2nd Gen Tundra Grade trim - are they prewired for foglights
Discussion in '2nd Gen Tundras (2007-2013)' started by mjninc, Jul 15, 2021.
  1. Jul 15, 2021 at 8:02 AM
    mjninc
    mjninc [OP] New Member
    2010 Tundra 4.6L 4x4
    2nd Gen Tundra Grade trim - are they prewired for foglights?
    I've seen a thread on adding fog lights to Tundras without them, but that was for a 3rd gen, just not sure if 2nd gen is pre-wired for them.
    If they are pre-wired, would the install be pretty much the same as the 3rd gen?
    Thanks!
  2. Jul 15, 2021 at 8:10 AM
    On my 2010, when I added them, they (OEM kit) came with a harness and a switch that went into one of the switch blanks on the dash. I don't remember if I had to run the harness all the way down to the bumper or not.
  3. Jul 15, 2021 at 8:12 AM
    mjninc
    Thanks, do you have a link to the kit you used?
  4. Nov 2, 2021 at 2:59 PM
    SanDiegoSlovak
    SanDiegoSlovak Junior Woodchuck
    San Diego, CA
    2008 Double Cab SR5 4x4
    Eibach Pro Truck Coilover Stage 2, RCI skids (engine, transmission, rear diff), Demello Hybrid Sliders, Morimoto XB headlights
    OP - did you end up finding out if you can add fog lights to your 2nd Gen Tundra that didn't come with them from the factory?
  5. Nov 25, 2021 at 2:42 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    yes there are factory plugs tucked away in there. search google a bit more theres a write up of addding a relay in fuse box and it activates the lines. you have to replace the left turn signal stem since it has built in fog light switch or you can run a momentary switch and tap into the lines under dash. I had a car audio shop figure out which lines to tap with a switch that pops into one of the empty slots and used factory wiring in the engine bay
  6. Jun 24, 2023 at 5:29 PM
    unchino
    unchino New Member
    TunaDr I have a 2011 pre wired do you happen to have a diagram or color that i would have to tap into.
  7. Jun 24, 2023 at 6:58 PM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    I bought my 2010 SR5 in 2017. My OEM foglight plugs were zip tied to the frame.
    I added a relay and found the correct steering wheelswitches. I installed it and everything works fine.
  8. Jun 25, 2023 at 8:48 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Yes, Yes Yes, my 2010 Grade has relay wire from dash and wires to the lights. It did not come with fog lights but is pre-wired. You need a relay, switch, power, Ground, and lights of your choice.
    Tundra Fog Lights:
    84140-02670 SWITCH $116
    52126-0C020 LEFT BRACK $61
    52125-0C020 RIGHT BRACK $61
    81210-AA030 FOG ASSEMBLY $182 < I used Morimoto XB LED's into the OEM housing.
    Part numbers are for chrome bumper.
    Thread is here. One wire to disconnect. I modified the switch making it short to ground when on to operate the relay.
    Look!!!--> https://www.tundras.com/threads/electrical-mods-fog-install-and-led-flasher.122423/#post-3137310
    Edit:
    Post has schematics and steps to wire new fleabay dash switch. My fogs come on with any light setting on and turn off via switch or if lights are turned off.
    The active high switch needs modified to be active low. See napkin schematic in link.
  9. Jun 25, 2023 at 9:13 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
