2nd Gen Transmission Drain and Fill DIY How-To
Discussion in '2nd Gen Tundras (2007-2013)' started by chrisf111, Feb 4, 2024.
  1. Feb 4, 2024 at 1:56 PM
    chrisf111
    chrisf111 [OP] New Member
    After a bunch of research I finally took on this job today and figured I'd document the process - both for myself and anyone who may want to attempt this. I did this on my 2007 5.7L 4WD Crewmax. From what I understand the procedure is identical for all 2nd and 2.5gen tundras.
    I won't get into why or when to drain yours but I am doing this on my truck with 230k miles. I am planning to do this 3 times over the next 3 months to exchange all the fluid. The transmission holds about 12-13qt total and this method only drains 3qts.
    This youtube video was a big help to me, especially with the explanation of how to get into check mode and how to pin the thermostat.
    https://youtu.be/pOrsNW2GXJs?si=XQEpPwrwCueJ_CEt
    Tools Needed:
    Parts Needed:
    Bolt Sizes
    • Fill bolt - 24mm
    • Drain plug - 14mm
    • Check port - 5mm hex (allen wrench)
    Overview
    1. Empty fluid from pan
    2. Fill with new fluid
    3. Drain off any excess fluid and check level
    Procedure to enter check mode:
    I suggest practicing this procedure before doing starting this job. It's a little tricky and it took me a few trys.
    1. Jump OBD ports 4 & 13 (put one end of the paperclip in each hole pictured below)
    2. Depress Brake & start Truck
    3. Shift through all gears slowly to allow fluid to circulate (P>R>N>D>S (1-6)>D>N>R>P)
    4. Shift to N
    5. Shift to Neutral >Drive> Neutral >Drive> Neutral >Drive> Neutral
    6. When you go back into N the last time the "D" light and the "N" light on the dashboard should both stay lit for 2 seconds. If they do not you did something wrong.
    7. Shift to Park & Release Brake (you can remove jumper wire at this point; I did to plug in my own scanner and watch trans temp)
    8. When in check mode:
      1. "D" OFF - Trans Temp too low for check
      2. "D" ON - Trans Temp OKAY for check
      3. "D" Flash - Trans Temp too hot for check, let truck cool down
    9. This post has manuals for the different transmission types with the temperature ranges this procedure looks for. You shouldn't need it unless you want to verify with OBD scanner that the temperature is correct. It's just imporatnt to note that not all trans get checked at the same temp.
      1. https://www.tundras.com/threads/transmission-drain-and-fill-capacity.108168/#post-2794524
      2. You can find your trans type on the drivers door sticker bottom line. Mine was a AB60F.
    Drain Fluid
    • Before draining confirm you can open the fill bolts and check bolts. You don't want to get stuck an empty trans and no way to fill it
    • This step can be done while truck is cold or hot (I opted for cold so I didn't have hot fluid everywhere)
    • Open the drain bolt and let the fluid drain into a container
    • Measure the amount of fluid drained. I poured mine from the catch pan into an old 5qt oil can and saw how many quarts it filled. I drained just under 3qt
    • Replace plug
    Fill Fluid
    • Replace drain bolt unless you want a driveway full of fluid
    • Open fill plug (24mm, I needed the wobble bit to get around the exhaust)
    • Route PVC tube from top of engine bay into the fill plug. The 5/8" OD should be a snug fit. Push it in a bit, you don't want this falling out. Beware of routing PVC against hot components.
    • Connect the tube to the Trans Funnel and fill transmission with approx. the same amount you removed. I opted for about 1/4 QT more than I removed just to avoid having to do it again (any overfill will be drained out in next step)
    • Remove tube and replace plug
    Check Level
    • If you have a transmission cooler you need to pin your transmission fluid thermostat to ensure fluid is circulating through the full system. See picture below. Use your screwdriver to push in the plunger then push a pin through the holes in the bolt so the plunger is locked in.
    • Loosen Check bolt before starting truck
    • Turn off lights/AC/radio
    • Start truck from cold and enter check mode
    • As the fluid warms up it will expand and fill up the pan. The check port is calibrated so that when it expands enough to overflow through check hole it is the proper level. Because of this you can safety open the check port before it reaches check temperature.
    • When the "D" light comes on allow fluid to come out the check hole until it becomes a trickle. Note: because the transmission is still heating up the fluid is still expanding and will continue to drain out the check hole. With this in mind, once the stream is no longer full force you can call it good. Re-plug the check bolt before the "D" light starts flashing and you're good.
    Cleanup
    • Make sure all bolts are tight. Toyota specs call for the drain and check to be tightened to 15ft-lbs and the fill to go to 29ft-lbs. I do NOT recommend this. I stripped my drain port like this. Just tighten to "nice and tight" without over-doing it. Details in next post.
    • Remove pin from trans cooler (if you have one).
    • I marked the bolt positions with a paint marker to make sure they are not coming loose.
    Other Notes:
    • For my AB60F transmission this range is 99deg - 111deg. This may vary based on your truck year. See link above or just use the built in check method.
    • The drain plug and the check plug are the same bolt size, just different heads to avoid confusion. The check plug has "CHECK" stamped in it"
    • Truck should be level when checking level. I used a 4' level on the bedrails and across the tailgate.
  2. Feb 4, 2024 at 2:04 PM
    chrisf111
    As mentioned in the original post I overtightened my drain plug and caused it to strip. I tightened it by hand first then went to check the torque with the torque wrench set to 15ft-lbs. It just kept spinning. I found multiple other posts online about the exact same thing happening. See picture below of what I suspect happened. The internal threads ripping off.
    In my case the bolt was still able to get very tight, much tighter than hand tight, and was not leaking a drop after a test drive and several hours.
    I figured I had three options to repair
    1. New trans pan
    2. Tap new larger hole
    3. JB weld the heck out of it and hope it never leaks
    I didn't have a new pan on hand, nor did I want to mess around with tapping this hole. To tap you really need to remove pan anyway to make sure no metal shavings get into the pan. As the truck has 230k miles on it I went for the JB option.
    I did this knowing that if I want to do another spill/fill in the future I can drain the fluid with a siphon through the check port. Also, if this cheap quick fix leaks, I can just do the more complete fix (1 or 2) in the future.
    So, I ran down to the local autoparts store and got some JB Weld, sanded down the area, and sealed it up.
    Once it dried I will remark with a paint pen and monitor for leaks. I will update here if there are any issues, and how my siphon plan works out if I ever try it.
    All this being said, do NOT overtighten these bolts. The forums are littered with stories of this happening to other people. The torque spec is too high or is for a dry torque only. Please only take this just beyond hand tight and let the crush washer do it's job.
    Slim Gym, chugs and joseph_womack like this.
  3. Feb 4, 2024 at 3:50 PM
    MiataOwner93
    MiataOwner93 New Member
    Saving for future reference. Great write up OP!
    chrisf111[OP] and Tridom like this.
  4. Feb 4, 2024 at 7:13 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    Very good detailed write up sir, will use this for future reference. Thank you!
    chrisf111[OP] likes this.
  5. Feb 5, 2024 at 6:48 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Saved in my archives as well.
    I always rely on some YouTube video to remind me of the OBD jumpers.
    Thank you sir.
  6. Feb 5, 2024 at 9:03 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I’ve used this method the last 4 times without any problems. The last time I had it in the shop, I had them check the tranny fluid level and it was almost dead on. The tech said it was maybe overfilled by about 2 ounces.
    https://youtu.be/NX3WRAPJ0Aw?si=mb8b9F8pQ-QvCFPQ
    chugs and Rph74 like this.
  7. Feb 7, 2024 at 8:59 PM
    Mbril
    Mbril New Member
    Thank you for this very detailed write up.
    I’ve been researching/studying to properly do a drain and refill on my truck.
    Most people miss the trans cooler thermostat which is critical to do it right.
    If you have the tow package, you have a trans cooler.
    I’m curious why you would go through the shifting procedure to check temp instead of simply plugging in your obd2 scanner?
    The nice thing about the overfill plug is that it can be used to check the fluid quality since we don’t have a dipstick.
    Anyways, I’m hoping to get mine done very soon if needed.
  8. Feb 8, 2024 at 5:30 AM
    chrisf111
    I used the shifting procedure and the OBD scanner at the same time. I would prefer to use the shift procedure and recommend it to others to avoid any confusion about what is the proper temperature, as it does change with the different transmission types available in our trucks. Also, the OBD returns two temps for the transmission, which can vary by a few degrees, and I was unable to find out which was the correct one to work off of.
    Mbril[QUOTED] likes this.
  9. Feb 8, 2024 at 7:32 AM
    COTundie
    Trey
    Pretty things
    I really don't know why anybody WOULDNT use this level check procedure. The truck itself tells you the proper time to open the overflow. I'm not sure what higher authority one could want or ask for.?
  10. Feb 8, 2024 at 7:34 AM
    chrisf111
    My thoughts exactly. It's very easy to enter this check mode with nothing but a paperclip.
  11. Feb 8, 2024 at 7:35 AM
    COTundie
    Trey
    Pretty things
    Well. Technically two paper clips (thermostat) ;)
    chrisf111[QUOTED][OP] likes this.
  12. Feb 8, 2024 at 3:15 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    On the topic of OBD + paperclip vs scanner or OBD App, on hot days the trans can shoot right past the check range. Watching it live allows one to predict, plan, and time your execution.
    From a post of mine on this topic.
    And yes, I dropped the pan as it was a used truck and I needed to know its health...
    [Paste]
    Connect your OBD port reading hardware and configure it for A/T Oil Temp 2 (TH02). I had both A/T Oil Temp 1 and 2 on display using OBD Fusion App and phone. TH01 monitors system line pressure used on clutches, and brakes. TH02 is used as a basis for modifying the ECT shift timing control when the ATF temperature is high. It is also used for the ATF temperature warning light. Or use the paper clip method. Your choice.
  13. Feb 8, 2024 at 3:27 PM
    chrisf111
    Great point. Considering my transmission check range starts at 99deg, it would be very easy to completely miss it even from "cold" if it's a hot FL day. I ended up using both methods in conjunction. After you get the D & N shift indicators to light up at the same time, the paperclip can be removed, and the truck will remain in check mode. At this point, you can plug in your OBD and verify with your scanner.
  14. Feb 11, 2024 at 5:48 AM
    chrisf111
    I originally bought 6qts of oil so I completed my second drain and fill today. Starting with the truck off, in park, and slightly warm I opened the CHECK bolts. About 1.5qts drained out. I tried to siphon out a little more, but couldn't get the tubes I had on hand to make the bends.
    Not wanting to mess with it too much I elected to just add the 3qts of fresh fluid in, let it mix while overfilled, and then drain off the excess. I should end up with cleaner oil afterwards.
    I closed up the CHECK bolt, used my fill tube setup to add the new fluid, took it for a drive around the block to mix everything up, and let it sit overnight to cool. This morning, I put it into check mode and drained off the extra fluid, around another 1.5 qts (which makes sense, as I added 3 qts total). Tightened up the check bolt and pulled the thermostat pin. Done.
    Hopefully, this solves some of my hard-shifting problems. I originally did this service because of hard shifts into drive after parked and high acceleration before shifting gears around 50-70mph. It would rev way past where it should before dropping into gear. It may be in my head, but after the first 3qts, it seems both issues improved. I will update again in a few weeks.
    Shanet421 likes this.
  15. Jun 6, 2024 at 11:08 AM
    Warrant_ero
    Warrant_ero New Member
    2017 tundra, 2008 Sequoia
    Nonr
    Any more feedback? How’s the tranny shifting? I have a 2017 tundra 93 k miles and a 2008 sequoia with 160k miles and want to conduct a drain and fill.
  16. Jul 14, 2024 at 8:25 AM
    chrisf111
    A drain and fill did not fix the issue I hoped to solve. I am still having the same "hard shift" issue. I think I need a new solenoid pack. I continue to get bad shifts and every now and then I'll get check engine lights with codes:
    * P2714 - Pressure Control Solenoid "D" Performance or Stuck OFF
    * P0761 - Pressure Control Solenoid "C" Performance or Stuck OFF
  17. Dec 1, 2024 at 6:33 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Thank you for this write up. It's much easier to read in layman's terms. The 5/8 tubing was perfect snaked through the engine bay. I don't think I even spilled a drop. Not as easy as an oil change, but not much harder either.
  18. Dec 3, 2024 at 10:01 AM
    chrisf111
    Awesome! Glad it was helpful to someone!
    Update on my situation: I am still throwing solenoid codes and shifting issues. Headed to a well regarded trans shop next week to get a professional's opinion
  19. Dec 11, 2024 at 1:49 PM
    dlvonde
    dlvonde New Member
    Daniel
    07 Tundar SR5 Base Model - Non JBL Sound System
    Thank you! My son and I watched a few videos and NONE of them mentioned this thermostat/pin step. We followed all the steps and at the end went to open the overflow drain and air shot out along with the fluid!!! :help:
    My understanding is pinning this open will help bleed any air out of the system? Or am I totally confused? Searching for my problem is coming back with nothing other than I may have overfilled it causing air pressure in the system...UPDATE: apparently I'm confused and this has nothing to do with air in the transmission..there's a breather I'm looking for now that might be clogged...
    We drained a hair under 3qt out and put a hair over 3qt back in...then started the truck and ran it through all the gears several times...then cracked open the overflow expecting a decent flow quickly followed by a trickle...but instead got a blast of air along with the ATF...perhaps I put more than just a "hair" more than 3qt back in :confused:
    I have done a few drain and fills on other vehicles but none of them had this issue...
  20. Dec 12, 2024 at 10:10 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    The amount of new ATF fluid that I went through my first time, was enough to just pay someone to do it. I pay a Asian toyota mechanic guy $80, I provide the fluid and boom done.
  21. Jan 20, 2025 at 8:05 AM
    Hoopcrazytr
    Hoopcrazytr New Member
    Please let us know what you find out from the transmission shop, I have a 2010 Tundra 4.6 that is throwing the same codes as yours, P2714 and P0716. The vehicle starts off in limp mode in the mornings but after warming up a bit I can power the truck off/on and drive normally without shifting issues, I have noticed an occasional slip into reverse though. Transmission has never been serviced and I’m sitting at 212k miles right now, was going to attempt a drain/fill to see if it resolved my issues.
  22. Jan 20, 2025 at 9:19 AM
    chrisf111
    Wow.. your symptoms are exactly the same as mine.
    2 weeks ago, I put it in reverse, and it never got any power. I was barely able to get out of the parking spot. I drove straight to the trans shop and they took a week to rebuild it at a cost of ~$5000.
    I've had it back for a few days now, and it appears my issues are gone. There are some hard shifts still, but I am told these will work themselves out as the truck learns the new transmission.
    I did end up having two different shops diagnosed before the reverse went out. Both said the thing: a new transmission or complete rebuild is needed. I would start saving your pennies for a new transmission now. If I remember correctly, I had been seeing those codes pop up for about 20k miles. In the last 5k miles reverse started showing issues. I'm not sure what the next issue would have been, but no reverse was the end of the line for me.
  23. Jan 20, 2025 at 9:59 AM
    Hoopcrazytr
    Glad you got your issues fixed, unfortunate it came down to a costly rebuild though. I’ve seen a few other posts suggesting to change the relevant solenoids from the CEL codes, I’m considering going that route first since they’re only ~$100/ea on RockAuto, did you look into that route?
    For what it’s worth, I had two shops look into my trans as well and both have advised a new tranny is needed without much further info.
  24. Jan 20, 2025 at 10:05 AM
    chrisf111
    Both shops I brought it to said the issue was almost certainly not the solenoids. One of them initially thought they could repair the problems with a 'zip-kit' to restore some line pressure, but with some additional testing, they found that was not the issue. I trust both shops; one is a Toyota-only shop, and the other is a transmission-only shop.
    This is my primary vehicle, and at the end of the day, a portion of the decision came down to limiting downtime while chasing problems.
    There was a point where I considered DIY solenoid change. Still, after considering the time and expenses involved in opening the transmission, draining the fluid, swapping the solenoids, and putting it back together, I decided to leave it to the professionals.
  25. Jan 21, 2025 at 11:15 AM
    AlexOd
    AlexOd New Member
    It does not NEED to replace drain bolt.
    JUST GASKET.
