2nd gen wheel bearing replacement anyone use Dorman?
Discussion in '2nd Gen Tundras (2007-2013)' started by RToad, Feb 20, 2022.
  1. Feb 20, 2022 at 3:44 PM
    RToad
    RToad [OP] New Member
    South Carolina
    2013 going to do both front wheel bearings due to a shimmy that gets much worse when turning into a curve at highway speeds.
    Can anyone touch on the quality of Dorman front wheel bearing assemblies? I have used their products on other vehicles without issue.
    Also looking at the BECKARNLEY?
  2. Feb 20, 2022 at 4:40 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have never had issues with Dorman stuff, but I never tried anything as critical as bearings. I honestly would probably pay a bit more for oem or a higher end brand.
    Alot of ppl on this forum will give you shit for using Dorman, like you don't love your truck lol
  3. Feb 20, 2022 at 5:54 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I’d go with Timken
  4. Feb 20, 2022 at 6:17 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    What’s the price difference between oem vs Dorman or timken?
    I would always recommend oem
  5. Feb 20, 2022 at 8:46 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I would get the pre-pressed Koyos off eBay.
  6. Feb 20, 2022 at 9:51 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I won’t say that I’ll never use Dorman products again, but it will be on a vehicle I’m about to trade, sell, or have similar low expectations of lifespan. And that’s from personal experience of how short their products do last.
    I wouldn’t buy a Dorman truck, would you? Yeah, I’m well aware that Toyota doesn’t make bearings. But I’d far sooner go for a Koyo, Timken, or SKF (often reboxed Koyo bearings for these applications) before I wasted my time with Doormat.
    Longtimecoming07 and RToad[OP] like this.
  7. Feb 20, 2022 at 10:06 PM
    2mchfun
    With the current situation you might have to use whatever is available and be thankful to have some. Still lots of shortages on various things.
    Hbjeff and RToad[OP] like this.
  8. Feb 21, 2022 at 1:30 AM
    RToad
    South Carolina
    I don't see a Timken hub assembly. I want to purchase the wheel hub assembly not just a bearing or I would go with Timken.
  9. Feb 21, 2022 at 1:31 AM
    RToad
    South Carolina
    I do see a SKF hub assembly available on Rock Auto but only 1 left. When I do a google search everyone else is out of stock.
    You seem pretty knowledgeable on this, have you had any experience with BECK/ARNLEY?
  10. Feb 21, 2022 at 1:45 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    I did mine with hub assemblies from a place called blue pit bearings.great service and fast shipping, was a few years back though.
    RToad[QUOTED][OP] likes this.
  11. Feb 21, 2022 at 1:50 AM
    RToad
    South Carolina
    Dr Doobie[QUOTED] likes this.
  12. Feb 21, 2022 at 1:54 AM
    Dr Doobie
    Talkeetna,Alaska
  13. Feb 21, 2022 at 1:57 AM
    RToad
    South Carolina
    Yes sir. Most likely the route I will go. Do you recall if the o-rings came with?
  14. Feb 21, 2022 at 2:06 AM
    Dr Doobie
    Talkeetna,Alaska
    Sorry, it's been a few years, I don't recall.
    I would imagine they do, but would be a good thing to ask about when you order.
  15. Feb 21, 2022 at 7:19 AM
    Blur'd Vision
    Blur'd Vision New Member
    Dave
    2007 Tundra DCAB SR5
  16. Feb 21, 2022 at 7:32 AM
    RToad
    South Carolina
    I actually discovered that my front lug nuts were loose this morning. I had them torqued to 110 ft lbs. Book calls for 97 on aluminum wheels. I went 120 ft lbs today. Will update. Issue is gone.
  17. Feb 21, 2022 at 8:09 AM
    2mchfun
    Perhaps someone was attempting to steal your rims and didn't finish for whatever reason. Had that happen to me once. May wanna consider wheel locks if you don't already have em'.
  18. Feb 21, 2022 at 9:29 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Beck/Arnley is typically quality stuff, though it varies a bit in my experience. I wouldn’t be surprised to open a Beck/Arnley box and find the bearing is one of the good name brands I mentioned, but can’t guarantee it either.
    I’d try them way before Dorman, any day, all day.
  19. Feb 21, 2022 at 9:34 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Do you have stock alloy wheels with these style lug nuts?
    The 97 ft-lbs spec does not apply to aftermarket wheels with taper-seat lug nuts. There is far more friction on taper-seat nuts, that is why Toyota’s spec for steel wheels with taper-seat nuts is 154ft-lbs.
  20. Apr 4, 2022 at 4:19 PM
    RToad
    South Carolina
    Great info, thank you. That explains why I had trouble. I have them torqued to about 120 now haven't had any issues.
  21. Apr 4, 2022 at 4:21 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Most Dorman stuff is junk I'd stay away.
