2nd Gen OEM Apple CarPlay from current Sequoia
Discussion in 'Audio & Video' started by nwalnoha, Mar 2, 2021.
  1. Mar 2, 2021 at 9:21 PM
    nwalnoha
    nwalnoha [OP] New Member
    Nick
    Pennsylvania
    2013 CrewMax SR5
    • 3/1.5 lift : 3” Toytec/Eibach coil overs, Billstein 5160 rear shocks, Toytec 1.5” rear add-a-leafs, Wheelers bump stops, driveshaft carrier bearing drop, front diff drop. • 35” Atturo Trail Blade XT tires w/17”Method 305 NV Wheels • Alpha Rex Pro Series Projector Headlights, EAG Grille w/ Amber LED drls, LED taillight & turning signal conversions. • N-Fab MRDS front bumper w/ 40” curved Rough Country LED lightbar. • U-Pole Raptor Bedliner
    Looking into updating the interior on my 2013 2nd Gen a bit. Really want to have a modern looking head unit with Apple CarPlay. I know there is plenty of aftermarket options out there, but I’ve seen mixed reviews. Has anyone tried swapping in the head unit from the newer sequoias that have CarPlay stock? Any thoughts? Ive seen threads about other parts being compatible, but haven’t been able to find much info on this
  2. Mar 3, 2021 at 1:31 AM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I recall reading that it would be extensive wiring changes to make it work. I ended up w an Alpine ILX207 and it looks factory and works perfectly with the Maestro (steering wheel controls) and backup camera.
    nwalnoha[OP] and Luckydog like this.
  3. Mar 3, 2021 at 8:41 AM
    ultrarunner
    ultrarunner New Member
    2013 Sequoia Platinum
    I agree with Matt on this one. The OEM has built in so much functionality with the factor display units, that, while you can replace them with aftermarket, we'd loose a great deal of what is built-in. Can't even imagine trying to adapt a next gen OEM display with a previous gen harness!
    nwalnoha[OP] likes this.
