2nd gen (2008 4x4) front trd sway bars?
Discussion in 'Suspension' started by AJ Gator, Jun 7, 2018.
  1. Jun 7, 2018 at 12:35 PM
    AJ Gator
    AJ Gator [OP] New Member
    2008 Tundra DC Limited TRD 4x4
    Question is do they exist and do I need one ( I’m thinking yes on the later)?
  2. Jun 7, 2018 at 1:36 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I'm not sure if there is a specific TRD sway bar for the front of the trucks, but your truck should have come with a front sway bar.
  3. Jun 7, 2018 at 1:50 PM
    @Roman parts guy for us, u shud have one already
    Roman likes this.
  4. Jun 7, 2018 at 7:51 PM
    AJ Gator
    Yes, I know I have a sway bar on the front. My question was does Toyota make a trd one that will fit a 2008 and do I really need to upgrade it. Thanks for everyone’s input, sorry I wasn’t very clear.
  5. Jun 7, 2018 at 8:02 PM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    You probably don't really need to upgrade it, unless you find the front of the truck has too much body roll and want to introduce a little more understeer.
    Mountun Goat likes this.
  6. Jun 7, 2018 at 8:04 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    No need to upgrade anything on our trucks. Upgrading will make it feel tighter around corners. I took mine off for extra flex for off-roading. I don’t even miss it haha. Although I have pretty heavy springs up front.
    joonbug likes this.
  7. Jun 7, 2018 at 8:50 PM
    AJ Gator
    I will be replacing my stock front springs with 6112s so I don’t know if that will stiffen it up enough?
  8. Jun 7, 2018 at 11:22 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Do you know what the spring rate is? Or does it use the oem springs?
  9. Jun 8, 2018 at 8:23 AM
    Wintyfresh
    Ramona, CA
    I believe the 6112s use 650 lbs springs.
    AJ Gator[OP] likes this.
  10. Jun 8, 2018 at 9:45 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    My Old Man Emu springs are 750lbs and I can barely tell I don’t have a bar. Unless I try to avoid a deer at 120 haha:anonymous:
  11. Jun 8, 2018 at 10:49 AM
    TheBeast The Beach
    no need to upgrade front. However, you can add the one for the rear. Improves cornering and towing control.
    Mountun Goat and AJ Gator[OP] like this.
