2UZ-FE replacement advice
Discussion in '1st Gen Tundras (2000-2006)' started by Georgemcfly, Dec 22, 2018.
  1. Dec 22, 2018 at 7:58 AM
    Georgemcfly
    Georgemcfly [OP] New Member
    A few months ago I hydrolocked the engine in my 2000 Tundra with the 4.7L V8. I just ordered a used replacement that has about 160k miles and tested well. It is being shipped now and I’m excited to get it installed and rolling again. I am wondering if there are any engine components that are known to need maintenance or replacement in the 160k to 230k mile range. I figure it will be easier to do this before I install the engine and want to prevent any likely issues. Any advice?
  2. Dec 22, 2018 at 8:08 AM
    Casper421
    In the woods
    06 DC
  3. Dec 22, 2018 at 8:30 AM
    Professional Hand Model
    Hand Protectors
    Were we driving through large bodies of water? Pics!
  4. Dec 22, 2018 at 2:26 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you're putting in a new engine I would probably go ahead and replace the starter/alternator/power steering pump and radaiator. Drive belt too. Someone already mentioned the timing belt and water pump. Some would call this overkill but I'm anal. It's just so much easier to do this now. The parts should be relatively cheap. If you're going to start over you might as well do it with everything new.
    This assumes you're planning on keeping the truck. If you're not, then just stick with the engine swap.
  5. Dec 22, 2018 at 2:52 PM
    BIGUGLY
    Paul
    2018 Limited
    Make sure there is no manifold cracks or you will end up with a ticking sound till engine warms enough to heat up the crack.
  6. Dec 22, 2018 at 6:25 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    With the motor out take a peek at your steering rack. And with the other motor out and no trans attached maybe check your front and rear main seals.
    SCV 2000 Tundra Girl likes this.
  7. Dec 22, 2018 at 6:37 PM
    koditten
    Kirk
    Midland of the Mitten
    We're you in deep enough water to submerge the starter? It is on the top of the engine.
  8. Dec 22, 2018 at 8:00 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    If it was that deep the truck is a write off. Your interior would be flooded. All electrical connectors full of water. Let's hope not.
  9. Dec 23, 2018 at 6:29 AM
    Hand Protectors
    I wonder if he hit any mailboxes during the submarine journey?
    bmf4069[QUOTED] likes this.
