2nd gen tundra payload rating
Discussion in 'Towing & Hauling' started by Luckster, Mar 20, 2023.
  1. Mar 20, 2023 at 6:01 PM
    Luckster
    Luckster [OP] New Member
    '11 4.6L Dual Cab
    Okay so here is a crazy one. Using the 2018 Tundra as a benchmark (last year with factory trans cooler), the tundra weighs ~5500lbs and has a payload of ~1500lb (using easy rounded numbers here). Now the Seqoia on the other hand weighs ~7500lbs and still has a payload rating of almost that 1500lb.
    So now work with me here, if you are crazy and already planning on doing a frame stretch to get the Crewmax with a 6ft bed, and rather than stretching the Tundras frame, instead swapped a Seqoias fully boxed frame and stretched that (since the first major issue is the Seqoia has a shorter wheelbase and thus frame) would it not stand to reason that the Tundra should then be able to handle that 2k difference and have a payload of over 3,000lbs?
    Other than possibly suspension, is there any other difference in the platforms or reason that isnt technically possible?
  2. Mar 20, 2023 at 7:01 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I like the theory but I'm seeing a Sequoia's curb weight at about 6,000lbs with 1,300lbs payload... So not so much difference to the tundra. The biggest problem I would think would be the independent rear suspension and cab mounts. Otherwise engine, trans, and transfer case should all be in the same spots from what I know, but don't hold me to that :notsure:
    Cpl_Punishment likes this.
  3. Mar 20, 2023 at 10:06 PM
    Luckster
    '11 4.6L Dual Cab
    I will have to double check the spech sheet I was reading.
