2nd Gen Headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by DTaylor, May 18, 2019.
  1. May 18, 2019 at 4:40 AM
    DTaylor
    DTaylor [OP] New Member
    David
    2007 Dbl Cab
    BDS Lift Kit
    Bought my 2nd Gen with some aftermarket headlights that are all messed up... the plastic looks to have melted and is full of small cracks. Any suggestions for some nice replacements... I see quite a few options out there.
    SQUAIDS likes this.
  2. May 19, 2019 at 1:26 PM
    EBenke
    EBenke I’m Ready To Go!
    Everett
    2007 Toyota Tundra DC, 5.7, 4x4
    3/2 lift, Icons, 35's, 3" CB's shackles
    Search this site lots of info available.
  3. May 19, 2019 at 1:33 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @DTaylor, unless you are looking to retrofit them, the new Spyders for the 2nd gens are very nice. There are members here running them.
    Black Wolf, chugs and DesertRoads like this.
  4. May 29, 2019 at 1:33 PM
    flyguysc
    flyguysc New Member
    [​IMG] [​IMG] Spyder®
    Chrome Halo Projector Headlights with LED DRL
    more details on - https://www.carid.com/2013-toyota-tundra-headlights/,got these put on last week .Install took approximately two hours. It was the unknown that took so long,if I had to do it again maybe one & a half hours. YouTube was a big help.
    tuna813 likes this.
  5. May 29, 2019 at 1:37 PM
    flyguysc
    flyguysc New Member
    Trooper2 likes this.
  6. May 29, 2019 at 2:13 PM
    Alot of the aftermarket lights are misaligned or leak. The OEM lights with leveler are about $225 each.
    TheBeast and Tundra Fan like this.
  7. May 29, 2019 at 2:17 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Wow that is the worst I've ever seen.
  8. Jun 1, 2019 at 10:19 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    find a set of OEM used lights and do a retrofit. You will not be disappointed.
    probably the best thing I have done to my 13 tundra
    dtpatt21 likes this.
  9. Jun 1, 2019 at 10:27 PM
    TheBeast The Beach
    or if you got the $$$..oem 2018+ Toyota Sequoia LEDS..
  10. Jun 2, 2019 at 5:27 PM
    dtpatt21
    dtpatt21 New Member
    Doug
    2007 Tundra 4WD Limited CrewMax
    Just putting in LED bulbs? Where did you buy?
  11. Jun 2, 2019 at 5:59 PM
    flyguysc
    flyguysc New Member
    autozone
  12. Jun 2, 2019 at 6:22 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    No, a full HID projector retrofit.
    I have LS460 with tuned clear lenses.
    Just do some research on “HID retrofits”
    I wouldn’t put LEDs in my headlights unless there have been drastic improvements in the past few years where the glare and ghosting is down
  13. Jun 5, 2019 at 1:49 PM
    marcfs71
    marcfs71 New Member
    Marc
    2010 Grey Tundra TRD Offroad Pkg with TRD Supercharger
    Dual Exhaust
    I used the Mothers Headlight Restoration Kit. Worked great! My headlights didn't look as weathered as yours though.
  14. Jun 8, 2019 at 7:36 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    I have had good luck with wet sanding and 2k clear coating to restore lights.
    But I think the lights in the OP are way beyond a lost cause
  15. Jun 8, 2019 at 10:06 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    If you go OEM, @Roman can help understand what you need for your truck. If you go aftermarket, read reviews, and be ready to RMA them since they can have issues with alignment and leaking. I got some after market ones that wouldn't adjust at all. They pointed way too high, my brights were lower. I ended up spending the money for OEM and they were perfectly aligned out of the box. They don't look as cool as Spyder, but I know I am not blinding people.
    Roman and EBenke like this.
  16. Jun 24, 2019 at 8:55 PM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    RMA? would love some advice on whatcha mean?
  17. Jun 25, 2019 at 5:07 AM
    FlipStyle54
    FlipStyle54 New Member
    Randolph
    2008 White Tundra TRD
    Return merchandise authorization (RMA)
    Either back for a refund or a replacement til you get a good copy
    TRD-tv[QUOTED] and sf319 like this.
  18. Jun 25, 2019 at 7:41 AM
    sf319
    sf319 New Member
    Utah
    Yes, like @FlipStyle54 mentioned, just be prepared to return or exchange until you get a good one. The ones that leak seem to either leak out of the box, or after some time, but can be easily avoided with some silicone sealer before install around the seam.
