tire size also. Check with vendors, CST and Maxtrac are the most popular. may be able to use wheel spacers
  10. Oct 9, 2017 at 1:46 PM
    Payaso 9394
    Payaso 9394 New Member
    Ricky
    La Puente CA
    16' Tundra 2wd CrewMax 5.7l
    Tint, 33x12.5r18
    I'm running maxtrac spindles with icon coilovers for the front with icon ucas rides ok a bit bumpy thou still trying to see how to fix that but I have about 4.5 5 inch lift the spindles say they give 3.5 lift and I out my coilovers at about 1.5 2inch for lift here a pic
  11. Oct 9, 2017 at 1:47 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  12. Oct 9, 2017 at 1:50 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    I got it next to a 6 inch 4x4 lift the one on right is the 6 inch lift20170929_081305.jpg
    CJ21 likes this.
