2nd Gen 4x4 Wear
Discussion in '2.5 Gen Tundras (2014-2021)' started by coolbeans, Mar 7, 2022.
  1. Mar 7, 2022 at 6:07 PM
    coolbeans
    coolbeans [OP] New Member
    Hi All. Wondering if anyone uses 4x4 a fair bit, and how it wears over time on these trucks. I have normally used mine only as absolutely needed on other trucks to avoid wear and costly repairs.
  2. Mar 7, 2022 at 6:15 PM
    Taco-Spike
    Two Trucks
    The manual says to engage it every so often.
    I’m sure it wears as designed.
    also, what ‘wear’ are you referring to? Anything specific? Transfer case, transmission, front/ rear diff, etc
    coolbeans[OP] likes this.
  3. Mar 7, 2022 at 6:22 PM
    coolbeans
    Just the typical components that wear as you use 4x4 a lot over time.
  4. Mar 7, 2022 at 6:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Aren't the mechanical bits pretty much the same as the Land Cruiser (which is full time 4WD)?
  5. Mar 7, 2022 at 6:54 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    I wouldn’t worry about it. I use mine every chance I get. Not that many xtra parts turning in 4x4. It’s better to use 4wheel drive a lot than not use it at all. Of course it needs to be used in low traction conditions.
  6. Mar 9, 2022 at 7:44 AM
    coolbeans
    Some people run their 4x4 all winter here in Canada. This can lead to significant wear and repairs.
  7. Mar 9, 2022 at 8:03 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Tundra's transfer case is very stout, the chain it's used in it is easily 1.5x the width of comparable 1/2 ton trucks, and keep in mind we don't use clutch so it won't overheat, the biggest problem is probably the actuators get rusty and need a rebuild, our differentials are massive, so use them away and just keep up with the maintenance!
    Wynnded and coolbeans[OP] like this.
