2nd Gen Headlight Fob Acknoledgement
Discussion in 'Lighting' started by Rockin 2nd Gen, Feb 18, 2021.
  1. Feb 18, 2021 at 4:24 AM
    Rockin 2nd Gen
    Rockin 2nd Gen [OP] New Member
    Jay
    Ohio
    2010 Tundra
    5" lift 20x12 fuel with 35" nitto ridge graplers. Full led and secaine 9" android head unit.
    Hey.. So i installed AlphaRex Pro lights and i was wondering which plug is associated with the security feature of the truck. When you lock the vehicle with the Fob the Turn signals use to blink in acknowledgement. I have several plugs no longer plugged in with the new headlights and i am assuming one of these was this feature as i get no lights blinking when i lock the vehicle other than the rear tail lights. Would be cool if i could get it to work with the DRL.
  2. Mar 16, 2021 at 5:48 AM
    2ng Gen Tundra
    2ng Gen Tundra New Member
    I vaguely remember a video on the answer to your question. If remember correctly you need to jump the non used wire that looks like a connecter (see diagram below) for an HID light to the yellow wire on your turn signal pig tail 3 wire harness right behind the bulb. Hope this helps. I have the same lights just haven't got around to trying it yet . I will update once I do. [​IMG]
  3. Mar 16, 2021 at 6:44 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    That's funny. I don't remember having any unused plugs when I installed mine. I'll have to double check. My headlight security acknowledgement works, BTW.
  4. Mar 16, 2021 at 10:42 AM
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
    I will have to dig into this issue over the weekend. My Rig has been in the shop for a wheel hub.
