2nd row seat compatibility
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Adgoff21, Apr 8, 2025.
  1. Apr 8, 2025 at 3:14 AM
    Adgoff21
    Adgoff21 [OP] New Member
    I have a problem. I bought a 2021 sequoia from salvage where the interior had been vabdalized. I am in process of replacing everything required. The only item I cannot get from the stealership is the 2nd row RH bottom seat cover. No where on the country is it available, so I am left with finding a used seat. Thus far I haven't found a gen 2 sequoia with sand beige interior in any regional salvage yards. I have only found one possible solution which is the reason for my post. Will a 2nd row from a 2014 sequoia bolt up into a 2021? They look identical. My 2nd row seats are not heated or cooled, only manual. I should have already mentioned, but both mine and the donor have 3 seats in the 2nd row. Thank you for the feedback.
  2. Apr 8, 2025 at 3:25 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Why not just purchase Katzkin or clazzio covers?
  3. Apr 8, 2025 at 5:48 AM
    Adgoff21
    I will inquire there and see. Will they match the OEM covers? Or will this require the whole 2nd row to be recovered, if I want them to match?
  4. Apr 8, 2025 at 9:16 AM
    shawn474
    MoCo, Maryland
    They have a number of color and material options; you might not get exact but you may be able to get away with something close enough to pass…..honestly would probably take the whole second row to be covered to look decent but it really isn’t that expensive (if you can get only the second row) and they work really really well. Have had them in my tundra for almost 5 years and still look new
