2HI to 4HI grind
Discussion in '2nd Gen Tundras (2007-2013)' started by Fundra3649, Feb 11, 2020.
  1. Feb 11, 2020 at 4:28 AM
    Fundra3649
    Fundra3649 [OP] New Member
    I am in need of help. I have 2007 5.7 SR5 4x4. When I shift into 4HI it grinds around the transfer case until the 4x4 engages. There are no flashing lights on the dash. It drives fine in 4HI. When I shift back to 2HI there is a droning/vibration sound at slower speeds that can be felt a little in the steering wheel and in the floor boards around me feet. It grinds every time I try to put it into 4 HI. It only grinds into 4HI while moving. When I actuate the 4x4 with the truck stopped, the 4x4 engages perfectly. Any suggestions?
  2. Feb 11, 2020 at 4:35 AM
    timsp8
    NY
    Have you changed your transfer case fluid?
    15whtrd likes this.
  3. Feb 12, 2020 at 11:18 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Do you make sure you have stopped and shifted into N before shifting into and out of 4L?
  4. Feb 14, 2020 at 7:21 AM
    Fundra3649
    I have not checked that yet as I have been very busy with work and kids. I will check that. Is it just a fill hole on top and dump on the bottom?
  5. Feb 14, 2020 at 7:22 AM
    Fundra3649
    Yes I always do so if I use 4LO whick may be once a year. My issue is going into 4HI while moving. Under 50 MPH of course. I never shift info 4HI over 20 MPH.
  6. Feb 14, 2020 at 8:59 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
  7. Feb 14, 2020 at 9:16 AM
    Fundra3649
  8. Feb 14, 2020 at 9:16 AM
    timsp8
    NY
    I believe so but haven’t ever changed mine myself. I think there is a how to thread on here about it. Or maybe a YouTube video. I’m pretty sure it’s fairly easy to do in your driveway.
